willz
Posts posted by willz
  1. Just finished the stern on my own build and thought it looked well but seeing yours makes mine look rubbish ,but i still ain,t redoing it ..Your carving skills are to be envied , by me anyway , tried my hand at it and finished up buying the brass docors .
    checked out your stern shihawk and its looks fine, commercial parts are nearly always a let down but you have cleaned them up super, as for the carving you must use the correct material, I purchased some boxwood and like you had a go, took a couple of attempts to get the hang of it and although not perfect they look ok, here`s my version of the right hand strong man and the view through a macro lens shows all the errors but when looking with the naked eye he`s acceptable.
  2. Thanks all for your kind coments, small update, finished the first planking of the hull, cut out all the gun ports inserted the linings and filled in all the gashy bits on the ports side, the quarter galley doors have had the linings inserted and left slightly proud so as to let the second planking butt up and then be sanded flush, all prep work finished on this side, started work on the starboard side but still lots of work to do ,cheers
      William
  3. William,
    Once again - very nice. :) I have not managed to pluck up the courage to make my own cannon barrels - yet.
    An interesting point of comparison. I note that you use a three jaw chuck to grasp the dowel without apparently denting the wood. Whenever I did that I always got indentations in the wood. My own answer was to use a collet instead - or to turn up a collar with a longitudinal slit to hold the dowel.
    Ian,  its true the jaws do dent wood, so everything is oversize to start with, so the fininshed product has had the marks turned out of them.  cheers William
  4. Looks like a great start!  Did you find the laser level helped with the alignment?  Have been toying with the idea on my builds as well.
    hi Wayne, yes the laser was very helpful, with it being a scratch build, i cut the rib slots slightly wider than the false keel to give me some side to side movement, then with the keel plumb inserted the ribs keeping the centre line of the rib in the middle of the keel and then setting the line on the top strap to the laser, putting in a top strap with a centre line makes sure its bang on, also the top strap gives the ribs much more strength for fairing, planking e.t.c., when the time comes the top strap will be removed. cheers
  5. Hello William,
    You are off to a good start.
    Will you be using filler blocks for the bow to support your planking?
    PS - yes, it is normal to be 'off the boil and back again'.
    It happens to us all once in a while.
    Good luck with your build and enjoy.
    Anja
    hi Anja, no, didn`t use any filler blocks and already started the planking, although i curved the planks round the bow when fitting i noticed that they later tended to lose the curve and judder round the bow, oh well we live and learn,  cheers
