HIPEXEC
Posts posted by HIPEXEC
  1. Here's how I'm bending trim 1mm x 5mm  planks for the curved bow pieces. After a 15 minutes soak, I placed them side by side in the jig that came with my heating iron. I placed some smaller plank pieces over the parts so as not to mar them with the clamps, then slowly increased the bend until they lay flat against the curve of the jig. Now they're drying. When dry, I'll cut & trim to fir, then glue them. This is my second try, since the clamps made marks on my first attempt.
  2. This is how I bend & shape & mount my fore toprail. It's two double 2mm x 2mm pieces bent & glued. First I soak the wood in clean plain water this time, then clamp them to the cutout from the false deck, which is close, but not net shape. Then I fine tune the bend in my jig. Then cut to fit with my miter box & glue. This piece was not pinned since it will have side supports to stabilize it
  3. I'm slowly installing the rails & trim  (pinned & glued) to the aft half of the ship. Constructo's use of 2mm x 2mm pieces, two across and three across, makes for interesting rails. I'll have to fill them in before varnishing. I'll start on the bow section next, but with its severe curves, It will be harder to trim. The bow stem fits pretty good, but that's because I worked on it for days right after I planked the hull.
  4. Now I'm trying to get net shape curves for the bow top rails. My jig only got me almost there, so I'm trying something new. I am using the cutout from my false deck as a jig and clamping the 2mm x 5mm planks to it in the exact shape needed. I soaked everything for 30 minutes.
    As far as the 2mm x 10mm bow pieces go...I'm trying an extreme bending method. I'm using my heating iron jig and some vice clamps. I'll either break them or curve them. Time will tell.
  5. While I'm trimming the aft toprails, I figured I'd stay ahead with the bow toprails. Wow! Trying to bend 2mm x 10mm Sapele that  is harder than bending steel. At least steel is bendable. I only have to put a slight curve on them, but they don't seem to budge. The rest of the toprail is 2mm x 5mm and bends easier (not easy) the the 10mm stuff.
    The 5mm stuff is being bent on the jig I built for planking the hull. The 1mm stuff is being bent on the form that came with by heating iron.
    We'll see?
