woodartist
NRG Member-
Everything posted by woodartist
For those who have built your kits, and considering the time, effort, and expense of building a quality ship, they will not be seduced into buying an inferior kit. Those that do so will notice what could have been and that is a horrible realization. Been there done that, will not repeat the mistake!!
I whole agree. I bought 2 pairs and with the second pair I filed the v a little deeper to accept larger pins.
- 43 replies
- Lady Isabella
- zulu
Importing files into Delftship
woodartist replied to woodartist's topic in CAD and 3D Modelling/Drafting Plans with Software
the pdf files really help.Thanks so much, I will figure this out somehow. -
I have never used a cad program before for starts, however I have downloaded the free version of the software, I am trying to import plans. I have the same plans in jpeg, bmp, and tif files. I would like to learn how to use the software but can not find a basic tutorial to get started. I thought that if if loaded in some boat plans that I have that it would be a place to start. But when i try to load the plans into the app it appears that Delftship only recognize fbm or bak files. How can i proceed? Is there a basic tutorial online?
woodartist replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Thanks, I am sure you are correct -
I was referring to a post you made on 9/23 #26 that shows a photo of the gun deck hatches. I got the Proxxon mill you recommended and was starting to make hatches with it so I was looking at your early posts when you described the process. -
The grating at the bow in blue is proud of the frame, all the rest are flush with the frame? Is that intentional? -
Fiskars cutters are available from Amazon, they have a cutter that will cut 30 sheet thickness of paper for $60 and one that will cut 12 sheets of paper thickness $22 -
Work area pictures only
woodartist replied to Johnny Mike's topic in Modeling tools and Workshop Equipment
i have a small 10x10 workshop in my back yard. I used to do a lot of wood carving and taught small classes in my shop. Now it is my boatyard. -
thanks I will research further on the machines, software and 3D forum
Is anyone using a lazer cutter to make parts? What equipment are you using? What software are you using? Any recommendations?
Johnny I had an accident and lost use of my right arm bicep. I can still move my right hand but it is stiff and does not have a lot of flexibility. I use my left hand as my primary hand now because I can not raise my right arm without assistance from my left arm. So I am incredibly slow in moving and each move has to be planned in advance. I use a 3rd and 4th hand a lot, I use reverse tweezers a lot to hold things, I use super glue much less often because it takes awhile to get pieces situated. I use a white glue that can be released with alcohol as well. Mainly it is just realizing that I have limitations and plan accordingly. Can I be as good as those with two good hands, NO, but I can still do quality work and enjoy the process. I do 1/48 scale but no longer try to do 1/64 or higher. I also do admiralty models because rigging is not possible with my limitations. I still have great fun.
I would love to start on this when you are ready. It looks awesome. Have you considered fully planking one side of the hull?
