willz
Posts posted by willz
- thibaultron, Canute, mtaylor and 10 others
13
as for the balustrades Greg i have dabbled with them, the problem is that they are not round and they are all cut at different angles. so heres a couple of pics of the different shapes, one is of the centre balustrade next to an ordinary pin for scale the other is of the centre balustrade and the other is the extreme right one
rules there is no rules
- mtaylor, Chuck Seiler, gjdale and 6 others
9
- Ryland Craze, Mike Y, GrandpaPhil and 6 others
9
- Jack12477, aviaamator, Canute and 6 others
9
All my carvings are made of boxwood
Ok lads n lasses, the stern band. I thought a lot about how to do this, it seemed to me to be very tricky to get right with its symmetrical and fragile shape but when I came up with this idea of how to make it it turned out to be the easiest piece i`ve carved.
The band passes under the stern emblem in the centre, this allowed me to make it in two pieces
- Canute, Mirabell61, aviaamator and 9 others
12
- Mike Y, mtaylor, aviaamator and 16 others
19
- John Allen, Jack12477, Patrick B and 4 others
7
i would glue a piece of paper with pva to the mounting block then glue your piece to the paper again with pva, after you finish you just leave it in water and your piece should fall away. i havent tried this method but i have never used a mounting block, i just dive in and carve
all i use is stanley blades, i sometimes grind them into a more pointed shape if needed and i do sharpen them. i use a diamond stone.
- Canute, mtaylor, thibaultron and 1 other
4
I havent posted on here for over a year but my build is still going, it is my first scratch build, a 1/72 HMS Victory. My problem lies in the lack of challenge, It all started with a monthly subscription of the AL HMS Victory 6 years ago, it was well advertised in Britain. Started the kit along with many others at the time on a slowly but surly monthly build, time went by and I started to feel a lack of challenge that I was expecting from the kit, so I bought McKay`s book and jumped into a scratch build.
I decided to make it at 1/72 simply because I could buy 3rd party cannons anchors and all the stuff I couldn`t make, as I merrily carried on with my build not hitting any problems. So I decided to have a go at making the cannons, turned them out of ebony and found yep I can do that.
So thinking a little deeper I split the cannons in two so I could build the entire cannons on every deck then remove the bit of the barrel that sticks out any replace it when the build is finished. Then my old mate the LACK OF CHALLENGE was again tapping on my shoulder so OK going to have a go at carving the stern decorations and again did that, next carved the figure head, built a the barge with anchor and oars and again no challenge, so as the challenges fall so does my enthusiasm.
So advice for a beginner… dont think one day, right gonna build a wooden model ship, no keep the idea in your head and let your enthusiasm grow, and when your really keen and ready thats the time to jump in, as for the rules there is none. Pick as big a scale as you can this makes the detail much easier but keep in mind the space you need to build it, another point is the time it will take to finish the build, the longer it takes the more your mind will go through different phases, so I think a 3 to 6 month build would be ideal, one last point and I use this one, is if you find you need a break, cover you build up with a towel, this stops you catching sight of your model on a regular basis, then when your ready to start again, you will find removing the cover will give the model a fresh look..
- John Allen, mtaylor, Elijah and 10 others
13
i found that when things go wrong on the model and it gets you into a state of complete frustration a nice big hammer comes in handy
- pompey2, muzzleloader, daveward and 4 others
7
Had a break and starting to delve back into it !!! Started to tackle the ships wales ! found this very tricky on a natural finish ship. I’m using two types on wood to create the striped pattern, the difficulty lies in the fact that the stripes don’t follow the wales, so ended up splicing some of the anchor stock shaped wales together ( the ones that overlap the striped pattern), one photo shows one centre wale spliced and the other shows the same wale fitted .
- GuntherMT, davec, AnobiumPunctatum and 9 others
12
Since the scales for model building are given in a couple of ways (1/8" scale or 1:96 scale) it sometimes becomes necessary to find the ration (1:96) from a fractional inch (1/8").
The method Stuntflyer shows takes the fraction (1/8) does the division to get a decimal (0.125). Since 0.125" = 1 foot at scale, and not sure why this works but it does, divide 12 inches per foot by the decimall (0.125) to get the ratio 1:96 (1 inch scale = 96 inches real).
Also works for other scales -
1/4"=1 foot becomes 12/0.25 = 1:48
3/32"=1foot becomes 12/0.9375 = 1:128
1/16" = 1 foot is 1:192
1/2" = 1 foot is 1:24 and so on.
This may not work as neatly when converting metric - haven't attempted that part yet!
understand now, sober today lol
i may be stupid but it doesn`t make any sense. for example ratio for 1/8 of an inch = 1/125 but the ratio of 1/8 of a foot is still 1/125
dont understand this one but 1/4 = 1/25 so 5/32 = 1/64 so if you building a model thats 7/32 of the real thing then the scale would be 1/4571. you simply divide the second number by the first, but not quite sure if thats what your asking
I take it that the split cannon is so that you can add them later so that they are not in the way while you complete other tasks.
The stern details are very fine work.
Michael
correct Michael, some kits have full decks all through the ship and it seems a shame to block them out with dummy wall cannons, i did a tutorial on the AL Victory to make dummy cannons out of the material supplied for the dummy walls and the dummy cannons, here`s the link http://modelshipworld.com/index.php/topic/2704-dummy-cannons-by-william-butler/#entry73179
- mtaylor, Jeronimo, GrandpaPhil and 1 other
4
cheers all for the comments.
OK on with the build, started the second planking on the Vic had to replace one plank but apart from that all going fine, at this point decided to try in my split cannon, as you can see by the photo there is no need to up the detail on the carriage , i`ve looked from all angles and happy with it
Great job, William, on those figurehead people. I had a fun time doing them at 1:96. Very hard to get them to strike the right attitude. Also, beautiful work on the stern galleries. Looking forward to seeing the 138 balusters.
All the best,
Ed
your right Ed thats a lot of balusters to carve, you are one of the few who counted them right, heller got it wrong and the great longridge also miscounted unless there`s been a change somewhere down the line
WDButler carvings
in Build Logs for the Carving Group Project
hi Moxis, dont have much on the main emblem on the stern, but found a few pics finishing the left hand side as you look at it, as i go i use a wet toothbrush for cleaning the piece
