Posts posted by HIPEXEC
Never mind. I finished the rudder.
Thanks.
Whew! I finished mounting the rudder. Thanks for the tip of doing the top & bottom hinge first. It really helped. I used a drop of crazy glue in each hinge and set the pin so it wouldn't keep falling out while I tried to mount it to the hull. Then I used a wood sliver as a wedge to keep the hull hinge full deflection so as to make a tight fit while I nailed it. It worked. About every third nail bent and had to be pulled out.
- Sjors, dgbot, CaptainSteve and 2 others
5
- Karleop, justsayrow, usedtosail and 7 others
10
I'm glad I'm not the only one who uses clothes pins.
Got the DEVCON 5. How long is that stuff good for after use?
Thanks for the tip on epoxy. What brand is best for our type models?
Here I am working on the rudder. It isn't any easier than my first model...it's probably twice as difficult. The hinges Constructo provided are not the right size, so I have to straighten out and then re-bend them to fit a much thicker rudder.
I made the simulated plank effect with my miter box saw. It made very nice and straight cuts that really look like I glued together three planks.
Also, the pin material they provided is way too thick, so I had to scrounge up some smaller stuff. Since I can't seem to make absolutely square bends when I re-bend the brass, I compensated and rounded the rudder to accommodate the slight roundness. It seems to work, but I've been at just one of four cuts I have to make, so I'm planning on two more days at this.
I'm not complaining, it's just my Admiral keeps asking when I'm starting the masts and rigging??? She has no idea what it takes...?
A sharp 32 pencil did the trick for me. I even had an experienced model builder think I actually nailed the planks.
What's the best glue to fix the metal hinges to the wood rudder?
Making the hole for the bowsprit was harder than I thought. I made most of it with my hand drill making the hole larger and larger. But, I had to very carefully finish to the full 8mm with my Dremel. I don't like putting power tools against my hard fought hull, but I had no choice. Anyway, it worked out.
Thanks everyone.
Rich
I just glued the first of two curved trim pieces on the transom. Constructo wanted me to glue a shaped (by me) 1mm round brass wire for these. I couldn't see how a round wire would stay glued on, so I made these out of 1mm x 1mm blond wood. It took a bit to get them bent just right, but this is my solution.
I need some help mounting my rudder hinges. They're tricky to handle and gave me a fit on my first build.
Thanks,
I filled tiny gaps by making sliver planks and glued them in small gaps. I did better with that than homemade filler (sawdust and CA).
Looks real good, though!
HELP!!!
I need some tips and tricks to mount a rudder. I had a real tough time getting the rudder on with my first build. Couldn't seem to keep those hinges nice and lined up. Also the nails are too long.
Anyway all help is welcome.
I need some tricks and tips on mounting the rudder. On my first build that drove me crazy.
Thanks, Rich
After I finish trimming the wood parts on the transom, I'm going to take a break before tackling the whole bow section since it is chuck full of complex parts I must fabricate myself since there are no pre-cuts. I'm going to take that time to micro sand and scrape all the glue smudges I've left in my wake. I will also fill in many of the small cracks and voids left while I plunged ahead to get to this stage.
How did you get the black background in all that fancy scroll work?
USS Constitution by Hipexec - FINISHED - Constructo - 1:82
Also....I'm thankful the ship only has one rudder.
