moreplovac
Everything posted by moreplovac
  1. Work on sails started by scanning and printing the copy of sail plan from the kit. Then i cut them all.. Test on the sail cloth that was included in the kit.. appears to have enough space for all.. Now put them aside til i am working on staining the cloth.. The model is also resting a bit ... First i ironed the cloth... Than stained in golden oak stain, must say i do like this stain colour,... a bit messy job... Taking excess stain from the cloth, with a help of few sheets of bounty paper.. Cloth is drying ... Happy modelling..
  2. The rat lines have been completed. Interesting work, must say... It does really test your patience... In the process at topgallant... All completed... During the work process, outer jib boom guy (hopefully have the term correctly) was slightly damaged, enough to bother me so i replace it with a new rope.. Here is process.. And completed.. Now it is time to do some touchups on the model and to start working on sails.... woohoo. Happy modelling.
  3. Ratlines..... and more of them... The template was made following the plan.. and ratlines are tied with a clove hitch. Happy modelling..
  4. During last missing hole drilling exercise, i thought no damage was done. Unfortunately it was.. So instead of starting with rat lines, i will be repairing (or i would say improving) the look of two rigging lines. So, lets fix it... by painting the wood and replacing the rigging line. This is my process to rig a block. Little helping hands.. End result.. The hook is also attached.. Thole new assembly in place. Now the other side has to be replaced as well, so both are matching.. Happy modelling..
  5. Gunter iron downhaul was installed and attached to belayed pin. And a bit more rigging done.. Happy modelling.
  6. There are several holes in the hull used for tight different ropes to belaying pins... not sure if i missed these steps but i have not drilled the holes before. Now it is time to do so.. a bit more difficult that needed be but... mark them first and with little help from longer drill bits i managed to drill 10 holes in total, without damaging other parts. So if you are building this beautiful model, pay attention ahead of time.. Now i am doing gunter iron gantline rope. First started with 2mm single block and made a hook. Simple by twisting the wire at the end and secure it with a drop of CA glue, then form the hook. Hopefully it will hold. Have some challenges making it at this small scale.. Working on the rope.. The length of coiled rope is correct, now i need to make few of those.. Happy modelling..
  7. A bit more work completed.. Had to replace some ropes as i did not like the way the looked... Happy modelling..
  8. The small block has to be removed, sanded and rope grove has to be filled.. The end results: Happy modelling...
  9. Rigging of mainmast stays continues by replacing blocks; it turned out that blocks were not positioned correctly so need to change this.. New blocks.. ..in building process.. Once in place, the rigging can continue... Testing the distance.. Happy modelling..
  10. Continue with rigging... Getting ready for a mouse... Starting making a mouse.. Once mouse is done, it was soaked in the glue to help with a form... and left to dry.. Happy modelling...
  11. I believe it is not but i strongly suggest Phoenix as your next build. Very good kit quality and tons of room for customization.. I also have Syren on the shelf waiting for some other inspiration. Cheers
  12. Work on mainmast rigging continues.... with few corrections on the mainmast itself... Happy modelling..
  13. The foremast rigging has been completed, at least for now... And the mainmast has been positioned... Making sure it stays up.. Happy modelling..
  14. I was distracted by perfect workmanship and maybe missed somewhere the scale; could you pls let me know the dimensions of this fine model?
  15. Perfect work, excellent. Could you pls let us know what tool(s) and what method are you using to carve such a beautiful carvings?
  16. The futtock shrouds are done next. Here is a brief process. For seizing i used few lines from unwoven thread. The futtock shrouds are turned around the futtock stave and seized to the shrouds in three places. Fore and main topmast shrouds are installed next. Happy modelling..
  17. Continue with sheer pole work; this time i made a bit longer so i can easier hold; once the work is done i can just cut the excess and touch up with black paint. Then i put in the catharpins.. Happy modelling..
