Ferrus Manus
Everything posted by Ferrus Manus
  1. Apologies for the stalled progress on this build. I realized an error I will have to fix on the designs for the first 4 or 5 frames- I didn't draw the cutout for the cockpit! Anyways, the show will hopefully continue soon. The keel will be easy to design, as well as the rest of the frames up to the beginning of the stempost. There are, I believe, 4 stempost frames. I do not believe these vessels had any kind of cant frames or hawse pieces. It wouldn't need them, as this is a small vessel. I have changed my design for the shroud turnbuckles- they will be attached directly to either the outside of the hull or the top of the cap rail. I might buy my own pre-cut planking material for at least the deck. I have been recommended a hand planer to assist with the extensive fairing at the bow.
  2. Both members here are right about the flag halyard, but I have always rigged mine at the bulwark, owing to the fact that the boom does not have to swing as far as the gaff would.
  3. @GGibson If he wants to see a list of a specific member's builds, he can just go to that person and ask them for a list. This community is all too happy to show others their builds. I tried your technique, and the issue is someone might have posted in one or multiple non-build log forums, or may be referenced in logs other than their own.
  4. You should probably make stuff like this out of brass in the future, because it's easier to work with and can be chemically blackened.
  5. This might be one of the best looking custom-made fittings I've ever seen on a non-scratch ship.
  6. I haven't found one. If you want to see all my builds, I can give them to you in a list.
  7. Don's wood. The framing, false keel, and likely a significant amount of the planking will be made from Don's wood. He is basically sending me raw materials, and I'm sending them back in the form of a model ship. I will be using a lot of my own materials and fittings, however. I will be buying my own blocks, rigging line, brass, turnbuckles, shackles, chain, cloth, etc.
  8. To be honest, the thickness and material of the stanchions doesn't matter, because they won't be seen under the interior planking. All I need is for them to all be a uniform width and height.
  9. Probably just regular planking. The bulkhead stanchions will be made using Don's wood (I still don't know exactly what type of wood that is, but he showed me a sample and it's perfect for both planking and framing) and I came up with an ingenious idea in the late hours of last night. When it comes time to plank, the upper half of the main wale will extend above the frames, serving as a further support for the stanchions. The stanchions will probably be 1/8 inch square, and a half inch tall. I could also use plastic card for this job, and fill in the rest of the inside area with wood of the same thickness.
  10. Today, we will design the first five frames of the Devin Collins. I began by taking measurements of the curve of the hull (as per the first shown diagram) and calculated the maximum width of each frame, then divided the totals by two. This extra width will account for the material taken from each frame during the fairing process. The transom is not listed as a frame, owing to its outward angle in relation to the false keel, as well as its width being half the width of a frame. Then, I began designing frames based on the measurements shown, as well as the total length from the deck to the bottom of the false keel. Remember, the amount of sanding that will be required on both the top and sides of the frames mean that the less-than-perfect measurements intrinsic in non-CAD designs will not end up mattering. This is also due in part to the relatively simple shape of the hull. The uprights shown on the frames are not part of the frame, but rather a placeholder for the stanchions that will support the bulwarks.
  11. I am hoping to be able to get to the beginning of the frames by later this week.
  12. Your cleat knots and rope coils are the best I've seen in a while. Better than mine!! Good job, Isaiah!
  13. I am thinking I will start the design work for the frames soon. I have looked at various builds of 18th/19th century longboats, which the hull shape is most similar to. I have come up with a general pattern of frame design, based mostly on the longboats of the era. Hopefully, however, we will end up with a unique hull shape.
  14. At this point you're almost done with your brig, so I wouldn't have you change anything. However, for future reference, the rigging instructions for model ships are generally wrong, sometimes egregiously so. The rigging on beginner kits is sometimes simplified to the point of absurdity or complete non-functionality.
  15. Upon reading the rigging instructions for your Perseverance, I can definitively say that you should have thrown them away and went with what other people have been doing on the rigging of their brigs. Soon, you will develop the instinct to know what correct/incorrect rigging looks like.
  16. This is a pilot cutter with turnbuckles used on the shrouds. Note the main wale and the pseudo-channels that hold the shrouds away from the hull. This will likely be what I use on this boat. I might use painted styrene for the straps, but I have not decided yet.
  17. At this point in history, at least on large ships, turnbuckles would have been used for the shrouds. Would they also have been used for the bowsprit gear? Would deadeyes still have been used on small boats in 1899?
  18. Another area of note: the hull was not designed in the late-1800's style, with the straight-vertical bow and the sloping stern. The design for the hull was based largely off ship's boats from the late 18th/early 19th centuries, and pilot cutters of the era used that same hull shape. However, as a later pilot cutter, this design will include more iron strapping and a deck plan more suited to late-19th century cutters.
  19. This is the oyster smack Lizzie Annie, a boat of a similar size to the Devin Collins. This showcases an alternative rig for the vessel, as well as some of the core rigging principles that will be employed. Note the fact that the bowsprit makes up about a third of the total length of the ship, as well as the lack of a topsail. The Devin Collins, as a pilot cutter, will need the topsail as well as the flying jib. Pilot cutters raced for the privilege of offering their services to large ships in the Bristol Channel, necessitating the obscenely large sail area.
