Posts posted by Gaffrig
The build continues..
I've glued on all the bulkheads, one at a time using a square and clamps while the grue sets.
I'm using gorilla woodglue for this.
Everything seems square and true so far!
While waiting for the glue to dry, I've started to prepare the deck materials as the deck is the next step in the build.
These materials are 0,5 x 4 mm and I clamped 8-10 pieces together, gave them a light sanding and marked the edges with a charcoal pencil to simulate caulking.
I also started to prepare the gun carriages. These are to plywood pieces glued together without wheels.
Then I prepared the guns, which are metal castings that needed some filing of burrs and marks from the casting. I also gave them a little bigger bore as I think the original bore seemed a little small. So they are all ready for painting. Le Renard has ten guns.
When all the bulkheads had been glued, I sanded the top of the bulkheads along the sheerline of the boat to get a good surface for the plywood subdeck.
Especially the transom needed a lot of sanding to take the plywood deck.
Then I hit my first snag. The plywood subdeck has a notch that fits over a tab in the keelpiece in the stern. All well in that end...
The keelpiece also have a tab in the bow end, but the deck has no notch. In the instructions there is no tab on the bow... 🤔
So what to do?
First I thought I'll just remove the tab, but when my little brain had started working (this took awhile.. 😵) I decided to cut a new notch in the deck, as this would help me keep the deck in position while gluing and clamping. (for some reason I don't have a picture of this)
This worked fine and I glued the deck in place with the gorilla woodglue and kept it in place with rubberbands. and a couple of pins, making sure that the deck was pressed down on the bulkheads all the way.
So when the glue dries I'm ready for laying the deck.
Hope you all get a nice modeling weekend!
Gaffrig.
- JpR62, yvesvidal, Edwardkenway and 7 others
10
Hello to all.
This is my first attempt at a build log for my current project.
This will be my third build, the first is the Bluenose by Billing Boats which is currently waiting for deck materials.
My second build was the Hannah ship in a bottle which is finished.
So while waiting for the Bluenose deck, I have started on Le Renard.
So, here we go!
First a picture of the box.
And it's contents..
Everything looks very good, no warped or cracked parts, and everything was well packaged.
The instructions looks great, one for the hull and one for the rig. There is no fullsize plan though.
So I started at page one, and that is with the basic hull skeleton assembly.
First I removed all the bulkheads and keel from their cutouts(?) and sanded off the little points that hold them.
One of the bulkheads had a little fault from the production of the plywood sheet itself.
I'll fill this with a thin piece of wood and glue..
Then dryfitting of all the parts, all the slots were a little loose, so the bulkheads will need clamping with a square while the glue dries.
As seen here the bulkheads lean left and right due to the loose fit.
At least the loose fit will give room for glue.
Everything seems to fit together, and it looks kinda like in the instructions, so time to open the glue bottle.
Don't you just love that new glue bottle all clean and shiny, and say to yourself, "this time I'm gonna keep it clean and the tip nice and open"
Yeah, at least I know how long that's gonna last..😁
First bulkhead glued in, all square and true!
Not a whole lot done, but I think it's a good start!
Stay safe out there and enjoy your models!
Gaffrig
- Edwardkenway, yvesvidal, Dutchman and 11 others
14
Hello to all, and thank you for all the welcomes.
I haven’t been taking much pictures of the Bluenose or the Hannah, but I’ll post some pictures of them when finished.
I think I’ll start a log for the Le Renard though.
Therapy for shipaholics might be just the right thing for me, you may very well get a new patient soon!🤒
Hello.
I started building the Bluenose, kit from billing boats i february and searching for something online I stumbled upon this site!
What a great forum and what amazingly much experience and info there is to find here!
I registered back in march sometime and have been lurking around until now.
I used to build RC model airplanes from balsa and plywood when I was a kid/teenager. Also plastic static models like airfix kits.
I built a boat called Artur by Igra which was plank on bulkhead that I rigged with RC when I was around 13-14 years.
So starting modeling again now some 25 years later I see myself as a complete beginner.
I live on an island on the west coast of Norway.
The Bluenose build was coming along well, but I didn’t wanna use the supplied mahogany for the deck, and I have been waiting for weeks for limewood strips to arrive in the mail.
So in the meantime I started a second build... Maybe not the smartest but I finished it yesterday! The ship in a bottle kit hannah by amati.
Still waiting for the deck, I started a third build... (this stuff is really addictive, maybe its the glue?) The le Renard by Artesania Latina that I bought at a discount.
This is just started and I’m thinking of starting a build log for this.
Anyway, this was a littlebit about me,
looking forward to be using this site in the future.
Good modeling to all!
HM Cutter Lady Nelson by StuC - Amati/Victory Models - 1/64
Hello.
I am also new to the forum and I follow your build with great interest as I am building Le Renard which is very similar.
It is interesting to see that a big difference in the kit construction is that my bulkheads don't have any tabs to support the plywood bulwarks while gluing these on.
It will be interesting to see ho that goes.
Your work looks great and I'm looking forward to see the model come together.
Gaffrig.
