marktiedens
Everything posted by marktiedens
  1. Frank, My thought process is not always correct,but I didn`t want to try installing them after the rigging. My thought is since they are made of metal they would better survive a bump or two even though the posts are wood & only 1.5 by 1.5mm. If they were wood I may have waited until at least some of the rigging was done. I think I would be more likely to snag some of the rigging trying to get my hands around the shrouds & other lines. Thanks for your nice comment also. /Mark
  2. Alittle progress - made the odd looking pulleys that mount to the front of the mizzen chain whale. Also installed the catheads - I`m not going to try and make the little guy in the cage that sits under the catheads. Also made & installed the upper hand rail - I made them from some .8 by 1.5mm brass bar bought from my local hobby shop. Now I will have to be careful not to break them off . Also got the rest of the figures installed. /Mark
  3. Thanks Frank. Although some people don`t like the look of walnut I think it looks pretty good on this particular ship. Also my low tech camera doesn`t really show the true colors - the browns always seem to be a little on the red side. Maybe it`s my light source . /Mark
  4. Thanks Edwin. I see that I also have a few more figures to paint & install - almost forgot about the little sea monsters that go on at the breaks of the railings. /Mark
  5. Looks like a good start - you are braver than me to build this with no plans. /Mark
  6. Another little update - all the guns & lids mounted. After re-sizing the upper gun ports the lion heads on the lids were a bit too large,but they will have to do. /Mark
  7. Thanks Michael. The chainplates are fastened close to where they should be but the chain whales should actually be mounted on top of the whales instead of above them, but it would make them too close to the chainplate fastening point so I mounted them above. /Mark
  8. Thank you very much Edwin. Yes,we all benefit from other people`s tricks & tips. /Mark
  9. A little more progress - chainplates mounted. The kit deadeye strops were made from wire bot the strops on the real ship are flat bars so I modified them. I filled the gap with epoxy & then filed it smooth to look like a flat bar. I must thank Michael (md1400cs) for this idea. I think they came out pretty good. Thanks for all the looks & likes / Mark
  10. Hi Josh - I used a small hand plane to turn the square into an octagon & then files & sandpaper to make them round. A little time consuming but it works pretty well. You can also turn them down on a lathe if you have access to one. It may not work to well in a lathe if they are warped very much. /Mark
  11. Hi Frank. Another pictorial reference I have used is Clayton`s scratch built Vasa web sight. It may not be 100% correct in light of the latest findings but it is pretty close. https://sites.google.com/site/clayton707/swedishwarshipwasa /Mark
  12. I have also built this kit & made plenty of mistakes - chainplates at the wrong angles for one. I didn`t even rig the guns . Yours looks very nice to me. I have a few pictures in the gallery if you`re curious. /Mark
  13. Thanks Frank.I tend to be over critical of my work. /Mark
  14. Nice work Frank. I have always done the shrouds before fastening the yards but your way may be a little easier.I am now trying to decide whether to add belaying pins to the crossbars between the bitts next to the main & fore masts. Someone on the Vasa forum said these crossbars did not have belaying pins. I don`t know how they would belay the lines without them . /Mark
  15. Thanks very much Nigel. Although I am not totally satisfied with parts of the build I will continue on. I am looking forward to you resuming your fabulous work. /Mark
  16. Update - finally got all the weather deck guns rigged. Also got most of the deck fittings in place including the slightly modified capstan. Thanks for looking. /Mark
  17. A small update - started rigging the guns.I am using Chuck`s nice little 2mm blocks. The blocks are really nice but also really small - I don`t know how he makes them so small and yet so nicely shaped. They are a bit difficult to handle but I am slowly getting them done. /Mark
  18. Great looking sails,frank. If I do sails at all they will be furled - I don`t have a sewing machine to make all those simulated seams. /Mark
  19. A little progress.........Most of the bow figures done. I may start on the guns & port lids next - tired of painting.Need to make some sawdust! /Mark
  20. Looks similar to the Half Moon - maybe you could modify that kit. /Mark
  21. Thanks again Frank for your eagle eye in spotting my mistake.It`s funny how I can look right at something & still get it wrong . /Mark
  22. Thanks Frank - I have corrected the placement of the tall figures on the sides of the upper stern . I had them on the wrong sides. /Mark
  23. Update - finally got the stern finished.Corel only gave 2 knights to stand guard by the windows in the stern & they were way too tall to fit in the space provided so I used some of the extra figures in the kit instead.They are just a little bit short but at least there are 6 instead of 4.Also built the front railing - I didn`t like the dolphins the kit provided so I used some nice columns I had in my spare parts box.Also built the knightheads while waiting for paint to dry.I don`t have a milling machine so I tried to make the sheaves by drilling & filing but that didn`t work too well so I made them by laminating a number of thin strips glued together to form the sheaves. Then I cut some thin pieces off a dowel to make the pulleys. Not perfect but they look good from a foot or two away. /Mark
