Sparky21
Posts posted by Sparky21
On 7/30/2020 at 6:01 PM, Davy Jones said:
Finished the keel. I think it looks ok now its sanded.
I also attached the rudder This was quite fiddly, it took alot of fitting the re-fitting but all went well I had to be quite carefull with the rudder Gudgeons i think thats what they are called, These are made out of a lead type metal and marked very easily.
Davy.
I am making the same model, I am up to attaching the rudder. The directions for this model aren't the best. I can't figure out what to use for the pintles for rudder Gudgeons. What did you use for the rudder pintles? Thank you David
Have not worked on the HMS Victory for most all of the summer. Almost finished with the first layer of planking. I have a lot of prep work ahead for the second planking. I and wondering about the second planking methods.
When adding the second planking how do you fasten the planks while the glue dries?
Started the first layer planking. It was a learning curve for me on how to use the soldering iron as to when enough heat was applied as to not burn the planks. As you can see in the second photo I scorched the planks.
Also the written directions said to wax the frames so the frames can easily be removed after the planking is done. But in the sheet plans it show tiny nails into the frames. I'm not sure if I'm doing the planking correctly or not, time will tell- mort stoll, GrandpaPhil and Henke
- 3
This is my seventh build. I do believe it's above my skill level but for better or worse I'm going to give it a try. I've never done a second planking so this will be interesting. Also, the sheet plans are all in Italian. I've been using the Google translator which works really good. I started using a soldering iron with a jig that I made for the bending of the planks. I've found that water soaking the planks before I heat them to bend work quite well. More photos to follow as I progress.
Could that piece be reversed? Looks like the longer flat side might be placed towards the bow. I'm probably way off on suggesting this.
On 3/16/2022 at 11:41 AM, Dave_E said:
Words to live by in this hobby for sure! Thank you for the reminder. Beautiful boat! 👍😀
Thank you very much.
23 hours ago, JerryC said:
I still need to work on the rigging. I couldn’t figure out what went where from the plans provided.
The plans for the rigging are difficult to follow. I did my best to follow it, but I guessed where they should go from past builds and sailing experience.
I just do the best I can and learn from my mistakes.
Your model looks great!!
Not sure of the type of wood that came with yours, I'm thinking mine came with walnut. I purchased it on eBay and I think it was laying around for a log time a all of the wood was very fragile and kept breaking when I used an exacta knife. I ended up sanding most all of the planks into shape
- Dave_E, ccoyle, Rik Thistle and 6 others
- 9
5 hours ago, BobG said:
Nice job on this interesting model, Sparky!
Thnk you
8 hours ago, SaltyNinja said:
Did you fill in the gap? What about making a piece to fill it in and gluing it in? I think I read somewhere about using glue and sawdust for filler.
It's looking like nice progress anyway.👍
Thank you,
Yes I did fill it with wood fill
- mtaylor, BobG and SaltyNinja
- 3
Coming to the end of the planking process. . The kit had been in a small hobby shop that went out of business during the pandemic; he was ready to retiree. Not sure of what type of wood the kit came with (I think its walnut). I found that most of the wood is very brittle. Learning curve has been frustrating at times. I'm mostly happy with my results. I'm planning on clear coating the planks with either shellac of varnish. There are a few gaps in the planking, not sure if I should leave them or fill with wood fill or sawdust fill. Any input would appreciated
Thanks,
David
- ccoyle, Rik Thistle, king derelict and 3 others
- 6
I have them, wondering how I can get a copy to you.
- thibaultron, Canute and mtaylor
- 3
Following the instructions it says to plank with strips 1.5X5mm and space with0.5mm strips. I glued in place, then as per instructions cut off excess spacers that were above the planks. After cutting off I then proceeded to sand, After sanding I noticed that I had not done a very good job of gluing the spacers. Now there are large gaps where the spacers fell out.
Not sure what to do at this point. As you can see I haven't made much progress.
Photo #1 shows the spacers and planks glued
Photo #2 shows a spacer with planks
Photo #3 large gaps where the spacers fell out
Not sure what to do at this point. I used white glue, I'm thinking about trying to remove the planks and spacers by soaking with water. Then gluing planks in place with no spacers then pencil line in spacers.
Any advice?
Thanks,
David
This will be my fifth build, I'm not the best at logging my builds but will try to keep up with this time. All but one of my previous builds have been models by Midwest (The Dingy, The Muscongus Lobster Smack, Sharpie Schooner, Boston Whitehall Tender), and Long Boat 18th Century by Model Expo.
I had purchased the Trotmares on eBay last summer 2020 not knowing anything about the build process. The Midwest plans and instructions for the most part are very easy to follow. After opening the Trotmares box and looking at the sheet plans and instructions, I was very overwhelmed.
Almost a year later I have decided to go ahead and build it.
Lexington by Sparky21 - Mamoli MV48 - Scale 1/100 - American Brig
Started this build January 2023, progressed through the winter and spring. I lost interest in the hobby after getting Covid and other family issues. But I’m back to working on the build.
