Mirabell61
Everything posted by Mirabell61
  1. A beautiful Model Daniel, congrats, well done Nils
  2. congratulations to the excellent scratch-build completion of your ship Svein Erik, I like the rivet plating giving that special nostalgik appeal, well done !! Nils
  3. Thank you Stephane, for your words, I have a great problem in finding additional display space in my home. For instance the #5 Elbe schooner will have no own case, and will have to share the case of the Zeesboot from time to time, as both models (one at a time) can fit in it. As this is an English speaking forum, please would it be possible for you to correspond in english rather that in French language, so that other members can also follow, thank you regards Nils
  4. Hi Rob, I used 4 mm thick glass panes for all my 9 display cases to date. It is a bit tricky in preventing the panes to tilt during assembly, before the frame can secure, but meantime I gained some experience in handling that quite well. The handicap is that the glass cases are rather heavy, and I finaly need two helping hands from my wife to put and lower down the glass bonnet over the model and on to the case base-plate. Nils
  5. Peter, many thanks for kind words, much appriciated. I was looking for how to issue an album all the time and finaly solved it. So not only the #5 Elbe Pilot Schoner but also the Zeesboot got their own album. I hope that I do`nt forget again how I did it Nils
  6. Gary, thank you for your kind words, much appreciated, and I´m very pleased that you like the boat.... Nils
  7. Many thanks Keith, it is already displayed in my little private museum together with 8 other models... The Gorch Fock model had (in lack of place) to be moved upstairs to my attic office Nils
  8. The casing the casing is now finished the model set inside and this closes the build log Nils
  9. thank you for following the build Johann, I`m pleased you like it. The case for the model is nearly finished
  10. Here some pics of the case building progress.... As my recent 5 Elbe provides nearly the same length and height as the Zeesboot, this case will alternatively suit both models well Nils Glass panes ready for being fitted all corners will be reinforced with brass fittings the bottom frame corners are fitted with ply corners the mid frame gets supports as well. The brass pins fit into all six sleeve sockets to seccure for no movement of the bonnet Zeesboot trial fit standing on the base also the 5 Elbe model will fit into the case this is what the case is actualy made for
  11. Many thanks Keith, I`ve just started to make the glass casing..... Nils it satrts with the base plate and the sides profile the glasser did a good job, the cuts are very precise and the edges well debured the last side to be fitted I saw this little side table offered by Aldi this week. The glass case will stand on it later on
  12. Hi Ian, thank you very much, I`m really happy with your nice comment.... Nils
  13. Many thanks Dave for your kind words. The model will be on display in a self made glass case, I`ll see the glasser`s shop tomorrow for the glass panes. Material for the wooden framing is already here. Nils
