Posts posted by Gimo
Hi Clark,
Corel plan is correct. This is how the oars were fitted
In this kind of rowing (scaloccio) the oar is a second order lever
whose fulcrum is at one end in the water and the oralock only does the point of resistence.
The force applied by the oar against the water causes the oarlock/boat to move.Gimo
16 hours ago, fmodajr said:
Hello Gimo!
Thanks for stopping by.
Also I appreciate your input.
So, I checked the model and there are no dips on the left (Port) side. The Longitudinal planks are straight and do not dip.
I do think, however, you are really talking about how the arches sit on the upper rail plank. I noticed that some of the arches reach almost to the end of the railing and some end in the middle. Good catch! You have a good eye! I made the arches 2mm thick, but neglected to grind the tips on some of them to the 2mm thickness. So, after I finish with my current work in progress, I will sand down some of the longer ones and build up the 1st two a little to make them more even going along the side. I didn't think they were that noticeable, but I guess I was wrong. LOL!!
Thanks again for the positive input.
Appreciated! I hope all is well in your neck of the woods.
Frank
Sorry Frank,
I misleaded you with my wrong wording, however you've got my point
cheers
Gimo -
Hi Frank,
I noticed that the first two arches indent slightly on the left side and this makes the longitudinal axes inflected.
I remember I glued two thick (white) stripes on each side of the centerline as guides and "shape constraint",
then I traced/cut each arc a little longer and patiently smoothed the ends as needed.I am somewhat embarrassed to put this in sight but your fantastic model does not deserve such dystonia.
Gimo
La Reale is at my daughter's house now, the same exact of my last post.
Cheers
Gimo -
Hi Kikatinalong,
as your first build you did an excellent job,
I suppose this is the first of two overlapped planking so, make sure that each stripe follows its natural course.
I see two stripes moving away from their bulkheads in the aft (due to lateral tension)
Try to direct the strips towards the upper part of the sterncheers
Gimo- Kikatinalong and mtaylor
2
Hi Mark,
thank you for the appreciation.
Gimo
- GrandpaPhil, Pete38, rafine and 4 others
7
- harvey1847, Canute, mtaylor and 1 other
4
- harvey1847 and mtaylor
2
- mtaylor, harvey1847, AON and 3 others
6
Thank you Pete and Mick for the comments.
For the Bits and Hatch I've used beech stained with "orange stain" and the result is somewhat similar to the mahogany.
Cheers
Gimo.
Reale de France by Clark – FINISHED - Corel - Scale 1:64
Very precise masts preparation. Very well done Clark.
Gimo
