Papa
Everything posted by Papa
  1. Impressive work. I will have to pay attention and perhaps learn something. My plastic models never come out well.
  2. I fill the larger cracks with slivers of wood. They blend in very nicely when sanded.
  3. FYI, I wont be posting over the rest of the month. Mrs and I are taking a trip to Italy to celebrate our 51st wedding anniversary. We missed out 50th celebration as my wife needed gall bladder surgery. Good thing we had trip insurance!
  4. Hmmm. Just tried to delete in an edit. Didn't work
  5. Capt Slog, i was also thinking it might just be an extra piece. All of the pieces on that page are for the lower hull except the one marked 13a.
  6. Dan, maybe you can help identify the piece on this page with the bottom plates. It has no number and all the bottom plates 1-8 are present and accounted for. Also, followed your advice and am putting in some longitudinal braces
  7. Actually, i have made no more progress. Too much going on right now,
  8. I am finding that putting the bottom plates on is fussy work. Not happy with the first 2. Trying a new technique on plate 3. align and glue the center-line first. Then do the ends and sides.
  9. I followed Danny's advice and inserted some tiny brass "eye bolts" in the deck at the marked points. You can't see them in the photo
  10. It is so obvious I wonder why it took me so long to see it.
  11. OH WOW!!!!! Thanks so much. Google gets a bit confused sometimes, and this is so much clearer. Thank you thank you
  12. Thanks. Generally google translate is doing ok. I just have to take the build slowly and double check everything
  13. I will scan the "directions" today. I have figured out that the tiny white spots are for rigging.
  14. Danny, Thanks for the advice. The plans aren't very detailed, but, the more I stare at them the more I see.
  15. OK, I studied the directions some more. A "W" indicates "cut". The W in the attached picture is about where one of the masts should be. I am wondering about the other tiny white disks. Are they to be drilled out for davits or rails?
  16. The instructs say to pre-drill the mast holes. It is not clear to me on the deck plan where the mast holes are.
  17. I finished the skeleton, except for the decks. The instructions say that the deck pieces are to be glued to 1 mm card but the schematics don not indicate this. (a "**" is attached to the part number if it is to be glued to a card; the deck pieces don't have this indication.) I decided to follow the written instructions and have glued them to a card. Hope it works out OK.
  18. If you do not happen to like Ferrero Rocher chocolates you can send them to me after unwrapping.
  19. Super job on the ratlines. I can't even come close to that level of perfection.
