Posts posted by S.Coleman
Great job on the skylights. I've never used that Krystal clear before but it sounds like it's magic. Top work.
- thibaultron and jct
2
Im all in for the changes. As for the carvings......um.
How are you finding the sergal plans? I dare not ask about the rigging plans.
Be Interesting to see how the transom pans out. I'm sure it will be fine. Nice job.
- CaptainSteve, Hennie and mtaylor
3
Congratulations on finishing your build. It looks amazing. Well done. Top notch job.
- Mike Dowling and thomaslambo
2
The next stage to start working on the stern galleries roofs and ornamentation.
The decorative peices around the windows were painted and attached. Abit of bending and elbow grease and finally got them to fit properly. They are of a soft metal.
A 2×5mm strip was bent around the top of what is to become the gallery roof.
The green is actually dyed Wood strips that had to be cut and mounted on the inside of the decorations under the windows.
Last few hull planks and it's onto plank the 2nd deck.
Mamoli suggest the same 5mm wide planks as used on the main deck to be used on all the decks. But I didn't like the look of massive bulky planks on the smaller decks so I raided my stores for smaller width planks.
Also tested heights for cannons at this stage and cut out the 2nd deck gunports ports.
- Sjors, CaptainSteve, coxswain and 1 other
4
- VACorsair, coxswain, CaptainSteve and 3 others
6
- VACorsair, coxswain and CaptainSteve
3
Aha!! Soon let the sawdust fly!
- Hennie, mtaylor and CaptainSteve
3
- coxswain, VACorsair and CaptainSteve
3
3
3
- coxswain, CaptainSteve and VACorsair
3
- VACorsair, CaptainSteve, Sjors and 1 other
4
Thanks Sjors.
Yes from Deep down under.
You are most correct in saying it's not an easy build. It's like a game of chess, Trying to think 2 steps ahead!
I'm sure I have photos somewhere here of some of my other completed builds. I am hoping to bring this build to a good end and not just an end.
My spare room as it lays now. Some built and completed, Some awaiting construction.
- CaptainSteve, WBlakeny, coxswain and 2 others
5
I have just stumbled upon this log. This is something very new and different. Your doing a great job.
I don't know about using balsa for the planking but, Prehaps some thin walnut strips? Something with not much grain showing.
Also I'm not sure how glue would adhear to the clay. Unless you use CA?I've honestly never attempted to do this. All the best and glad you returned.
That is an epic bow figure! It must be time to head outside for some relaxing sanding.
- mtaylor, Hennie and CaptainSteve
3
3
- VACorsair, CaptainSteve and coxswain
3
Here you can see the stern gallery curve much better as I was talking about in earlier posts.
Fitting steelers and starting to sand back gunports. Also roughly marking out next deck gunports.
Planking continues higher up the transom area and planks are sitting on the bulkheads inside to give a rough indication of the next level decks.
- CaptainSteve, coxswain and VACorsair
3
The gun ports look dead straight but trust me the have a very slight curve. Not as much as I would of liked but it's there. Looking along the side you can tell.
- CaptainSteve, VACorsair and coxswain
3
Jolly Roger by KAT
in - Build logs for subjects built 1501 - 1750
Cheers. Sounds like walnut will be best. The glue, I was just wondering if you are sticking Wood strips to the clay model itself. Not too sure how Wood glue would stick too well to clay. Or you might have to use super glue.
