Mirabell61
Everything posted by Mirabell61
  1. Many thanks Geert and Bruce, Geert, it realy seems to work... , there will be a sectional bulkhead in combination with the two first half-frames I`m working on this monent. Behind it the main mast will be situated, and in front of that bulkhead the cabin fits in, with entry from above Bruce, I`m pleased that you are enjoying the build. The little one is so sweet, he`s laying at my feet at the desk in my hobby room, although he still "leaks", sometimes also on the carpet, if we`re not fast enough to recognise what he has in mind. Nils
  2. Next sequence is doing the framing ribs.... need to make some well fitting templates fist, that adopt to the inner lapstrake contour Nils flexible ruler is of great help fot this job A flexible ruler to take off the rough shape for transfering it to card card for taking off the clinker stagered strake outcuts doing it in a bit of 4mm thick scrap wood provides the template for the final ribs I must admit, its a bit tricky job.....
  3. hello Tim, I liked your introduction, wish you a pleasant stay with MSW, and look forward to your first buildlog here... Nils
  4. Thanks for your welcoming words B.E. we`re just back in from a walk in the park not far from the house... Caspar and Nils
  5. Thank you very much for your kind words Keith and Mark much appreciated... Nils
  6. Thank you Geert, yes, he`s a real clever little chap, but it takes much attension at this stage of age to help in learning and during discovering new impressions daily... Nils
  7. Hi Peta, excellent work ! its a real beauty, and the progress is lovely to follow, what a nice pricise planking !... Nils
  8. New family member, after our Ronny (Foxterrier) passed away 7 months ago, due to a stroke from which he unfortunately could`nt recover, we did`nt want to have a new dog again. To make it short, the decision did not last long, we missed the house being without any four legged pal...... Here now is our new two months old darling "Caspar", (rough haired Dachshund), puppy pet, since last Saturday, and picked up in southern Germay. There is much life and joy in the house again Nils
  9. Thanks to all the "Likes" The centerboard case is ready for attaching now, a few ribs will be added later on, when it is integrated into deck timbers and to bulkhead with stffening out knees (front side) Nils
  10. John, thanks very much for your nice words, I`m pleased you like the boat... Nils
  11. Hi Peta, the design/construction of the Avos kit model looks realy professional thought through, great work, this is a wonderful basis for a super model... Nils
  12. many thanks to Antony, I`m pleased you like this clinker hull, I am myself happy with the first hull planking over a plug and for using pear wood instead of pine wood, except for those small ships boats made for HMS Pegasus and for the Chebec Nils
  13. Thank you Steve for looking in, and for your kind words.... yes, its one piece of 0,3 mm thick brass sheet. I cut it out by laying a part of the sheet on a scrap bit of 4 mm plywood, dilling a small hole through Brass and ply, and then cutting out the center part with a jig saw. This way the brass had adequate support from beneath and it stayed relatively flat as well Nils
  14. Next is the swivible centerboard... Nils template reinforcement frame board lowered down to max. extent board raised inside
  15. Super build Javier, it must be fun doing these mini-models in this way. I lke the deck curvature in this case, very realistic Nils
  16. perhaps they have unequal long legs Keith, but a bad Habit it is indeed... Nils
  17. I agree Martin, he had a hard life up to now, so he`ll just make the best out of it, and visit the nearby finess studio regularly, they also do neck-massages there... .😏 Nils
  18. Ab and Wefalk, thanks to both of you,.... the pros and cons (PVA vs. Epoxy) must carefuly be considered, I`ll try and gain more experience from my side Nils
  19. thank you Geert, I also used a wet cloth for wiping off surplus glue before it cured on the wood. The point is that the "stains" appeear when liquid wood primer is applied to the areas, even there where one thought that they had been removed........ Here is a little removable jig to hold down the rudder from pushing up from the stern hinges In the small baltic shipyard two "Zeesener"fishermen are just inspecting their new boat being built Nils preventer bracket (removable) father fisherman..., with the new ordered boat in build... together with his son, next generation, who will be the new skipper both in scale "G" 1:24
  20. Thanks Ab, yes, you`re right, I also experienced stains on the wood due to use of white glue. I`m still intending to check with every visible plank (outside) to remove the stains by sanding carefuly. I tried to avoid larger stains by using the white glue sparsely and also because the horizontal overlapping lines will be nailed and quench locked from the inside hull, but that will be done after the inside framework is put in place Nils
