ECK
Everything posted by ECK
  1. More progress today. Mots of the work done. Tomorrow will be painting day, then file out the our holes and then the boat equipment.
  2. Finished planking the buggers. There are 5 ships boats provided, duplicate 24 ft boats but I had to much battle damage on one of them to continue. Have 1 each 32,26,24 and 18 footers. Will take a lot of sanding, filler and paint to get them into shape.
  3. Looks good. I had to fiddle quite a bit as well as taking measurements from the plans in that area not easy given the curve of the hull. I used a piece of wood the correct width as a spacer.
  4. Except for the rails, the hull is done. I used left over gun ports to bring out the sternchasers' appearance. Also remembered to put in the main stun'sail booms by the Being a masochist, I think I will do the ship's boats next IMG_7334.heic IMG_7336.heic
  5. Continuing onward, finished the deck fittings for the stern of the ship. Can see nicely through the skylight. You may notice I removed the stern lanterns as I was always catching and bending them. Will put back at the end. Fitted the carronades You can see I wrapped the wheel with the steering tackle The Capstan lines up nicely and inserted into the lower deck one. Hopefully will finish by the end of the week. I will not install much of the railing as I usually bend it all out of shape when I am doing the rigging. Of course the anchors will also wait until the end. My debate is masts or the ships boats which are always a bugger to do.
  6. Had the same issue as Glen with the stern cleats, likely did not push edges down enough when gluing the deck. Used this to elongate. Then glue and filler Then paint Did the faux wood Final placement Unfortunately the glare makes the stern look a bit off but not in real life.
  7. I just had the same issue yesterday with the stern cleats, followed your lead
  8. Thanks, that's what happens when the nest empty's out, have to do something while binging on various streaming services.
  9. Thanks. Agree with your post on being dogged in doing things. Hard to say good enough.
  10. It took a few days but all the deadeyes and chains in. Used the string method from the mast to get the angles correct. Deadeyes in Chains on starboard side pre touch up Po Post paint touch up with iron black Next will be taking care of the deck pieces to complete the hull. Will leave anchors to the end and will also add the stunsail booms.
  11. Today fitted the knees and eye-bolts then painted it up. You can see from underneath I bent the eye-bolts so they ill not pop out under the strain of the rigging.
  12. Thanks all. I am definitely a few months behind Kevin when it comes to masting, especially as those ship boats take some time and I tend to do them before the masts. Iphone 12 has a great camera.
  13. Completed the fenders, steps and lanterns. Also fitted the channels which went in pretty easily given the pre drilled pin holes and the marks on the channels. Edges have a nice reveal.
  14. Looks good. Had to use some filler as well but after painting will look perfect
  15. Stern area almost done, "glass" panes drove me nuts, kept flying off in all sorts of directions but fortunately did not lose any. Also put in depth markers.
  16. It is nice to see the subtle curves with the copper reflections/shadows, thanks !
  17. Bow done and figure painted and test fitted. Next will be the stern windows
  18. Finally finished coppering. The darn rudder took 5 hrs to do.Got to at last turn it right side up again. Taking a hint from another member, notice the lazy susan turn table I got. Makes moving it a lot easier.
  19. Finally done. I gave 3 coats of poly, taped the edges, poly'd the tape edge, repainted the black wale then re-coated with poly. Next is the rudder which will take at least a day to do given the coppering then fixing it in place. It is a shame that Chris could not get the single copper piece for the rudder, would have life much easier.
  20. Lovely work. I usually do not attach the bowsprit until I am doing the bow stays as I tend to otherwise snag it and break something.
  21. I usually add 3-4 coats of polyurethane over the copper and seems to keep in looking ok.
