My Fathers Son
Posts posted by My Fathers Son
Ok, two things have happened that are helping me in my quest. Firstly, I have found digital copies of Campbells drawings of the CS that is the layout, the sail plan and rigging plan. From what I can see and from looking at images of the actual boat, there are a few differences plus I am working with a base that is not strictly to scale. This does however give me enough of an idea on what I need to do and I would never have been able to get my head around the rigging without something like this.
Secondly, I have bought a Kindle version of a book called Ship Modelling Simplified. This is helping me a lot in setting out an order of things that need to be done reinforcing my Admirals mantra of Finish the deck fittings first.
I had started out on finishing of the Stern and moving forward but the book tells me to start from the forward position and work towards the Stern, so that is what I am doing. In the mean time I had made an attempt at installing some of the standing rigging on the mizzen mast.
The above are my first attemps at Lanyards and Deadeys. I had tried a single piece of wire bent at each end to standardise the distance between the deadeyes but I struggled with this. So I made a tool consisting of a stripp of lite ply, 5mm by 60mm, with two pairs of wire on which I can mount two deadeyes. These keep the deadeyes in the correct position. I mounted the lower deadeyes and lashed them to the mast below the platform. I then added my tool and connected it to the lower deadeye and had another on the upper pins. I was then able to loop the stroud around the deadeye and clip both the rope together up the stroud. I could the seize this in place in two places and a touch of CA on the seizing keeps the whole thing in plaace with consistand distancing and direction of the deadeye.
I could then remove the tool and thread the lanyard in the correct order with tension and the final length is looped onto the seizing on top of the upper deadeye.
Moving to the front of herI have secured the jib boom in place and installed the chains that support it from below. I have changed the original Cathead so it exists both inside and outside of the hull. Not easy to see here but I also made whiskers and CA'ed them to the Catheads.
I am now experimenting with making my own cables with copper wire I have stripped from coils from a dead ECU from a domestic boiler. One thread is very thin. I have spun 3 lengths together which you can see hanging of the bow, but I think I need to add more lengths to pruce a realistic cable strong enough to stabalise the Job Boom.
Need to read a bit more of the book to see what is next, but I suspect finishing the Capstan and Windlass is the next in line.
TTFN
Simon
- ScottRC, mtaylor, GrandpaPhil and 2 others
- 5
On 6/7/2021 at 11:01 PM, LeoM said:
I went through your build log and I am delighted by the work you are doing.
Thanks for sharing your story about father.
Leo
Thanks Leo, I allways appreciate all the comments and support I have received on this forum, it has helped a lot.
- mtaylor and Keith Black
- 2
Not much got done this weekend but I heard about a model shop that specialised in Boats and it is located in Chatham historic boatyard. Well, the shop was a bit of a dissapointment as it was very limited in stock but I still managed to get some things. However, it was a lovely day weatherwise and the Dockyard is free to visit, so phone in hand, I started to have a look around. There are three ships onsite. HMS Gannett, 1882 hull with 4 guns. The upper decks and masters cabin were open so I had a walk round. She is still afloat in Dock no 5 but the water is dead and green as a result of the copper cladding.
In dry dock no 4, is HMS Ocelot, a 1962 Cold war Oberon class submarine. She is closed to visitors as there is no chance of Social distancing in a submarine.
In dock no 3 is HMS Cavalier, she is also afloat. She is a 1944 Destroyer that was updated and refitted in the 50's and retired in the 60's.
There is also a fantastic indoor sheed houseing WW2 vehicles, miscelaneous boats and item's plus lifeboats through the ages.
These are just a few of the images.
- mtaylor, GrandpaPhil and Keith Black
- 2
- 1
Hi all,
I am looking at making the Fairleads for the foredeck and am struggling a bit on size and design. These are mounted on the topgallant rail which was Teak 6-1/2" x 3-1/2" and looking at the image of the real thing, this looks to be about 3 1/2" wide and a ration of 1:13 against its length. At 1:100 that makes it about 1mm wide and 13mm long and just over 1mm high. That seems very small and I am not going to be able to make this with a central post, two roller posts and the shoulders to cover these.
Worse still, I couldn't see anything sutable on Cornwall Model Boats website. Any idea's?
- Keith Black and mtaylor
- 2
On 5/16/2021 at 10:36 AM, My Fathers Son said:
Hi all,
You know when you look at something and it bugs you but you cant quite see what the issue is? Well, it has hit me what is bugging me, the Mizzen mast is too short. The confused scale of this model is getting to me a bit, but I can see what is wrong now. One, the lower mast is too short, not by much but enough to notice. When I compare the proportions of the three masts, the Fore and Main Masts are in proprtion but the Mizzen c omes up a little short. Part of this is dads error, he shorted it about 1cm and the other cm is down to me. When I reworked the hounds, I overdid the overlap. The reason this happened is I did the Mizzen first and just adjusted the joint by removing material from the rear of the base of the centre mast and adding to the from, but on the other two, I actually added extra material below and shaped the joint to create the space for the Shrouds to pass between the masts. I can add a cm to the base of the mast, this will be below decks and wont interfere with the structuarl integrity, but will bring the Hound up in close allignment to the other masts. Bah humbug, but I am not certain whether to undo the hound as there is a fair bit of ironwork already installed.
Well it got to me, I could not stare at it any more to the point that I was ever going to be satisfied with the look of this without dealing with this mast. Also, fiddling with bits of the mast, trying to adjust the length of the lower mast was not going to work so I am remaking this section of the mast, sorry dad, but yours had to be replaced, I am keeping the the mid and upper sections.
This gives me the chance to learn from my first attemps on the iron work which while ok, but were not the best I can achieve.
Having read NenadM's comments on the scale of the bands on this section, I have bought a supply of 8mm brass belaying pins. I know they are way to big for scale but for practicality, they will at least hold the ropes and give me the chance to apply the rope 2-3 turns and still have a bit of room to hang the ends loops of rope for the lines.
When making the lowest band, I will install 6 hoops aligned vertically for the blocks to hook onto and horizontal in the next hoop for belaying pins. I will also change the universal joint on the lower gaff to match the design of the one on the upper gaff but hope to refine the finish a bit.
If at first you dont succeed, try, try again.
Simon
- Keith Black, NenadM, GrandpaPhil and 3 others
- 6
2 hours ago, NenadM said:
Making masts, some queations appear. Pretty enough for mind blow and head ache.
Look at this detail. And that is not only ...
Dia of fore mas bottom in my scale is only 8mm
There are placed two rings with pins and and with bumch of little rings.
How should be dia of those little beasts? Pins lenght - 1mm?
It is not problem to fake, and to make something to look as it should look.
But, how to make it to be functional and strong enough to put end of ropes lines there ...
How thin ropes have to be? As a hair, or less?
Hmm
Will it help if I enlarge dia of mast to 10mm? I don't think so?
Dark side, dark side, dark side ...
Hmm againHi NenadM,
The image you have shown here is the foot of the Mizzen mast. At 1:100 I am going to have to surrender to practicality on my Cutty but she is not as strict to scale as yours. I am currently remaking the Lower Mizzen and fitting out this section with hardware and the image you have shown has been a great help as I had not realised the lower band was going to have blocks. I have managed to get sight of Cambells drawings and unfortunately, he has not detailed this section of the mast unless you can see the detail here.
Loving the detail on your Cutty.
Simon
Well, I haven't touched the Mizzen mast this weekend but have continued with the brass Davits. I spent some time thinking about the fittings on this and tried to make the blocks and cleat. I used a short length of 2.5 copper cable and filed down and approximate shape for the cleat being carefully not to separate it from the rest of the cable. I then mounted both davit and cable in my new magnifier holder clamps so the were level and just touching.
A Liberal coating of flux and cut of a tiny amount of solder and applied the heat and the job was a gooden. I then fine tuned the shape and removed excess solder with a file.
I shaped the blocks from 2mm Square sapele and drilled them. Threaded the cable and secured it to the davit with rope at the base.
Remembered this morning that I really should have painted it before mounting the rigging, do'h.
- ScottRC, GrandpaPhil, keelhauled and 2 others
- 5
I had an attempt at the Brass Davits yesterday and you can see the difference. Leaving asside that the first attempt was two short, there was not enough space for the block and tackle between the boat and the davit, the brass looks way neater and stronger. Just need to design and soldier a cleat and eye to secure the ropework. I have made 3 basic one so far and continuity is an issue with the bends and eye at the top. It's about a 10p coin curve but a 50p would be better, if only it didn't have a those bleeping angles on it.
Hope everyone is having a fruitfull weekend.
Simon
- Keith Black, GrandpaPhil and mtaylor
- 3
On 5/9/2021 at 8:08 PM, keelhauled said:
Hi Simon,
The Cutty is looking good. Nice details. I look forward to seeing how you do with the davits. I made mine out of Brass, but I'd be interested to see how you do with the wood. Be careful in wood not to introduce to much bend all at once, you don't want to split the wood. Also, drastic bends can be very difficult with thicker wood or dowels. At least they are for me ☺️
Good luck!
marc
Hi Marc,
Thanks for this, it is coming along, not as quick recently as work has been taking a priority. Also, the things I am working on take a long time and progress is not as obvious. I managed to get the bends all done without any casualties, but I am not happy with them, they are way too fragile and look it, so even if they never have to lift a lifeboat, they dont look sturdy enough to do the job anyway. I have some brass rod so will have a go at thet to see if this improves the look. I am planning to set up block and tackle on each if I can make something that looks the part.
With the shops back to opening to the public and a day off work meant I could take a wander through the local hobby shop. Hobbycraft are not specialists so there is lots of generic stuff for all hobbyists but nothing for the specialist boat builder, but I did manage to get some fresh blades and a third hand with magnifier so was not a total waist, plus some dowels so I can start on replacing the missing yards.
I have made the replacement Spanker Gaffs, I sourced some chain in antique brass and found a way to make a universal joint for them. No images at the moment, will upload some later in the weekend.
I have made some bollards and am ready to install them and the anchor chain chutes to the chain store are ready to install, and my son and I had a go at the figurehead. Scale is a bit out, its too large but will have anorther go once the Jib is set up with the chains and lines.
- keelhauled, Keith Black, GrandpaPhil and 1 other
- 4
Hi all, its been a while since I last posted. That funny old week mentioned in my last post nearly ended up with me being made redundant, missed that by the skin of my teeth. Obvious progress made is very little as the things I m working on are small and time consuming.
I have managed to fix most of the superstructure to the deck from the aft deck to the foremast, but forward of this point, most things are made, bar the Anchor chain and the feed lines for these. I have brass tube on order but having to wait a while for it to be delivered.
In th emean time, I have been tidying up the masts. Dad had simply nailed three sections of dowel together in straight lines, and this did not work for me as you need the space between the masts at the overlap for the Shrouds to pass between them. However, I wanted to keep the masts Dad made so I just added extra to the front of the mid and upper sections , shaped them as best I could. I toyed with making brass Mast caps but that was an abject failure. So I have made these in light ply and after gluing in place, It have thinned them down and painted them black. The image below is the Foremast before I painted and stained the masts.
Hindsight being a wonderful thing, I really should have painted and stained these before starting on the deadeyes. This is the very first part of the rigging I have attempted.
One thing I am stuck with is the spacing on the deck. The mix up on the scales between length and width is one thing but the other is that the Main Mast is set about 1/2 inch (12mm) to far aft and this area is now a little cramped. I will remake the hatch cover a little smaller.
You can see my latest effort on the signal cannon, I intended to drill out the barrel for a few mm but none of my drill bits are up to it.
You can see here that I have created the chicken hutches. I still need to install the Bollards, I have ordered the upright parts and I will glue/solder these to Brass plate and install them. I need to finish the Boat rests for the life bouts. I have finnished the one for the starboard side but I am toying with the idea of remaiking the port side one to match. I have made Davits for the boats, but I am in two minds whether the make new in Brass or use the ones I made and curved, using water, heat from my soldering iron. Had to heat it up, turn it of to cool a little then use it as it was far too hot when lit and burned the wood. There is one resting on the boat slides as an example.
If I make any progress over the weekend, I will update again.
TTFN
Simon
Emm, I am pretty sure my Admiral would not, but if you used wooden clamps, you could put water in the pan and put on the stove, the heat would speed up the bending process!
Hi all, its been a funny week at work and this has disrupted my progress a little. I have decided to work from the rear to the front and make each component until I am happy with them all and then install them to there permenant position. The signal gun is a first attempt, the barrel is not too bad but the mount is not acceptable so will be starting again. I think there is supposed to be two meat barrels and I am aware that there should be three bands, but that is beyond my current skill level and facilities. The bands are made from 15mm plumbing pipe, I have cut strips and then filed them as thin as I can, but they still look clumsy. The barrel is too stumpy as well, I hadn't tried to use my mini drill as a lathe at that point, might try again but that is fine tuning that I can do when I have the main structure and components sorted out.
I tidied up the Liverpool house and am content with this, I have the brass stantions for the railings but having read that they get in the way when installing the rigging, I will set out the holes for them, but will leave installing them. I am contemplating changing the front railings as they appear out of proportion, they are too tall and the support posts too heavy. I could do with a mini lathe but all I have is a drill and my imitation dremel. I have been making wooden Belaying pins on the dremel from bamboo tooth picks as the 5mm brass ones I bought would not be able to catch the thread when installing the running lines. These ones are 8mm, I know they are over scale as that puts them over 2' long but I do not have much choice.
Planning ahead, I have started making the fittings for the lower deadeyes and it is going to be almost impossible to thread these in situe.
You can see that there just isn't room to get even a curved needle between the deadeyes and the gunwhale, so I will have to set up a rig where I can construct the lower and upper deayes in place, thread them up with the lanyards, then install them into the predrilled holes in one go.
I think that the standing rigging for the mizzen mast looks a little like this.
So my rig that I will set up will consist of two uprights that will be removed after installation. The base can be 1mm x 3mm walnut strip with drill holes for the lower deadeyes. The top piece can be 1mm x 1mm walnut strip that can be strapped to the upper deadeyes, and the down cables attached when the main rigging elements are installed. In the mean time, I will set up the deadeyes locations so I can position the fife rails correctly.
I have been practicing my metal work skills this week and have been working on the bilge pump but no pictures today, this is still experimental at this stage.
Simon
- Keith Black, gieb8688, mtaylor and 1 other
- 4
1 hour ago, RonGinger said:
I can only repeat what so many others have said, your work and tools are outstanding. On one hand it is a great inspiration, but on the other it is depressing to see how much better your work is than anything I could ever come close to doing.
Hear, hear, at least we have the benefit of a master at work.
- 2
On 2/27/2021 at 9:00 PM, Keith Black said:
MFS. CA will work for the wheel.
Thats for the help Keith, I finally got round to finishing of the Wheel and Gearbox yesterday.
The wheel is retained by an Earring backstay mounted between the outer board and an inner piece so it turns. The name plate is sheet brass and used a Dymo printer on clear tape. My hands are far too shaky to get that to look nice otherwise. I have some clear auto lacquer and will coat this so it retains its shine.
I added a little detailing to the Liverpool house prior and getting ready to install the hand rail but I read from someone that this is likely to get bent out of shape when rigging so may hold of from this.
Half way through the meat barrel last night I slipped with a craft knife so gave up for the evening, but is true now that this is a labour of blood and sweat, if not tears, bringing the model back to life. The two fife rails are constructed but not installed as I can't determine the correct position until I have a better idea where the deadeyes are going for the mizen mast, I dont want to crowd the area until I have this set out, much to the dismay of she who shall be adored, who thinks I need to be more methodical. She is right of coarse as I have drifted from task to task a bit.
- gieb8688, GrandpaPhil and Keith Black
- 3
Hi all,
Had my covid jab yesterday so feeling a bit off today, but woke early and after making a coffee, set out my workshop.
I finshed the Steering gear box yesterday and am waiting on the postman for the wheel. Looking at the deck it seems I have lots of things with the main construction done but nothing is actually finished, so I have tried to sort a few of them out.
I started with constructing the roof mounts for the Captains Gig, glued it up then painted the roof white. Another coat and I can install the brass rings to secure the ropes that will hold the Gig in place.
I was lucky to get my delivery from Cornwall Model Boats today, pleasantly surprised at the speed of the delivery.
The Ships wheel I ordered was included but as you can see, some assembly is required. The spokes dont actually click in place and keep falling back out. Will CA glue hold this or do I have to solder them?
I carried on with painting, but it all needs to be rubbed back down and another coat applied.
I can then apply the final trim aound the houses in Mahogany strip. I still need to work on the hull as I need to round of the curve on the rear, its quite obvious in such close up images.
- GrandpaPhil, mtaylor, gieb8688 and 1 other
- 4
The doors are 16mm. I lowered the roof and took out the sill above the doors. At a scale of 1:100 that would be about 5'6". The average sailor in the 19th century could walk through with only a small duck of the head. I have stained the side walls and planked the roof with beech sticks. The sky light was interesting, the window frames took a bit of fiddling gluing 1mm square beech stips, these still need to be glazed before I stick them in. I am quite pleased with this, not too fancy to be so far from what dad started but true to the spirit of the ship.
Next will be the steering gearbox.
Must start that shopping list before long.
- Keith Black, GrandpaPhil, gieb8688 and 2 others
- 5
Thanks Keith, the magic number for me was 6'6" as I didn't know that. There are 2 scales in play here as she is 1:90 on length and 1:110 on width. Working on an average of 1:100 and 24.5mm to the inch, this cones out as 19mm, so using 18mm makes sense. There are a couple of brass 8 spoke wheels on Cornwall model boats site so I will go for one of those.
Really appreciate the help.
Thanks Keith, I was leaning towards 20mm as this would have a radius of 10mm. This is mounted just below the roof level of the gearbox and the bottom of the wheel just clears the deck. I am planning the Gearbox to have 2-3mm legs at the front and be 8-10mm in height so it is in scale to the liverpool house which tops out at 12mm without its dressing up, which will only add 1mm to its overall height
- mtaylor, Keith Black and gieb8688
- 3
My Liverpool house is doing well as I have a nice shape and the proportions to the poop deck look of. The cover for the front door is a little to high, so I will reduce this. The door will remain the same size though and is the same size as the immitation doors in the two deck houses. I will plank the roof with beech sticks, install a surround at the top and bottom of the sides and simulate a door from. The sides will be stained mahogany and the roof painted white and distressed a bit.
Next will be the steering gearbox and ships wheel. I have been looking for a suitable wheel, and I am thinking something in th eregion of 20mm to 24mm and there are a few options in my favourite store. I have looked at the Mantua wooden ones and they look a little chunky for my taste. I am leaning towards the ones with a finer look.
It is interesting that the image of Captain Woodgett in 1927 shows a rather plain 8 spoke wheel but the one on her today has a brass hub and a brass inlay in the outer ring. The spokes are more akin to victorian stair rail with a square base and turned pattern.
I am just asking what size wheel I should be looing for considering the scale I am looking for is between 1:90 and 1:110.
- GrandpaPhil, mtaylor, ScottRC and 2 others
- 5
Hi Keith,
This was the first thread that I read in the forum followed closely by Kathy's equally excellent model. I do not aspire to replicate their work as that would necessitate redoing the Hull and would not then be dad's legacy. I will use these as a good guide for designing and setting out the deck but I need to be a little stylearised to be true to dad's original.
I took the model down and started laying out the deck fittings and the space is starting to look a little cramped. To make the decision houses the right width, I have made them a little long down to the scale error in the Hull.
I am redoing the toilets as they were too short, and the most crowded area is going to be between the fore deck and fore mast. I have no choice but to play with the scale of the Fife rail, winch and hold cover to create a little space between each item.
I will be making these parts myself so won't be stuck with sizes on stock parts. We will have to see what my metal work skills are, hope they live up to my woodwork skills, even if they are still a little rusty.
The fore deck is solid balsa so I can't do anything for the crew accommodation and piggery that was under there, but I have started on the chicken coups. Lite ply and thinned toothpicks will do for that.
- ScottRC, Keith Black, GrandpaPhil and 2 others
- 5
Have spent the majority of the weekend planning on what I am doing, trial and error and "Having a go at what I fancy" is not working for me. That said, I still spent sunday afternoon working on the ships Jolly Boat.
A Lack of plans is a problem and so I am looking at what I can do to draw a few of my own. This should let me set things out as the size of the hull is a done deal. The only trouble with that is the proprortions are wrong. The hull is 71cm from stem to stern and Cutty is 212.5 ft so this suggests a scale of 1:90 or there abouts. However, she has a Beam of 36ft and my hull is 11.4cm and this comes out at about 1:110 or a little less. Overall, this should not be a problem if I work to 1:100 as a general scale so that the overall effect wont be too far out.
I had made a Liverpool house and the size is not far out but its a bit too angled and the whole thing is in Walnut. I will be making a new one, a little longer that the current one with a smoother curve to the sides to match the shape of the deck. You can see the difference in sizes based on the ratio alone as the images attached have the two stencils I drew up. I will have to temporarily stick a paper to the deck and then run a compass around the deck with an arbitary size for the gangway. As she is now, there is only one door at the front of the Liverpool house and that is how dad had her, so I will omit the rear door. This will be made from Lite ply with beech planking on th roof to match the deckhouses, thank you Starbucks.
Being in Lockdown is getting very frustrating as I would much rather go and buy what I need as I need it, there are, or at least were, modeling shops in South London, although only a few that stocked the materials I will need but thats out, so I am stuck with mail order and the Cornwall shop is the only reasonably priced place. The only real problem with that is I like to see what I am buying and you have to plan ahead, which I have not been doing so far. Other wise, I am sourcing materials from where ever I can get it and coffee stirrer sticks make good roofing materials, but you have to forgive me the scale issue.
Time for work, more to come.
- BANYAN, mtaylor, GrandpaPhil and 2 others
- 5
Hi all,
One of the problems with a lot of enthusiasm and lack of project management is that it results in duplicated effort, something I am definitely guilty of.
I find myself perusing the images on this forum and am astounded and amazed at the quality of the work being done, I ansolutely love Kathys "Cutty". I on the other hand find myself making an effort and sitting down looking at the result and cant help but feel disappointed. However, to quote Harry Callaghan, "A mans gotta know his own limitations". That doesn't mean that I do not have or cant develop the skill to do this but I need to make my mind up what I am going to do. The previous efforts I made such as the Forward Deck House and Lifeboat and shown on my last post were both better than my fathers pieces, but they fall short on what I want to display. I dont know if dad had any plans, the boat had only been installed in her dry dock months before he would have started his model. I dont think this is a kit because I just cant nail down the scale, it appears to be somewhere between 1:100 and 1:110. I do not have proper plans either, so am using a lot of images I can find on the net (an advantage I have over dad, he was a keen photographer so would have taken photos of her at the time) and looking at proportions to work out the scale for individual items. So I have remade the Deck house, my previous effort was to narrow and too small, not by much but noticeably so. So I have remade this from Lite Ply, some spars and Starbucks stirrers for the roof (I need to do this on a budget, so am looking to source materials from what I can lay my hands on). This is a better proportion for the existing deck.
I remember dads small boats were carved blocks and were installed upside down on the roof and racks, but that is not the way they are displayed on her at Greenwich, so I had to do better. What I have shown here is my fourth effort at a clinker built boat, and I have finally managed to unstick the tips of my fingers, and am relatively happy with this. I will be installing this one on the deck house displayed. I have two lifeboats in progress and the remaining boat will have to wait until I source some more thin stips for the planks.
Time to go to work so TTFN, I will be doing more over the weekend and will post on my progress.
- mtaylor, gieb8688, Keith Black and 1 other
- 4
Ok, so I have not been totally idol this week but there is a fait bit going on in my life at the moment, so have not been able to devote as much time as I would like.
When I got the boat back, I did a fair bit of cleaning to her, but in doing so, quite a few bits of damage became more evident. I removed the masts and deck houses, cleared up the decks and it was clear that I was not going to be able to get away with just cleaning it. Apparently, she had been played with in the bath, not realising that she would would need about 2 pound of lead shot and glue in the keel to keep her upright, and the deck timbers had shrunk and cracked. Rather than remove the old deck, I just laid a fresh deck over the top of the old one as the previous damage was now stabalised and there was no worping.
All I had at the time was a lot of images of the actual boat and so attempted to use these and the dimensions of dads original pieces, to create the three main deck houses. I used basic marquetry to give the impression of doors. I am not sure if the proportions are precisely right, and certainly looks a little more detailed and should suffice.
I had also made the rear deck house and the Poop deck structure as well in the same fashion but stalled at this point as I was struggling without any decent drawings of how to set out the deck. I realise there is a lot of equipment that would normally be there, pumps, winches and windlass's and I had no idea on how to rigg the ship. While I knew this was a long way into the build, I knew that I would have to do a lot of preparation that would not be possible once the rigging was underway.
So I spent a lot of time just searching on the net and had all but given up, the hull and parts had sat on a shelf in the front room and it was not until I decorated the room and had to move her, that I started to look again.
This time I had a little more success. For instance, I stumbled accross this site and read through the build loggs and was amazed at the detailed models and instructions that were available, with an absolutely marvelous example of Cutty Sark. The spark was relit.
When I made the new deck houses, I noted that the ships boats sat on top and dads originals were missing. I did remember that they were simple blocks, mounted on slides next to the rear deck house. I did attempt to repeat dads examples, they woud be adequate to display upside down but not in the correct way once I have constructed the bridge structure over the rear deck house, so I drew out skeleton frames based on some drawings i had seen on Pinterest. No compass small enough so all the curves are curtasy of 2p and 5p coins.
I have made 2 lifeboats, 1 jolly boat and the captains gig. Not sure I have the scale right on all of them, and spent a lot of time unsticking my fingers from the superglue, and my planking is crude to say the least. They dont bare close scrutinary, and the planks are very thin. I have no idea what the wood is but is about 0.5mm thick and quite fragile, but once they are all stuck together, they are quite sturdy.
I may redo these, they are my very first attempt at planking, but I will keep these for now. In reality, they would have canvas covers while at sea and may do that, unless my next efforts improve significantly.
Next week, I hope to add some detail to the deck houses, I have some brass rods and tubes that I can use for hand rails. I have a few portoles I bought from an excellent Model shop based in Cornwall. I would be like a kid in a cholotate factory if I ever managed to set foot in there but they are 150 miles from me and would likely get arrested and fined under Covid regulations if I tried. Fortunately, they have an excellent mail order service but to make sure, I order a few examples and if they look right, I reorder a few more.
Just a thought, but has anyone made a ships wheel at this scale, I can buy one but as I have a supply of brass and 1.5mm ply, I was curious to see if this had been done by anyone here.
- Rik Thistle, mtaylor, NenadM and 6 others
- 9
Thanks for the support and the comments, it is greatly appreciated. jlefever, the book is an interesting suggestion and worth looking into, I have searched briefly and found copies at varying prices, but most of the Used copies are missing the drawings/plans and New copies are beyond my budget.
I do agree that it is of great value to have something of your fathers to cherish. I too have a son, so intend that he should inherit something of both myself and the grandfather he never knew.
I have been practicing some of my skills in attempting to recreate some of her boats, they are work in progress and will post images but lack of decent scale plans means I think my first attempt is a bit off in scale. Also, made a few errors in cutting out that have carried through into my planking. so if at first you don't succeed, try, try again.
- 2
Cutty Sark by My Fathers Son - Restoration
The cables came out quite well. I had two grades of copper wire extracted from a Control board for a Boiler, the smallest grade needed ssix strands of wire to create something that was acceptable but the other heavier grade needed just two strands. I spun this using my Lidl Drill and have used this to create the stays for the jib boom.
I have glued the capstan in place and made the rocker for the pump. I will make racks for the handles for this and the bars for the Capstan. The Fairleads are wrong, it is supposed to have one Post and two rollers under the shoulders but I just cant get them in this scale and try as I might, I haven't found a way I can make them. Its something I can look at this in the future as they are easily accessible.
I have also installed the ships bell.
You can see I have used a little bit of artistic licence on the connectors for the Cable stays for the Jib.
Just a bit of a cleanup and varnish required in this area and find out where the deck bolts have to be for the rigging.
