John Gummersall
Everything posted by John Gummersall
  1. It has been awhile since I last posted up... What can I say... it is summer and too many other distractions... I have completed a few items. Below is the completed bow and stern sheerstrake planks glued to the now trimmed inner bulkheads. As the instructions indicate as the ceiling planks get to the floor bulkheads they need to be notched. Measure carefully and make the notch (shown in red) as small as possible - Just large enough to cover the floor bulkheads. The planking is 1/16". If the notch it too big or too long it will show as the ceiling planks continue on to the floor planking. In order to get a better gluing base for the ceiling planking below the floor planking note the rectangle piece of wood (shown in black) added to the inside of the outer planking. Earlier pieces were added along side the bulkheads to provide a better gluing, but I felt a little more is needed. The gap between the outer planking and the ceiling planking is very close to 5/32". Just glue 3 - 3/16 pieces of wood together and with minor sanding you have a good base for the ceiling planking below the floor planking. OK,,,,, now is the time where the purists are going to roll their eyes and totally tune me out.... Below shows the bailing well made earlier in the build. It took me several attempts to make it look OK (maybe), but at my skill level, I just can not get it to turn out looking anything that resembles a bailing well. Anyone looking at it will surely ask "what is with the hole in the flooring"? Anyway,,,,, I discovered that this boat was originally built so tight that it just does not leak. It never rains in the boat and waves just never splash over the side. As such,,,, does not need a bailing well. So I removed the bailing well... I just could not get it to my liking,, 🙂 Outer and inner planking complete,,,,, On to staining,,,,, not quite sure what stain I will use at this time.... I keep going back and forth.... Will post again when I have made a decision 🙂
  2. Planking finally complete.... As I first mentioned, this will be a painfully slow log... Especially now that summer is upon us.... Seems lots of outside stuff keep pulling me away from the build. Below is a side shot of the completed outside planking.... Still needs some sanding, but all in all I am pleased.. Not sure why, but in some cases the pencil marks on the side of the planking did not come out even on all planks... Seems a little blotchy,,, Hopefully sanding and stain will cover some of it up. Below is a shot from the bow.... Seems the starboard garboard is a little thicker than the one on the port side. My intention was to taper it as it goes into the bow... Looks like I forgot to tape the starboard garboard. Will get to that later. As you can see, I have moved the shipyard out to our porch. Not as convenient as in the basement, but it is summer, so ship building has moved outside. Now on to the inner planking (ceiling planks)... As with the outer planking, now the inside of the first five bulkheads needs to be trimmed to better accept the ceiling planks.
  3. Again,,,, I appreciate your comment, but back in post #14 I had two planks left to go. I was really unclear on that point. It was then that I noticed that when I got to the final plank the bottom of the hull would need to be trimmed. Anyway, I am not on the final plank and how to complete the planking soon. john
  4. Chuck, I appreciate your comments, I was not really very clear as to my issue. My problem (before the patch) was not so much a shortage of wood. But that would have resulted in a gap under the stem/stern posts (see below) as the planking stops at the stem/stern posts. I really did not want to see that gap... Below is the completed stem post with the 1/32" patch at the bottom. Now both the stem and stern posts (patched stern post listed above) will be able to accept the bottom planking with no gap between where the planking ends and the stem/stern posts.
  5. Rodger, Thanks for your comment,,,, I appreciate it Below shows the completed Stern post after sanding... Now the bottom plank should fit pretty good into the stern post. As for the stem (bow) post, looks like it only needs the additional 1/32" to be added. Below are a couple pictures of the added patch to the stem post. It too will be sanded later to confirm to the stem post.
  6. Not sure why I did not notice this before, but now that I am at the last plank, I noticed that when the bottom of the hull was planked with 1/32" planking, the bottom now extends beyond the stem and stern posts... ugh,,, If I had noticed this at the time, I could have adjusted for the 1/32" when attaching the stem/stern posts to the hull bottom. This now needs to be fixed as the bottom plank will not sit properly with the stem/stern posts. At this point about all I can think of is to extend the stem/stern posts. Actually it looks like I need to add about 1/16" to the stem/stern posts as a patch. Below shows the stern post patch after the initial gluing.... Tomorrow (when the glue is dry) I will trim it to match the stern post. In the end will be hardly noticeable, but if not fixed, the transition of the plank to the stem/stern posts would be very noticeable.
  7. As the saying goes.... "you can never have enough clamps".... Even with my attempt at bending the planking, a little brute force (as in clamps) is always helpful. I find these from Micro Mark really helpful and form a really tight bond to the bulkhead.
  8. Planking going along pretty good. As Chuck and I have mentioned above, the planking is somewhat easy on the Philadelphia. Most of the planks only require a little shaping and bending. I really have liked using Chuck Passaro's planking method. Even with a little bending his method really makes planking easier..... especially for someone like me that has no idea how to do a good job with spiling. Below are a few shots showing planking almost complete. Then on to the sanding to clean up some glue spots and general smoothing out. Noticed a little space in the top sheerstrake ,,,,, Will need to fill that from the inside later on.. While waiting for some of the planks to dry I noticed it will not be a smooth transition from the bottom plank (W+4 strake) to the bottom of the boat. Note when the bottom plank will eventually be applied there is not much edge to glue to Just as you need to trim the foreword/aft bulkhead to accept the strake planks looks like you will also need to trim the hull bottom to provide a better base to glue the bottom strake plank. A few minutes with the Dremel easily takes care of that and will provide a much larger area to glue the bottom strake plank. Does not really need to be perfect, just provide something to glue to.
  9. I agree spiling is not a problem on the Philadelphia. But as I have mentioned earlier, past models have shown to me that I am the "World's Worst Spiler" (if that is a word). Fortunately wood filler, paint, and a lot of sanding makes hides even the world's worst "spiling" job. Having said that, there is some minor bending/twisting of wood on the Philadelphia. I do like Chuck's method of bending wood as very few clamps are required to make the plank lie flat to the bulkheads. My previous planking jobs usually have ended up with more clamps than wood try to get the wood to do unnatural acts to lie flat. Looking forward to my next ship that has thinner planks and more curve/twist to them to see if I will loose my title as "World's Worst Spiler"
  10. Before I take on spiling I thought it best if I give Chuck Passaro's planking Videos one more review. I have seen them before and they looked interesting, but I never really attempted his process. Having gone back over the videos, I now realize this is the way to do planking - for me anyway. I made a very small version of the bending station suggested by Chuck. In Chuck's case it looks like he uses a 2 x 12 board over a couple of saw horses. That seemed a really good setup, but I just did not have that kind of room. Below is my smaller version of a bending station. With the Philadelphia there are not too many planks to bend and each plank is much wider than the planks on most models. This process worked great for me even with the wider planks. I say "even with the wider planks" as the wider planks are much harder to bend. Narrower planks would be much easier to bend. I am looking foreword to trying this process on a future boat with narrower planks, but for now this worked great for me. In the event you are interested, here are the links to Chuck's videos https://www.youtube.com/watch?v=KCWooJ1o3cM&t=7s Part 1 https://www.youtube.com/watch?v=9T5C9rW2JkU Part 2 https://www.youtube.com/watch?v=atXqH0GWLL8 Part 3 https://www.youtube.com/watch?v=Uhwsf4lW6Sc Part 4 As I was waiting for planking to dry I wanted to experiment with blacking brass. Just as many theories on spiling as there are modelers, there are any number of ways to blacken brass - some successful other not so successful. In my case I wanted to try "Novacan Black Patina / for Solder - Lead". I had heard this works pretty well so I wanted to give it a try. Below is the result. I need to keep fiddling with it. In the example below I did not pre-clean them with acetone. Just took the brass and stuck it into the Novacan Black Patina. I was hoping for a more even black. Instead I got a very rusty look. So it defiantly aged the items - like they have been sitting on the bottom of the sea for some time - and that is a look if that is what you are after. Tomorrow I will try with a pre-wash of acetone to see if I get a more even look - We will see,,,, As you can see the above blackening process left the pieces looking pretty rustic. If that is the look you want then OK. In my case I wanted a more even blackening. I attempted diluting the Novacan to 1/2 strength (with water) and ended up with a pretty even blackening with nothing rubbing off. Based on the dilution process, I am really impressed with Novacan for blackening brass. Below are some additional Philadelphia brass etching pieces blackened with Novacan at 1/2 strength.
  11. Been awhile since my last update... As I indicated early on, this will be a painfully slow log... I do not get to work on the model as much as I would like. Seems something else is always tugging for my attention... Anyway, the first three planking rows have been completed.... Pretty straight foreword, just a slow process. Each plank has to be cut to size, soaked, pinned into place, let dry, and then glue into place. Below is my attempt at the first three planking rows Bow Stern Port Side Starboard Side As I was waiting for each plank to dry I decided to plank the decking. As mentioned earlier,,, "why do something easy when you can make it hard". I used 1/32" x 1/2" planking as I did not want to add to much height to the deck. Having said that, additional height does not appear, at this point, to make a difference with the Philadelphia. In hindsight I probably should have used 1/16" x 1/2" planking as 1/32" has a lot more warping to deal with than the 1/16". In addition, others had mentioned that an additional 1/16" of an inch probably is what the original model designer intended and greatly helps with the placement of the canons. In either case, do not forget to weight down the decking after planking it to prevent warping. You will definitely have warped decking if you do not weight them down as the glue dries. Below is the decking after the planking. At this point I just layed the decking in the boat for the picture. In reality, the ceiling planking will be applied before the decking is glued into place. Now on to the (shall we say) fun part - spiling.... I am probably the world's worst spiler.... I have attempted and tried several spiling methods others have used in past models but do not really feel comfortable with any of them. At this point I just to not have the knack for it. I am not sure what the issue is... too old to learn, too new to modeling, or just no talent - pick one..... Once again, we will take it on and see what happens.. 🙂
  12. I agree,,,, really nice job on everything I see,,, Boiler and machinery look really good. You have a far steadier hand than I did... I had a hard time with those small parts... As for you spiling,,,, that looks great too. From the pictures you did a very good job at matching the planks. To me pre-notched lines for planking were more of a guide that the absolute truth... Main thing is to try to match the curve of the previous plank and have as small gap (or no gap) as possible between planks. From what I can see, you have done an excellent job (and better than I do). I will give one word of warning,,,, when it comes to painting the hull, no matter how much you patch and sand, even the smallest seams will show up and appear huge to you after the first prime coat. It is easy to get discouraged after what seems like endless sanding and have a hull that looks really smooth, only to have the paint expose numerous seams. Just keep patching, sanding, and additional coats of paint. Eventually all the seams will be filled and the hull will be smooth. It may take 6-7 coats of paint,,,, but in the end, the hull will smooth and look fantastic.
  13. Cockpit floors have been laid. One issue I noticed on the bailing well is that there is no border to the well to support the lid. The model does not have a lid, but I assume there should have been. The 3/16" board on one side could support one side of the lid, but there is no support for the other side of the lid (marked in green below). I did not catch this until after I laid the cockpit floor. If I was doing this again I would have just cut the flooring plank a litter shorter exposing some of the 3/16" floor support board. However, at this point, not sure If I will just leave it (as that is what the instructions call for) or just add a small piece of wood on the edge to support the bailing well lid. With both cockpit floors completed I added a 1/32" strip of wood over the false keel portion of the cockpit (marked in red) as I assume this will be visible in the completed model. With the age of philosophy saying "you can never have enough clamps", below sits the hull with both port and starboard strips of the sheerplanks, soaked in water, and bent into place. Once dry, tomorrow I will glue them on,,,, and the planking fun will begin.
  14. I am by far no expert on spiling,,,, In fact far from it.. Most of my attempts at spiling have a lot to be desired.... But I have learned this,,,, if you plan to paint the hull, no matter how good or bad your spiling looks,,,, in the end both good spiling and bad spiling all look the same under paint. The better your spiling the less sanding you will have to do, but in the end it all looks the same under paint. Try to keep learning you spiling skills (as I am), but also try not to worry about it as you go. Not worth the worry. Remember, sanding and paint are your friends and your ship will look great in the end. Everyone will marvel at your completed ship and you will look back and wonder why you agonized so much over the spiling.
  15. Completed bulkheads.... In previous posts I mentioned that I had to trim what I would consider an unusual amount off each bulkhead. This seems to have changed. As shown in my last post I started with bulkhead #9 and worked toward the stern. I mentioned I was worried that I had to trim each bulkhead what I would consider an excessive amount (2mm). I was worried I was doing something incorrect but saw no other way. Interesting enough, when I got to bulkheads #1-#8 they all seemed to be the correct length with only minor trimming for them to match the outer edge of the hull. So I guess all is good with the world. In the below picture, all bulkheads have been installed and I have started on the foreword lower cockpit I do not really expect any issues with the foreword and aft lower cockpits... Famous last words.... we will see what trouble I can get myself into...
  16. Following that age old philosophy stating "why do something easy when you can make it hard" I decided to plank the bottom of the hull and the decking in the boat. But for this you need to get some extra wood. I decided to plank the bottom of the hull and the decking with 1/32" x 1/2" wood. In hindsight I think I should have gone with 1/32" x 3/8", but the wood has been ordered... While waiting for the wood to show up I moved on to the cannons. As others have commented both the 9lbs and 12lbs cannons need a lot of cleanup from the molds. Might be time for Model Expo to get a new cannon mold. Anyway, they clean up pretty well after some filing and sanding. When assembling the 9 lbs cannon mounts it says to glue the front and side pieces on the etched lines on the wheels.. Problem is the front piece (shown in green below) is not wide enough. When you glue on the side pieces they do not line up with the etched lines on the wheels. While dry fitting I noticed this but did not give it much thought... Not so good. Problem is, later on, when you lay the cannon in the mount the back part of the cannon will not fit down in the the slot... So the cannon will only shoot straight and be able to shoot up into the air. This might be an issue later on if the cannon potentially could not be high enough to shoot over the rail. I was thinking of breaking down the mount and add a small sliver of wood on both sides of the front piece (to make it wider), but a better thought was just to sand down the two side pieces (shown in red). The required sanding is so small that it is completely unnoticeable. So when building you cannon mount, note if the sides line up on the etched lines and if not, plan to sand down the sides or increase the side of the front piece. Have not built the 12lbs cannon mount yet, but will look out for this potential issue. Final result for the cannons... The do clean up respectable ... Not museum quality but good enough for me. Note the mount for the small cannons in red. The mount from the kit was so bad that is broke even with really delicate handling. Using two eyelets and some thin wire I created a new mount. Once this is mounted on the boat, it will look fine. Planking arrived and bottom planked. I started out thinking I would do the 1,3,5,2,4 or 1,3,2,4 planking pattern, and spent some time in laying out both patterns to see what I like best,,, It ended up being the 1,3,5,2,4 pattern. However after lots of thought and time on the issue I screwed up the pattern on the very first row, but did not realize it until I was on the 2nd row.... So from there I just said "the heck with it" and went for a totally random pattern. Oh well,,,, it is just the bottom and few (only those that peak) will ever see it. If you plank the bottom hull, be sure to put weights on it as the glue dries to prevent warping... I learned that the hard was on a previous model. With bottom planked, stained (golden pecan), and sealed, I started installing the bulkheads. Take time to insure you false keel is straight before you start the bulkheads. As mentioned earlier, I am not sure why my bulkhead pieces were so long. On both sides of the hull they extended about 2mm past the hull. So in addition to beveling the planks with bevel lines I had to trim each 1/2 bulkhead by about 2mm in order for them to line up with the edge of the hull bottom. Not really a big deal, but the fact that every bulkhead was about 2mm long (and other logs only mentioned slight sanding) made me feel a little uncomfortable that something was amiss... Anyway,,, we will see what trouble I get into later on do to this "adjustment". As with planking the bottom, be sure you have weights on the bulkheads as the glue dries,,,, or you will have some warping and a lot of (shall we say) "fun" later on trying to unwarp the hull. - Again,,, ask me how I know this 🙂
  17. Lewes, Thanks for the heads up..... I will keep that in mind when I get to beveling the bulkheads... By the way,,,, is it just me or were your bulkheads a little long too and had to be shortened where they meet the false keel?
  18. Started to dry fit some of the bulkheads on the false keel and noticed that almost every bulkhead (on both sides of the keel) extend beyond the flat bottom of the boat. The bow/stern sections (after beveling) seem like they will be close, but most of the others seem about 2mm long. From what I can tell they are supposed to line up with the edge of the bottom of the boat. Not a big deal as I can easily shave off some of the center joint where it meets the keel, but the fact that almost every bulkhead is too long somewhat concerns me. Like maybe I missed an earlier step an did not build the false keel correctly. Looking at some of the other Philadelphia logs only Brucealanevans mentions adjusting the bulkheads,,, and that seemed only because he mentioned his false keel was not square. Anyway,,, I have gone back over the plans and instructions all seems to be correct. I just I just need to adjust them where they meet the keel so that the outside of the bulkhead lines up with the bottom. Should not be a big deal, but I am concerned I may regret this later in the build.... But do not seem to have a choice.
  19. Just starting up the gunboat Philadelphia build... I just completed the USN Picket and anxious to get started on the Philadelphia. I am by no means an expert builder but having a lot of fun along the way. One word of warning,,,,, this will be a painfully slow log to follow. I know most people hate slow logs. I am not a full time modeler so I only get to work on it when I have some spare time. Hopefully I will be able to have at least one post a week. Maybe more,,, Rather than have a log and shows only the good stuff I plan to bare my dirty laundry and show a lot of "what not to do when building the Philadelphia". I will plan to complete the Philadelphia, but it may get ugly along the way... One item that I am sure is a "no brainer" to more experienced builders, but is worth mentioning... The Philadelphia, like most medium/large models has a lot of wood strips of various sizes. Before you begin, I would suggest you identify each different size of wood strip and label it so you can easily find it later in the build. The wood strips are very similar in size and no sense rummaging through all the word each time to want a particular size. Below is my attempt at labeling each strip size. Does not matter how you label them, but you will save yourself a lot of grief in the build if you can easily identify each strip as you need it. Starting right in,,,,, The instructions call to build the false keep, glue the stem and stern posts to it, and then trim the stem and stern posts. I guess right away I am altering from the instructions,,, Hope this is not an omen for the future,,,, To me it is much easier to build the stem and stern posts, trim them, and then attach them to the false keel. Not sure if I will get in trouble later on or not, but one thing I did do when beveling the stem/stern posts for the rabbets was to trim them more than the suggested trim lines. In the past when I have trimmed the stem/stern posts to the suggested lines, it is never enough to accept the planking, and when planking I had to shave the ends of the planks to fit into the rabbets. This time I choose to bevel the stem/stern posts enough to accept the end of the planks that will eventually be inserted. Like I say, have never done this before and later on in the build I may regret it, but it has been done. Here is the result of the stem and stern post builds. Stem Post Stern Post Then building the false keel there are three cross pieces to provide support and help verify the keel is plumb when glued to be bottom of the hull. I do not have a couple machine angle plates to help insure the cross pieces (and later on bulkheads) are square... So you use what you have. In this case some angle braces. Worked well for these cross pieces, but looking at the bulkheads, I can see some (shall we say) "fun" ahead trying to get the bulkheads square. In the past I have had issues getting bulkheads square when each bulkhead was one piece, but in the case of the Philadelphia most of the bulkheads are two pieces. Doubly hard to get square.... and if the bulkheads are not square, you are in for all sorts of issues down the line - ask me how I know this 🙂 Let's just say I plan to pick up a couple machine angle plates prior to taking on the bulkheads Laying out the bottom of the boat pretty straight foreword. Glue the three pieces together and you are done. Just insure you have a very flat table and while the glue is drying, put some weight on it to prevent warping. Below is the completed keel (with stem/stern plates attached) and the bottom of the boat. One note, the bottom section of the boat is 608mm long, but the false keel is 610mm long. Not a big deal, and I probably could have left the overhang, but just to be safe I shortened the false keel by 2mm before gluing on the stern post. Was not sure that 2mm gap would have made a difference when planking, but did not want to take a chance and easy to correct. Verify you false keep fits the bottom of the boat before gluing. Below is a picture of the stern post after gluing to the false keel. The stem post connection to the false keel was really sloppy. Not a good fit at all. Below (in red square) I glued a small piece of wood on each side of the false keep where it meets the stern post - just to insure a good bond
  20. I agree,,, off to a good start.... I just completed my Picket build, but you are incorrect. The Picket collection of models already had an amateurish version - Mine 🙂
  21. Seems OK To Me.... The stain is just Rust-oleum Weathered Grey. However, rather apply it like most stain where you brush it on and then wipe it off to get the look you want... I just brushed it on like paint and did not wipe any off. In effect it is like a grey paint..
  22. Thanks for all the comments..... I am still have a lot to learn,,,, but having fun during the process...
  23. I decided to skip the blocks in the kit and order some from Syren. They are much more realistic and have to be assembled. In my case I ordered double blocks. They come with five sheets that must be glued together to form six full double blocks. Instructions makes several references to carefully align the five sheets that form each block before glueing. In reality the five sheets all go together very easily and align perfectly. In fact they aligned so easily, I thought I was not doing it correctly. As I played with the sheets trying to see if there was some other way of lining them up, I realized the pieces on these sheets break off very easily - Ask me how I know that .... 🙂 Four of the six blocks had all the pieces and glued together nicely. The other two blocks I had to piece together to glue. The picture below does not show how really small some of the pieces on the first and last sheet (shown below) really are. So small, just the friction of the tweezers picking them up would make them stick to the tweezers. Save yourself a lot of time and grief and treat the sheets gently.... Gluing the blocks together from the sheets is much easier than having to build them by hand. Once the blocks dry, they can easily be broken out of the sheets, sanded and ready for stain. As with most things, the more you do them the better you get at it. While the finished blocks below look better than the stock ones, they could be better. Lack of skill on my part. My next set of blocks will be better At this point the hull has it's final paint coat and all machinery has been completed. All the remains is to assemble them. Starting in the bow with the Howitzer.. For raising/lowering the canon, the instructions called to wrap a 1/16 tube with thread to simulate screw threads. Instead I opted to just us an actual screw. Cut off the head to leave just the thread. To me it just looks more like screw thread. In hindsight, the hand crank (to turn the screw) probably should have been left brass or maybe painted silver to more stand out. As it is (black), it is kind of hard to see or really know what it is. One challenge was creating the two large wing nuts used to anchor the canon. Instructions call to cut a slit in the 3/32 tubing and insert the wing. Initially I was going to skip that part as I felt, no way was I going to be able to cut a slit in a 3/32 tube. But I gave it a shot and with a razor saw was actually able to make the slit. Not sure it did the very find teeth on the saw much good, but I was able to cut the slot and form the wing nuts. Similar issue when creating the three attach points for the canon. Here a hole must be drilled through the 3/32 tubing and a pin inserted. With a vise and a steady hand the hole was drilled. When drilling the hole, once you have gone through the first layer of tube, stop and re-align the bit to insure you will be drilling directly through the other side of the tube. If not, it is easy to get out of align when the drill comes out the other side of the tube. Again - ask me how I know that 🙂 In the below picture you can see four of the six blocks in action - used to move the canon back and forth on the deck. The hooks were just made out of eyelets and the blocks were stropped with very fine line. As you can see,,,, my stropping skills need a lot of improvement. Below shows those canon lines coming from the blocks to a couple cleats below the deck. Whatever army guy ordered the line for those blocks had no clue really went overboard. Those lines probably should go over the deck by maybe 6 feet or so... As you can see there is probably about 20 feet of line from the blocks coiled on those two cleats . A little more line than needed 🙂 Here are a few more pictures of the front section,,, Moving to the mid-section of the boat we have the machinery. Not really much here. Since the machinery has been assembled, all that remains is to insert them into the hull. I will say,,, in the philosophy of "do as I say and not as I do".... I did have some (shall we say) "fun" with the machinery. In my case I wanted all the piping that was intended to go through the deck, to actually go through the deck. To me that just looked better then having the pipes just stop at the deck. Thinking I had a good idea, I cut the vertical pipes (the one that were to go through the deck), longer than need be and glue them into the upper pipe. My thought was that then I could then just hold the piece machinery where it was supposed to go, mark the deck, drill the hole, and then lower the machinery and the pipe would go into the deck. In reality it did not work out so well. Holding the piece of machinery, it is very difficult to mark the exact spot in the deck for the pipe. Off by the tiniest bit and the machinery will be out of place. Put the machinery in the correct spot, and if the hole is not exact, the pipe is not vertical. Even if the pipe is only out of vertical by a tiny about, it is real obvious - Again,,, ask me how I know this. It took me way more time trying to get the machinery and pipes straight than I am sure it was supposed to. I think a better approach would have been to put the machinery in place and then measure/cut and glued in the vertical pipes. In the case of the rudder, I wanted a curved rudder. Using the two rudder pieces supplied I was able to make a curved rudder, but to me it was just too skinny. Perhaps it was do again to lack of skill on the builder (me)... Using my skinny rudder has a template I used a couple pieces of spare wood and made a thicker rudder. To me it looked better,,, some may disagree. In regards to the torpedo I had a few cleats left over, so rather than take several lines to one cleat I dedicated a cleat to each line. This time the army guy in charge of lines got it a little more accurate (or at least he thinks so). The forward and aft lines and firing pin lines need to have extra line in order to be able to launch and trigger the torpedo. Those three lines go to their respective cleats and the remaining line is coiled on the bench. The torpedo release pin line is only used to release the pin, so not a lot of extra line would be required. As such this line goes around a cleat with the remainder just hanging in the boat At this point "I am calling it",,,,, To me I am done..... Below are a couple more pictures,, And it her final home....
  24. Fittings on boiler complete. All other machinery complete too... Next step will be inserting the machinery into the hull.
