Everything posted by Ferrus Manus
It definitely looks like the standing rigging is done. Good job! Now you have an insane amount of blocks to strop.
- 1,508 replies
- Le Soleil Royal
- Heller
This is the proposed size and shape of the gaff topsail, laid out on the table. Jackyard topsails were the largest variant of gaff topsail, and often rivaled the size of the main gaff itself. Racing yacht riggers used them to legally increase the sail area of their ships via a loophole in racing rules, hence their prevalence on the racing yachts of the early 20th century.
Are we able to see it on the ship?
- 134 replies
- sea of galilee boat
- SE Miller
Today, i got the first sail bent. I cut it out by eye, trimmed it down, and then made a stupid mistake. I lashed the sail to the yard and boom, which i painted yesterday, before i remembered to stain the sail. I went for it anyway because why not. I poured myself a cup of coffee, but the coffee wasn't for me. I dipped the sail, spars and all, into the coffee, not knowing if the hot liquid would strip the paint, which would mean a junk sail and a second paint job. Luckily, the paint didn't strip. For "jaws" for the gaff and boom, i simply tied a rope around the end of both and tied the ends around the mast. I made "mast hoops" by running a line through the head of the sail and tying it around the mast. Here is the finished result, minus gluing and trimming the knots.
I meant that thing that looks like a mast with a sheave in it that's sitting in the far background, up against the back wall of your workspace and partially obscured by the sheet you have protecting your workspace.
- 134 replies
- SE Miller
Will you end up making a calcet (sheave piece on the mast) for the yard's lift? Edit: I JUST realized you're making... another boat? You had two kits?
- 134 replies
- SE Miller
The mast definitely looks better. I had to compare it to the first photo because my eyes initially failed me. You could probably, if you have a drill, make a custom lathe out of that. Your life would be made way easier.
- 134 replies
- SE Miller
Remember the fact that typically, boats and ships of this time had pretty spindly masts, that were held in place by thick backstays. It looks like you've turned it to a smaller diameter on a lathe. It looks better than it was, perhaps it's just the angle.
- 134 replies
- SE Miller
Hey, what's the mast sitting against your wall? Is that an alternative mast for the boat?
- 134 replies
- SE Miller
I installed the mast step and bowsprit step, and glued in both structures. This is intended to be one of those boats that looks like it's just spars, with the actual boat being kind of an afterthought. Sort of like this smack, but slightly more extreme. It will have a sloop rig with a jackyard topsail.
Steven, if i had to give my input, i would tell you to probably just do what Woodrat did with the rudders on his Nave Rotunda. At least the side structures, and maybe you could plank outside them as shown in the images.
- 508 replies
