Egilman
Everything posted by Egilman
  1. No your not!!! The admiral issues orders, the swab jocky's heave too... You got one guess as to who the swab jocky is around here... So's I remind her from time to time as to who actually built the place, at that point, she reminds me of who actually runs it.... I'm a husband I can't win for losing.... (and they need a women's march cause they are so abused and downtrodden)
  2. That silver plastic does look remarkably like aluminium...... (I don't think it is painted yet)
  3. Yep the Soviets at that time were pretty good at building crates with wings and getting them to fly.... Your replication of the look Dennis is superbe..... (particularly that weathered swamp water green paint, great stuff) Looking good!
  4. Small update for today, Almost ready for Mr Surfacer and primer... And the undersides... The front landing gear doors are only tacked on with canopy glue and I'm leaving the main gear doors off, there is too much surgery I would have to do with them to get them to sit flush so I'll do those separate from the fuselage.... The Radome gets painted Aircraft Grey with a black anti glare panel matched to the canopy line so it doesn't need to be mounted right now... as well as the wing tanks and horizontal live tail which will get the BMF treatment as well.... Onwards.... And thank you for all the likes and reparte' It's appreciated.... EG
  5. Well, he would need enough to clear the corn at the end....
  6. Wiggly worms on hooks is not my idea of a gourmet meal.... QUACK, Quack, quack, quack, quack, quack................ It's too late anyway I've already glued the wings....
  7. Ok I"m fickle... I've changed my mind, I'm not going to cut the flaps out and I"m going to close the speed brakes, that is the natural way it would be sitting on the ramp. And that is how it would be sitting on my shelf..... I have yet to see an action pic with the doors open and the flaps not lowered. what I found is that unlike some other kits where you can just cut them out and reglue, there is a LOT more work to getting it to look right. The flaps are hinged within the wing trailing edge, which means that no gap shows when they are down. So that means not only cutting them off, relieving the trailing edge and changing the leading edge so the flap fits within the wing yet holds it's rotational position. With no gaps..... A lot more than I'm willing to put into this build at the current time. Like I've said before, I can easily create myself a lot more work... Not this time already enough on my plate here.... EG
  8. Thanks Nick, Thanks Carl, Right off the bat, that settles it for me... besides I can use the wings as handles when doing the very delicate metal powders...... I can see the high spots on the wing where they contact the fuselage so that will be my first step getting them to conform as much as possible... As far as the rest of the details the dropped flaps and extended speed brakes, I think I'm going to cut out the flaps and drop them as it looks better and is the look shown in the episode, which also means the brakes will be open... Otherwise it will look a bit plain.... Anyway, thank you gentlemen.... the course is now set... EG
  9. I think it's a very smart move to keep the pie cooler next to a guard tower...... (even the barbarians knew where the good stuff was)
  10. Next decision... Wings.. Not a whole lot of wing there. there is some small gaps between the fuselage and wings, I"m debating on whether to glue the wings on now and mask them off for painting, this will allow me to fill the gaps with Mr Surfacer. Or, leave them off and deal with the gaps after painting.... The wings get painted pure white top and bottom on this bird.... (most standard USAF F-104's had whit wings on top and aircraft grey on the bottom, but for a short period they were white top and bottom... Another question, when running and approaching take off or after landing, the flaps are always down, 45 degrees and at take off the slats are down 45 degrees also.... But when at rest on the tarmac they are both at zero.... (and locked that way) same thing with the airbrake panels, after landing they are out, when parked they are retracted..... Any suggestions? the video of Blue Jay Four shows the aircraft moving on the ground with the brake panels extended. (which is a discontinuity in the episode, if the aircraft is being scrambled they wouldn't be extended, I don't think too many people knew the difference) EG
  11. Thanks Ken, the three pics I got are of museum aircraft so that section is cleaned up quite a bit. (you can easily see the dust layer inside the AB chambers) The inflight pics I have all show it as black like the engine nozzle.... So what I think I"m going to do is color it the same as the engine nozzle... it is seeable but is not a huge noticeable feature
  12. Absolutely agree on the Liquitex High Gloss Varnish. It's intended as a long term preservative for finely painted artwork so it doesn't get damaged when on display...... It goes on with a soft sable brush used gently to avoid air bubbles and dries in a couple of hours to a hard shell finish that is absolutely clear. (and doesn't effect the underlying paint, that why it used for serious artwork) It didn't effect the metal powder finish I applied to my test piece. (absolutely clean hands, freshly washed clean hands, leave fingerprints from skin oils on that metal powder finish, if it doesn't effect that it won't effect anything) I understand that it is a perfect surface for decal placement as well..... (but I haven't gotten that far yet) Thanks Ken..... EG
  13. Are they really truly rubber, or vinyl? If they are rubber scrub them up with a toothbrush under running water...... If they are vinyl I would suggest denatured alcohol with a light scrubbing.....
  14. Today's update before a trip to the doc.... (nothing major) Well getting the fuselage ready for paint I noticed something with the tail.... The base of the tail above the engine... It doesn't look like that in real life I can tell you.... Something we gotta fix...... It will show.... Clamping in a piece of .010 plastic card to cover the hole... Glued in and rough shaped..... Sanded smooth.... Done, no more unsightly hole in the tail...... Little things like this, you would think that even for a 40+ year old kit, that was considered the top of the art when it was produced would get something this simple...... Any way getting closer to paint and finishing... EG
  15. Fingers crossed, If there is a way to screw it up I will find it... (trust me)
  16. Very Nice! Working those is an art form... an adventure in photo etch.... I have their Eiffel Tower which I acquired on a trip to Newport Oregon back in the late 90's. they were known as Iconx then... I still have it, unbuilt, it intimidates me too much.....
  17. Thanks Carl, I tried real hard to make it clear for all to see... and show the steps... Now I just have to do it for real....
  18. Absolutely agree with Lou on both sentiments, fantastic cockpits and YES on the Future for the canopies.... don't brush it, dip them....
  19. For the time being brother, at least until I have another problem to resolve.... {chuckle, besides I'm crazy enough already I don't need any more practice}
  20. A little out of my wheelhouse, but I'll not miss this.... Pullin up an easy chair...
  21. So, Getting on with the build.... I've fitted the tail and am now starting on fitting all the various panels with canopy glue so when I paint this I get even coverage.... Fuselage laid out.... EG
  22. Ok now, final test, Sealing the metal finish off... First up the gloss blue I pulled the cross tape so you can see the original base paint coat.... And the coloration and sheen are the same, no real perceivable difference.... Gloss Black base... Oh Yeah! the sheen and reflectiveness is still there Yay! Flat Light Grey... I'm loving this, perfect! Flat Black... Yep. the Liquitex clear varnish does not change the coloration...nor the depth..... I have a few more shots like before to see if we still have the depth in the shine... YES! Now I"m pumped, It Works.... Even the flat base sheen is there!... That perfect coloration for the aft steel panels... This came out a lot better than I thought it was going to... You've all heard that some things are too good to believe? well for me this was one of them. But, it turns out that it was true... You can put a polished metal finish on plastic without an expensive airbrush..... There you go my friends.... Experiment over... Next up finishing prepping the fuselage for paint...... Gloss Black EG
  23. Oh yes, all the high quality kits have that now and many of the AM manufacturers are now including weld seams for kits that don't have them... Modeling has come a long way.....
