Everything posted by cotrecerf
On a few other than ship modelling projects (wood toys for grandchildren) I have recently used linseed oil varnish WITHOUT any desiccants in it. It can be applied with a brush (in narrow places) or with a rag on smooth larger surfaces. Removed excess oil after a while. It well penetrates into wood, accentuating its grain and needs 48 hrs to thoroughly dry creating a firm seal. I like to employ it because its food proof. Joachim
What terrible news and so sad to learn that he passed away so early. I own some of his machines and really appreciate their fine execution and quality. Though I had only very little contact with Donna over the purchase process I send my condolences to her and the family. Once she decides to continue the business I hope to be in contact again. Joachim
Hi Valeriy, I have just visited marine-modellbau forum and found the following: 1. You have to REGISTER there AND have to WAIT for their confirming email to the email-address you indicated BEFORE you can enter the forum. 2. There are 2 small tick boxes somewhat hidden in the text of their Terms and Conditions you have to agree to during registration process. These can be easily overlooked. So, right now I am waiting for said email confirmation......Just received: it says I will receives a second email in acouüple of days, when my reidtrating will have been manually checked. And: I can visit the forum as a GUEST, which I am going to check right now. Best regards Joachim
Dear Valeriy, and again: thank you very much for your technology insight...a lot to learn and to keep in mind as a reference for own projects. I appreciate your adaptiveness to materials locally at hand as you are bringing me back from my tendency of applying technical "overkill". I am looking forward to this fine built. Best regards, greetings Joachim
Congratulations I've closely followed your exceptional work which undoubtedly has earned this prize. Greetings Joachim
- 589 replies
- le gros ventre
- cargo
Hi Kurt, many thanks to offer the valuable tables to us. FYI: I made a payment prior to the download and tried to activate the member discount code. Alas, it was not accepted by the system. I hope iot is not due me to being not located in the US but abroad. I am definitely not worried for the 2 USD (take it as a donation) but I hope that it will work on future purchases from this site. best regards cotrecerf
I solved the same problem (90%) by wrapping the book in a thick layer of newspaper after spreading some baking soda on the outer sides of the book. Then I put the parcel into my deep freezer for a couple of days (4-6 days). After that I slowly unwrappped the book and brought it to normal temperature in a dry environment. The musty smell was strongly reduced, the remainder is not so bad and the more you scroll through the pages the more the smell will go. Joachim
Dear Valeriy, so I do wish you for 2023. And as concerns the models, I am so selfish to hope to see your new models in 2023, too. best regards Joachim
MONTAÑES by Amalio
cotrecerf replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Hello Amalio, your clean and crisp work is just admirable. -
Hello Valeriy, happy to hear from you. Your philosophic view of difficult times in life pleases me very well, and I am sure you have not forgotten to live to the fullest your easy, beautiful and happy times, too. Your work is breathtaking as usual. Best wishes and greetings Joachim
A different approach to protect some silver soldering joints in short distances from each other is to use silver solder, mild, middle or hard (requiring the highest heat) in stepped succession, i.e. hard solder first and then down the temperature line. These silver solders are available in sheet or wire form.
Hello Valeriy, I fully second your point of view regarding meticulous manufacturing methods based on long established data. To me this is a way of Zen aspect: whatever you do, do it as well as ever possible and fully concentrate on what you are actually doing. best whishes to you. an absolute admirer
Here's to you, Valerij! I agree that you set a new and higher level of museum quality. best regards, take care and good luck Joachim
Italian Boats of the Adriatic Sea
cotrecerf replied to jack.aubrey's topic in Nautical/Naval History
JackAubrey, many thanks for the ample and fascinating info on these boats and ships. Great photo collection; not so easy to shoot them under sailing conditions. Yes, and I agree that the O'Brian naval novels are so enlightening for the era and always worth to re-read them. Each time I find new fascinating details to follow. best regards Joachim -
Valeriy, this is a marvelous approach yielding a top product. You're so ingenious. At your home, I hope all is well. All the best to you and best regards Joachim
Valeriy, I'm so glad hearing that you are well and able to continue your so impressive work. It's a pleasure to follow your build and and always admire your super-fine detailing work. All the best to you
In Steels Elements and Practice of Rigging there is described the making of Shround and how to come to the necessary lengths from fore to aft of the respective mast: David Steel: The Elements and Practice of Rigging and Seamanship 186*Shrouds made in the house RIGGING PREPARED IN THE HOUSE. THE RIGGING FOR THE LOWER MASTS. SHROUDS. The cablet is warped round two iron fids, fixed in the floor, as distant from each other as the first warp is long. The length, which is the distance from the top of the bolsters at the masthead to the foremost dead-eye, is specified in the Table of Dimensions. One end of the cablet is made fast to the lower fid, and passed round the upper fid; and so on, alternately, one turn close to the back of the other, and each hauled tight by hand. The additional length, gained by the turns lying round each other, is sufficient for the lengthening of each pair of shrouds, as they rake aft. When the whole gang of shrouds are warped out, the bights at the lower end are cut through, in a strait direction with the fids. The upper bights are designed for the eyes, and are marked round the middle, beginning at the inner one, with one piece of spun-yarn knotted, two for the second; and so on for the number required. The outer turn is called SWIFTERS; and they are left four or five feet at each end longer than the shrouds, and have an eye spliced in them the circumference of the mast-head. The shrouds, when cut to their length, are got up and stretched thus for worming: at the end of each length is made a bend; one end is passed through a pair of slings, fixed round a post, at the lower end of the house, and the other end through the strap of a treble block, and a fid thrust through each bend. The treble block is connected by its fall to a double block, lashed round a post, at the upper end, thus: The standing part of the fall is fastened to the becket, at the **** of the double block; then reeved through the first sheave of the treble block, then through the first sheave of the double block on the same side, and so on alternately, and the fall carried and attached to the windlass by three or four round turns. The windlass is put in motion by men, with levers, or handspecs, and each length thus stretched, hand-tight.
