Everything posted by Ferrus Manus
I guess i had simply failed to understand what you had planned to do.
- 1,508 replies
- Le Soleil Royal
- Heller
That's the same reason i decided to forego the parrels on my galleon; not enough space.
- 1,508 replies
- Le Soleil Royal
- Heller
I see what you did with the sail on the first one. This time, i would recommend putting some kind of glue on the sail before it's rigged, so you don't have to fix it in place with a wire. Even better, i would remake the sail using silkspan.
- 134 replies
- sea of galilee boat
- SE Miller
I could probably find you something on how exactly parrels are rigged, if you wanted.
- 1,508 replies
- Le Soleil Royal
- Heller
Also, you could definitely do the parrel right if you wanted. There's certainly enough space there, and you could definitely find or make a belaying setup. If you want to do the parrel as it would have been, refer to the point at which i explained parrels and square sail tacking in this log.
- 1,508 replies
- Le Soleil Royal
- Heller
Moreover, if footropes did exist, they would probably have been tarred black lines.
- 1,508 replies
- Le Soleil Royal
- Heller
I'm pretty sure the footrope hadn't been invented by that point. Can someone else verify this?
- 1,508 replies
- Le Soleil Royal
- Heller
Nice forestays, and amazing ratlines!
- 177 replies
- Perseverance
- Modellers Shipyard
Perhaps those were the same type of ships that bore the Sea Peoples to the Late Bronze Age Eastern Mediterranean, and the rest is history.
- 30 replies
- roman
- merchantman
You're right, Roger. That's why I am doing this mostly for fun, and plus, it's useful for my scratch projects in the future.
- 508 replies
How would you possibly be able to construct a shell-first carvel-built ship? At least with clinker-built ships, the overlap of the planks provides a general direction for where the planks should go.
- 30 replies
- roman
- merchantman
What i find interesting is that this is probably the same type of ship that St. Paul would have traveled to Rome on. Granted, that ship would have been constructed in the first century AD.
- 30 replies
- roman
- merchantman
This is a picture of the Vasa that i have significantly edited in order to make the lower planking more visible. I don't see any drop strakes. The below-waterline planking is nearly impossible to see clearly in any photo i've seen.
- 508 replies
The Mataro Carrack shows no drop planks either, although the planking goes up into the lowermost wale. The one singular thing the Amati kit got right beyond the overall look of the ship.
- 508 replies
Mathew Baker. Can you identify any drop strakes? Grab your magnifying glass and photo editing tools. Neither the Newport Carrack nor the Contarina 1 yielded me any results. What sucks is that the outer planking for pretty much all of these ships has rotted away. It seems as though the Mary Rose has a sort of prototypical drop strake system. However, good luck finding a picture of the outside of the actual hull. This reconstruction of a Venetian medieval ship shows stealers at the stern, but no drop planks. Imagine banging your head against a brick wall because your friend wants to plank his model a certain way. Couldn't be me! Until an intact shipwreck is found, which it likely never will be, we will never know. Someone's interpretation has got to be correct.
- 508 replies
I have seen Amati Coca's with drop strakes, and while it looks nice, i don't think it's accurate. Maybe we should start a new debate/controversy on MSW? The bottom line is we have no evidence, so either way can count as valid. Don't you love working with practically zero evidence outside eight-hundred-year-old buried shipwrecks and inaccurate art?
- 508 replies
I will not use drop strakes on the Senora Fielden. I will, however, use stealers.
- 508 replies
I have never seen a period drawing or engraving of a ship of the time with drop strakes, and never seen an honest reconstruction with them either. It wouldn't be bad if it's painted and you can't see them. Go ahead!
- 508 replies
Are you sure drop strakes had been invented by that point? I heard somewhere else that they were a late 15-early 16th century invention, or later.
- 508 replies
Probably not. If you could somehow display it in the middle of the room (if your wife will let you) it would be possible for it to be seen from both sides.
- 1,508 replies
- Le Soleil Royal
- Heller
If the ship were engaging another ship in battle when the two vessels were side-by-side both travelling in the same direction, one side's guns would be open and firing and the other side would be closed.
- 1,508 replies
- Le Soleil Royal
- Heller
