Jeff59
Posts posted by Jeff59
  1. The bridge wing deck requires plastic details removed top and bottom. My sequence was to stain the wooden decking for this and the bridge roof, then clue to plastic parts using white glue. Followed by masking of the decking, I then fitted the handrails then painted them, carefully removing masking once paint was dry. Incidentally I did alter the position of the upper bridge forward by about 2mm, seems to be this way on actual ship at mueseum. My best guess anyway.
  2. It takes a while to get round all the detailing and painting them separately before fitting, I did purchase a second Pontos set to get the necessary parts I wanted, I know this is over the top but there’s no way of producing the 1902 version without the necessary parts, it would be great if Pontos could do an additional set to help if the markets out there. 👍
  3. Hello again, Yip it’s that time of life, time for an update. I remember this part of build being quite busy to say the least and knew it would take a while. Starting with the lower bridge super structure following Pontos instructions removed unwanted surface details using electric chisel and my craft knife with curved blade, then start fitting the etch details, following the sequence in instructions works easy enough. Just added some extra details, pipes and jibes, cable drums, it all helps to bring the model to life.
  4. Well that’s it for now, shall need to start work on forward bridge structure and mast, a lot of work in this area so don’t hold your breath. 🤪 Jacqueline also bought me a second Pontos set so l have the parts I need to go forward. Who said us modellers are sane. Here’s a photo of the propeller before I dressed it up.
  5. The steps to the boat deck, didn’t fold this plus cut a bit styrene stock thick enough to let the steps sit at desired angle then painted the part as deck colour. Not correct but solved the bigger problem, seems to be a similar problem when fitting the other steps from boat deck down to main deck, except here the part is too long and requires altering again to get a desired result. Think I managed to steal all this. 🤞
