marsalv
Everything posted by marsalv
  1. Thank you guys for nice comments. Scrollwork and moldings are done with CNC milling maschine. The same situation is for the parts on next pictures. All carvings are made with CNC. It is likely that some of you will condemn this process, but you will not stop technical progress. I would be quite interested in your opinion on the use of modern techniques for creating carvings.
  2. Thank you guys. Answer to Glenn: The groove is made so that you only have to push the plank into the groove. For sure, however, it is still glued with double-sided tape. I started work on stern - moulding rails.
  3. Thank you druxey🙂. Main topsail sheet bitts and the deck is completed.
  4. To dowmer - this time I used brass, which is then tinned, and tin foil, which is glued to the deck with double-sided adhesive tape. To glbarlow - the maximum length I can do on a milling maschine is 28 cm, for longer plank I use "special jig" - see picture. I insert the plank into the groove in the jig, perform the milling of the first part, remove the plank and move it forward and continue milling. I continue with breast hook, collar beam and bowsprit partner.
  5. Hi Michael, moldings are made on CNC milling maschine. I am using VCarve software for this purpose. You have to create only curve (cross section) of molding and maschine does the work itself🙂. You can see in this example that my workmanship is not so superb as you noted🙂. Preparation of deck beams for forecastle and quarter deck.
  6. Planking completed, drilling holes for guns attaching.
  7. Thank you guys for all likes and very nice comments🙂. To archjofo: why that modesty, your work on La Creole is amazing. To JpR62: the moldings are done with milling maschine. I continue with planking the outer parts of the hull.
  8. To Druxey - thanks for informations, I discussed this situation with my friend who had the same problem. I cover these lead items with clear varnish and the whole hull is then preserved with the wax. I hope that it will be OK. To Alexandru - I am using the french Sajou thread for the ropes (https://sajou.fr/en/339-fil-au-chinois-gloving-thread-1000m-cones). Unfortunately this thread is only in one thicknesess. Completed ceiling.
  9. Thank you James H🙂. Forecastle and quaterdeck deck clamps, scuppers -made of lead foil.
  10. Various openings are cut into the framing - gun ports, windows and double sheaved fairleads.
  11. Some deck details - inner waterways, binding strake, carlings and ledges.
  12. To No Idea - I mostly use the two flute router bits (https://cnc-plus.de/en/End-Mills-266/2-Flute-281/Carbide-Two-Flute-Router-bits--2-Flute-End-Mills--CNC-Cutter-Bits-2983.html). Waterway.
  13. Thank you guys for all comments and likes. To No Idea: tilting base is specially designed and "home made" for existing Proxxon vice. To dvm27: I have visited Sherline web - this maschine is fantastic, I´ve never seen anything like it before. After about one week all ropes are finished, cca 190 ropes in 14 thickness. Lenght of one ropes is approximately 180 cm.
  14. The spare anchor is in place, I did all the other anchors during one work. Now I take a break "from the wood" and start making the ropes.
  15. The remaining deck beams have been added, a spare anchor remains to be added and the interior of the hold will be complete.
  16. Hi Derek, thanks for reply. Information at the beginning of the log I meant that there is no fixed orlop deck. At first I thought I wouldn't install this removable orlop deck at all, but later I changed my decision. I added the barrels to the water hold and covered the whole with the remaining deck beams.
  17. Thank you James H😉. Next part was the orlop deck beams installation.
  18. Thank you guys, especially praise from admin pleases 😉. Preparation of riding bitts.
