Everything posted by Mirabell61
many thanks for looking in Craig, the superstructure details will have to be developed as I get to the appropriate sequences, I have an Idea though.... The masts will be tapered soldered and from brass tube material Nils
- 330 replies
Thanks for that link with the etch primer Mike, I`ll keep an eye open on that Nils
- 330 replies
many thanks Gary, The plating is almost complete, I`m putting on the last few on the port side upper bulwark tomorrow and am pleased that my aluminium foil roll did last. I have as an alternative tried out a special bonding primer spray for shiny aluminium surfaces and the results are quite satisfying so far. It usually would have been zinc-cromate primer like the aircraft industry had in use, but that is toxic and as far as I know its not being distributed any more. The next pics will be with the painted Hull in a few days Nils
- 330 replies
Many thanks for you`re compliment John.... I just came from the copy shop and placed an order for the shipnames and homeport (aft rounding and forecastle sides). The lady said it would be best to print in white on black self adhesive foil. See what comes out when finished... The pics are showing the cutting of the 30 x 50 mm plating pannels with the paper table-guillotine, while the siliconed paper protection foil is still on. The gluefilm is acetat and it sticks like hell. A tool is actually required to remove the plating again Nils
- 330 replies
many thanks Phil, I would be pleased to see other metal plated model ships at the forum. I wish you much fun and success with your projects in planing Nils
- 330 replies
Update getting along with the plating job. My worries have calmed down, looks like there will still be enough foil on the roll Nils the waterline is marked again here, to be seen for Andy, the bottom is nearly flat
- 330 replies
Thank you very much Andy and John, The more feedback I get, the more I learn about these old steamers... Andy yes you`re right, I was too fixed on the centerkeel of the Ferris type ships (where I have the frameplan from). The aspect of less draft without that keel allowing increased tonnage load makes sense. I can imagine there is a slight disadvantage without a keel standing out for lateral less corse holding reason. I decided to leave the version I have as is, but shall allways carry the "Andy-Version" in mind for the future Keep these good comments of yours coming in, they are much appreciated. John Thanks very much for your comparison scetches of bar- and flat keels, this rounds up the design versions very well Nils
- 330 replies
Andy, many thanks for your comment.... I appreciate very much that you know so much of the design of these lakers. I`m not sure if I understood you right there, do you mean the ships bottom along the keelline should be flat, and flush with the hull skin ? The keel in centerline is in the moment only standing out about 1,5 mm, wich I would`t mind about. Bilge keels and center keel are horizontal at the same level. Nils
- 330 replies
Update I started with the metal plating today.... It will take a few days and my 0,125 mm thick self adhersive aluminium foil roll is coming to the end. lets see how far I get with it... Nils
- 330 replies
Many thanks for your comments B.E. and John, B.E. the idias for solving some of the tricky sequences come with the progress.... John Yes you`re right, I do`nt know either, as I have no pic on this detail from the movie. Thanks for your detail showing the make / function of the compression stoppers. Great input, I`ll save this for another ocasion and they shoud`nt be difficult to make in brass or so, even the swivel handle and the locking pin
- 330 replies
Update this is the template for the aft rounding. I also started with the stairs for the three islands... Nils I have to find out if the copy shop is able to print the name lettering onto transparent self adhesive foil in white letters, so that cut out names names can be brought on the black hull
- 330 replies
I love this build ! A beautiful rigid lightweight POF design mate. A true boatbuilder skill is showing here. The lines are very impressing, and your measures to make her watertight for radio controlled sailing are wonderful, well done. Nils
Update I`m working on the anchor gear, today I made one of the two workable mini chain stoppers, the anchor tubes at the forcastle, and the anchor fairleads Nils for documentation (all decks) where the frames and supporting structure are situated I attched a scale before mounting the closed decks the anchors are from cast metal, one can see where I plugged off hole in the skin made by an error the anchor fairleads are from brass-coated steel forecastle deck outlet of the anchorchain tubes the raw forecastle deck is on one of the two chain-stoppers
- 330 replies
Wunderbar ! great work Peter, I also like the sewing of your sails, welldone, a very fine model Nils
- 208 replies
- kitbashing
- Woodcarving
(and 4 more)
Cap San Diego by mikegr - 1/160
Mirabell61 replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
Very nice work indeed Mike, I love the design of the Cap San.. ships of the Hamburg Süd line, I have myself worked for Blohm & Voss in early work days. You`ve managed to get those elegant lines transfered onto your model. Nils -
- 330 replies
Many thanks Peter and John, Peter, good to hear that you are back on track, keep the pics coming..., I remember when once my chebec, in build stage, fell off the table and right onto the bow sprit. The sprit could be shafted and the rails replaced, nothing to be seen of the broken parts any more. John, yes I dicovered those winches from a Hamburg based web shop, and also found they need a little deburring and cleaning up, in generel they have a good cast quality. I have an idea what the poop bulkhead face covers will look like. The color is "desert sand". The door bulleyes ar slightly smaller in diameter and the silicone "glassing" worke well Nils
- 330 replies
Many thanks Peter, I`m pleased to hear from you again, hope you are well. hows your Bellerophon getting along to date...., or did you interrupt the build ? Nils
- 330 replies
Hi Andy, thanks for your kind comment ....... I am continuing with the vertical panels to the bulkheads for poop, forecastle and middle island. Here starting with the doors. Each door gets a bulleye. Also the aft bumper rail is mounted and I`m preliminary positioning some of the load geer winches in dry fit. Also the rudder has been plated. Unfortunately I have no building plan for all the super structure, and so I have to download lot of stand pics from the Sea Chase movie and to evaluate how things fit together. The hull itself I adopted from the Ferris type wooden Steamer, just about the same rating and tonnage as the Ergenstrasse aka the Corsicana Laker Nils I found these nice steam driven winches in scale 1:100, I wo`nt build them again myself like I did for the Heinrich Kayser model. They come in size to match for 1:87 scale as well The 4 bulwarks are fitted the rudder is plated these will be the first doors. The low cost bulleyes are made from hollow rivets and the "glassing" is made from 3mm round extruded silicone sealer
- 330 replies
Thank you Gary, most self adhesive aluminium foil (used on ductwork, etc.) is too thin for good results. For poncing the best results were with 0,125 mm thickness. Nils
- 330 replies
