Everything posted by ErnieL
	Beautiful build here. I come from the North Shore and haven't seen one of these in years, but from memory, you're doing the whaler justice. The flat bottom dory was king in Gloucester. I've seen young lads almost pick those things up by the oars and jump across the water they rowed so powerfully. Your craftsmanship is truly second to none, and I'll be following this right till the end.
- 52 replies
- model shipways
 - new bedford whaleboat
	I have a few strafing runs to do with another type of plane. Then fill the low spots, of which there are a couple. I feel I may have gotten a touch overexuberant with the sanding block at the stern here. A couple swipes of my block slightly cut into the stern edge of the gun pattern plywood, rounding the bottom edge slightly, and I sanded the curve under of the port side stern maybe a bit much. Thoughts? Should I build it up slightly with filler or sand the starboard side to match? i think it looks decent, but it’s a touch deep of a run under than the plans show. Also, on both sides, I have a slight low spot on the hull just aft of the first gunport. I’ll plane it as smooth as I can, but I expect the low spots aft of the first gunport will need a skim of filler.
	I’m paying VERY close attention to this. Being a plastic modeler, I’m very detail oriented, and fully rigging the guns is a set goal of mine. Lead on, kind Sir!
- 725 replies
- vanguard models
 - speedy
	This is MY kind of build! As a long time plastic aircraft modeler, I absolutely understand the need to weather for realism or artistic effect. Most wooden ship models I’ve seen have been built to reflect a ship in tip top condition, which may not always have been reality. I, for one, am absolutely loving what I’m seeing here. It’s definitely seen hard use and is due for some dry dock time, but that’s what I absolutely LOVE! Keep it up, sir, this is incredible! Ernie
- 358 replies
- occre
 - santisima trinidad
	Note to self: for the second planking, lay the plank next to the keel before you reach bottom and work upwards a few planks to meet the descending planks. Meet the two under the copper, not at the keel. What a sh!tshow trying to shape the bottom one perfectly. Much easier if only keel edge needs shaping. As it is, I had to add slivers here and there. Oops. Now we breaketh out large block loaded with 120 grit. there’s a whole lotta shaping going on.
				Is there an easy wooden tall ship out there to build?
ErnieL replied to thegrindre's topic in Wood ship model kits
One of my all time favorite movies. -
	I’m following this closely. This will be my next build, followed by the Zulu.
- 195 replies
- lady eleanor
 - vanguard models
I’m pretty much a newbie as well, although I’ve been building plastic kits for decades. If you’re looking for an easy, traditional wood model of a traditional ship and don’t mind a Lugger, try Vanguard Models Scottish Fifie Lady Eleanor. Or, if you want a rakish stern, the Scottish Zulu Lady Isabella. They are both traditional plank on bulkhead, have two masts with big lugsails, and are expressly designed for the beginning ship modeler. The instructions are second to none, the plans are awesome, everything is beautifully precut, everything slots together precisely, and can be built with or without sails. The sails look pink in the pics, but that’s just color shift, they come as white cloth and you dye them your favorite shade of brown or burgundy. When it comes to amazing instruction manuals, there are none better than Vanguard. And Vanguard is known for only supplying the very best wood available, and plenty of it as well. I have BOTH of these kits, and they’re positively amazing models. Absolutely nothing else other than paint, varnish, glue, and tools are needed. I HIGHLY recommend either of these for a relatively quick build using the traditional methods. -
	Welcome to the Vanguard Models club. I’m looking forward to your build, as I chose HM Sloop Speedy for my first ever wood sailing warship build. I’m sure enjoying mine. And learning ALOT!
	Yep. I’ve done that, and thanks to my lack of foresight, Inran the firstnplanking over the entire hull, right to the tip of the entire keel. So now, I get to make sawdust out of all those boards I so carefully cut and pinned to shape by the rear keel and the sternpost. Now that I know, it’s obvious, but I was full sail set to oblivion until someone backed the wind and set me in irons. Ill dig out, but I’ll need a snorkel to breathe from under the sawdust pile that’s fixin’ to be made.
	Beautiful work so far. The clinker planking is very well done.
- 23 replies
- vanguard models
 - alert
	Well, I’m getting close to finishing the first, and my first ever, first planking. I so far have gotten away with one stealer per side, which seems about right. I should have this part done tomorrow evening. I’ll admit I’m mighty slow, but I’m sorta just feeling my way along here.... i see a possible trouble spot or two that seems a touch low, but we’ll see. I haven’t had to redo anything of importance so far, have only lost a tablespoon or two of blood, and haven’t warped it like pretzel. YET.
