Ferrus Manus
Everything posted by Ferrus Manus
  1. Alrighty. The offending seam lines were mostly visible on the top of the forecastle walls, so I scraped them off with a knife: Then, I scraped the paint off the inside of the walls, and rescribed them with wood grain: I proceeded to fill in the injector pin marks with Tamiya plastic putty: One of the repainted walls: Afterwards, I cleaned up the paint on the front and shaded the gold: The decorative scenes on the forecastle show Greek/Roman square-rigged galleys and galley battles.
  2. These are the painted forecastle walls: These grand totaled about two hours... ...and still more to come. As per Michael D's advice, I will have to go over the top of them with a knife. I got them to the point where the gold mistakes can't be seen with the naked eye, but there's still more to do on the back. There are several injection mold marks that I want gone, and I might even scribe in some wood detail. I remember finishing up the Esmeralda at about this time last year. That took me 6 months. I think that my skills have improved since then in the wrong way. I have attempted to be faster instead of better, and I think it's just a matter of retraining my mind to stop rushing. Time to take a break for a few hours.
  3. The forecastle decks are painted and glued into place: The two painted lower forecastle bulwark assemblies:
  4. I know that the beginning of the rigging is still pretty far out, but I still have to clear something up. Heller swears these things are belaying pins. I've even seen some Corel builders use them as such. However, having rigged plenty of fore-and-aft vessels, this makes absolutely no sense whatsoever. My idea is that these are the ladder rungs to get up into the forecastle. If they were used as pins, there would be no way up. I haven't seen another form of ladder on any version of this ship. For that reason, I will be belaying pretty much all the rope work to cleats or something similar. I even have a relatively solid idea of where all the cleats are to go.
  5. The forecastle area is complete with the exception of the finalization of the 36 pdr's rigging.
  6. While the video shows how to weigh anchor on a galley, it does not show how the anchor cable is stowed. My only guess is that it must be removed and sent to some sort of rope locker, then retrieved when it's time to drop anchor. The video has been very helpful, though.
  7. The next thing I need to do before closing up the forecastle is the anchors. When I dry-fitted the anchors together, I was taken aback by how humongous they are. If they were made of cast iron, surely they would have weighed in considerable excess of a ton apiece. Now, this begs the question: how were they weighed? I see no form of winding gear on board the ship. Not a capstan, not a windlass, nothing. Granted, if a hundred men lined up on the catwalk and pulled, each of them would probably only have to lift 40 pounds max, including the weight of the anchor cable. I want to display the anchors fully hauled in and stowed. This begs a different question: where do you put 60+ feet of anchor line? There isn't much room for it on the forecastle, although that's what Heller says to do. This is how Heller commands one to stow anchor: After seeing the discussion on Michael D's build, my assumption that this was completely wrong was confirmed. In fact, this is so incorrect that the davits on the beakhead would snap under the weight of the anchor if they attempted this. the davits, according to an expert who informed his build, were actually used to weigh the anchors' buoys. The Landstrom book depicts the anchor stowage almost as incorrectly. The only major difference is that Landstrom belays the catting line on the huge timber heads on the forward bulkhead instead of a cleat on the davit, and runs the anchor cable off to some unknown location. This implies the existence of a rope locker on the real ship, but I am unaware as to where it would be located. Back to the anchor buoys- they are included in the kit and mentioned in the very beginning where you are instructed to set them up, but never again. I plan to show them hanging off the bulkheads just outboard of the anchor itself, with the line in a simple coil underneath the anchor, not attached to it in any way. I don't plan on setting up the anchors until I have a clear idea of how the anchor was weighed and where the anchor line goes.
  8. My favorite galley story is that of the two Italian brothers who attempted to find a sea route to India in the 13th century (I think?) using two galleys. They rounded the coast of Morocco and were never seen again, alive or dead.
  9. So, today I started on the work I'll have to do before I close up the forecastle. The first order of business was the gun rigging. Originally, I wasn't going to rig the guns, but since they gave me two out of the three sheaves I needed (and then didn't mention gun rigging in the instructions) I figured I might as well. I bashed together another sheave for the 36 pdr, then got to work. The interesting bit was the rigging of the 36 pdr. I drilled two holes for the ropes in the front of the gun carriage, inserted eyebolts, tied on the ropes, and did the exact same thing I did for the 24 pdrs. The interesting thing about it was the fact that the ropes run to the catwalk, which means they actually travel upward from their sheaves.
  10. Interestingly, there is a thole pin where the cooking pan is. Would there simply have been an oar/seat assembly that could be removed for cooking?
  11. The apostis assemblies went on far easier than I expected they would, given the imperfect alignment of the supports. The next job is to glue on the rest of the anchor equipment, followed by more decorative stuff at the stern. The ladders will be saved for the very end, as I don't trust them not to break off.
  12. The stern lantern and flagpole: And the ship's guns, surrounded by the forecastle deck timbers:
  13. Louis is the Sun King, so sunglasses might be appropriate. I guess it seems obvious that his ships would reflect his title.
  14. Even after reading the thread, all I can assume is that you mean "ornamental decorations at the extreme aft"...
  15. I have considered the idea, but gave it up as it wouldn't look the same as paint in other places, and would likely run down to the bottom, ruining the paint job. The pictures show several errors that can't be seen in real life.
  16. That is, unless I had just glued the one side more poorly than the other. Either way, the problem was solved. I learned that most things that weaken CA also melt polystyrene (including acetone) but there was no visible damage. 3M makes industrial chemical products, right?
  17. The painting at the beginning of this build log depicts multiple other figures, plus Triton and the angels, all of which are painted gold.
  18. I was blissfully unaware when choosing the paint scheme for the stern, that the extreme aft of the ship would end up being mostly light blue:
