Posts posted by HIPEXEC
Better safe than sorry. Wear a mask and eye protection for heavy sanding operations. You never know what's bad for you!
I'm enjoying your build. Nice work!
Did you pin the steps as well as glue them to the hull?
I haven't even heard back from Constructo?
In the meantime I'll start fabricating the channels for the rigging. They will be 9.5mm deep by 3mm thick. Any ideas as to how to strongly attached them to the hull? I assume some sort of pinning along with glue, but I must place them very accurately to avoid running a shroud in front of a gunport.
Oh well...I have to obey orders. I do have some small items I can attend to on my ship while I make my area ship shape. Oh, Sjors, thanks for the varnish removal tip. Do you sand it off?
It would be great if everyone posted some photos of their work space. I'm definitely going to upgrade mine now.
Wow! I picked up a lot of good tips here. Good forum.
Construction has come to a halt while I try to get 2mm x 2mm Ayous (blond) strips to finish all trim. I seem to have run out and just e-mailed Constructo to see if they can send me about 500 to 600 mm.
VARNISH?
Do any of you give your model a light coat of varnish before the ship is finished? Constructo's instruction book says nothing about it, but the pictures show a dramatic change in the finish right about the stage I'm at.
Any thoughts?
Thanks,
- src, augie, MarisStella.hr and 5 others
8
- Aussie048, src, MarisStella.hr and 3 others
6
I'm going to copy your pins when I put the lids on my USS Constitution's lower gunports.
- justsayrow, Karleop and augie
3
These windows will be permanently installed down the road. They will have clear panes installed and then the glued windows will be trimmed. I'm starting on the bowsprit next.
Here's the port gallery window rough fitted to my fix for the forward part of the gallery. I just shaped hull planks to match the shape of the gallery so I could move the pre-cut windows forward. Now I just have to make a trapezoid shaped piece to compensate for the angle error I made with the transom.
I'm starting on the bow area and discover that Constructo gives no detail instructions or detailed prints to follow. There are no pre-cut parts, so I have to figure out how to fabricate complex, curved pieces out of a dozen straight planks. They give no start points....nothing....very frustrating since one mistake and I usually run into a problem down the road because I didn't size or place something right.
Thanks! I'm going to leave it brass. I'm not going to paint anything on this model.
USF Confederacy by Augie & Moonbug - FINISHED - Model Shipways - 1:64
Your ship gets better every time I look at it! Nice work! and thanks for all your tips.
Rich
