SJSoane
Everything posted by SJSoane
  1. I have been pulled out of the workshop by other stuff for a while--don't you hate how that happens?--but back to it! Thanks, Gary, I added those additional pillars: It is a little tight on the tiller, I may have to trim it back just a bit. And the one just forward of the fore riding bitt has to miss the square hatch on the gundeck, so it stands just aft of the beam in the upper deck above. Maybe it just ran up to the deck above, or maybe it was longer and bolted to the side of the beam above. I am showing the carlings under the stove in the section above, but they are on the sides, not the center, so they don't interact with the central pillar. Or maybe the pillar at this point is two, so it can sit under the stove carlings at this one location? druxey, thanks for that photo. If it is indeed a single hole with a hood, then I guess they didn't originally worry too much about chafing. Because the initial sketch you sent, and that I redrew for the Bellona, clearly shows the rope will traverse back and forth from the wheel. Interesting! My photo of the original Bellona model frustratingly shows no detail here. This issue shows how a technological invention--the steering wheel--had to be adjusted over time as experience showed some of the shortcomings of the original version. Happens at light speed today, much slower back then. We might have enjoyed a slightly slower pace of life! Mark
  2. Wow, those are beautiful, Gary. I see why you chose this one. And I see it has a smooth, serpentine curve on the stern balcony, just like the original Bellona. The later Bellona brought the balcony in to a sharp corner at the frame ends, which I don't think is as graceful as the one you and I will be building. Mark
  3. Gary, Thanks so much, I completely forgot about that image of the Ajax. I used that to map against the Bellona gundeck framing, and with the exception of a beam or two not the same, they pretty much line up. The pattern seems to be this: no pillars aft of the mizzen mast, because they would interfere with the tiller. A single row in most places, except around the aft capstan and the hatches around the mainmast. They match up to every beam in the upper deck, needing a little offset on the gundeck in order to center on the upper deck beams. The only beam that cannot get a pillar is the one directly forward of the riding bits. The gundeck and the upper deck beams are too offset to match. thanks so much, Gary, you really helped me figure this one out! Best wishes, Mark
  4. Hi Gary, I see you changed the name of your build to HMS Montague/Alfred Class. I am curious, since I don't know the history of this class. Was the Montague before or after the Alfred, and were there major differences in decoration, etc.? Best wishes, Mark
  5. When in doubt, look at the original source! I wish my brain worked better in retirement.... Here are my own photos of the Bellona first model. The pillars clearly run down the center, except where the center is interrupted by capstans, bowsprits, etc. And heads are always aligned with a beam, whereas feet can land on the binding strake when the beams do not line up. I guess I will just start plotting logical locations based on this observation, and see how things turn out! So now we know, a 74 primarily uses a single row, a first and second rate use two rows. Best wishes, Mark
  6. I finished cutting the upper deck beams this morning, looked at the website, and discovered a rich conversation going on here. Thanks, everyone, for participating in these endlessly fascinating issues in the design and decoration of mid century 74s. Gary, the section of HMS Glory gives great detail on the pillars and much else. Thanks, I had not seen this before. I also looked at John McKay's Anatomy of the Ship for the HMS Victory, and his drawings seem to agree with the Glory section regarding the pillars. In section (p38-39), between the gundeck and the middle deck, there is a pillar for every beam in the upper deck framing, stopping just aft of the mizen mast, and just forward of the foremast. This is to avoid the manger and the tiller. Most of the time, the beams of the two decks do align, and so the pillars go from beam to beam. Sometimes, they are offset a bit, and the head of the pillar still aligns with the middle deck beam, but the foot sometimes lands on the binding strake, not the beam itself in the gundeck framing. And there even appear to be some crooked pillars, like a lazy Z, that connect two offset beams to each other. The locations are more spotty between the upper deck and the quarterdeck/forecastle, I need to study more the rationale for this. The Victory clearly has two rows of pillars. It's beam is 50'-6", while the Bellona is 46'-9". Could 3'-9" less span in the Bellona mean it could have gone to one row down the middle? Still so much to figure out! Mark
  7. While taking a break from the monotony of cutting beams, I started to look at the relationship between the beams of the gundeck and the beams of the upper deck, where certain things have to align, like the main bits, bowsprit step, etc. This then caused me to think about the pillars for the first time. I don't have a clear idea of where they are positioned. Brian Lavery's book on the Bellona shows them down the centerline of the hull in a cross section on page 42, and in a perspective cross section on page 43 he shows two athwartships next to the capstan; but he doesn't show any of these in plan. The contemporary model of the Princess Royal in Rob Napier's book has two rows of pillars on the middle deck, running down either side of the hatches, etc. But there are none in the fore or aft ends of the deck. And none I can see between the upper deck and the quarterdeck and forecastle. There could be two rows as opposed the one Lavery primarily shows for the Bellona, because the Princess Royal is a larger ship. Also, these are supposed to bear on the deck beams, but not every beam on my upper deck aligns with a beam on the gundeck. So are pillars omitted in these places? Do the pillars sometimes go down the center where there are no obstructions, and then shift to two athwartships where there are obstructions? Has anyone seen more evidence of where the pillars are located on a 74? Just asking for a friend....😏 Mark
  8. Hi JD, Yes, I used to live in Denver, a short distance from a Rockler Woodworking store. But now I am 850 miles away... I am glad you found the jig interesting. here are a few more details: The two template edges were formed by rough cutting the curve of the beam roundup, top and bottom, then using my sanding sticks of the correct radius to refine the edge. The sanding sticks themselves were made by cutting the arc of the correct radius through the middle of a piece of maple, then sandpaper was put on one surface to sand the other, and then the sandpaper reverse to sand the first surface. Gives perfect, smooth arcs. I then attached the template with hinges to the base that runs along the router table top. The white screws allow precise adjustment to the desired angle of the template for the sheer of the beam in cross section. Stops screwed down to the template are used to position the blanks before cutting. The edge of the stop on the convex edge of the template is straight, because the blanks are originally straight. I cut this edge first. The concave edge stop is shaped to the same roundup, because the just-cut blank now has the correct upper surface. The distance from the edge of the template on the concave side to the stop is the exact moulded size of the beam. I rubber cemented sandpaper on the template in front of each stop to give more friction to the clamping. A top sheet is then clamped down on the blank, with a temporary spacer at the opposite side of the template to achieve even clamping on the blank. Because it is so easy to insert things backwards in the monotony of doing the same thing over and over, I labeled each blank with which edge is the top curve, and also which surface should be up in the jig. I religiously check this before clamping the blank into the jig. And once the top surface is cut, I put the blank in the other side of the template and move the spacer to the other side. The angle is already set, giving perfect parallel surfaces to the top and bottoms of the beams. The router has to be adjusted for height for every cut, ensuring that the pilot bearing runs as close as possible to the top edge of the template. You can see in the diagram that if the pilot bearing were further down, it would cut further into the blank, messing up the thickness of the beam. For this I greatly appreciate the Rockler router table, which has an adjustment screw on the top of the table itself for precisely dialing the router up or down by small increments. Fiddly, maybe, but way less hassle than shaping every beam by hand. And also a much more precise way of dialing in the correct roundup and also angle for the sheer. Plus, it is fun to make jigs! Best wishes, Mark
  9. I checked in on the Tally Ho project. I don't think I will get much work done while I look at all those videos! It is amazing to see in full size what we are doing at a miniature scale... Thanks for the reference to this! Mark
  10. I improved my old beam jig, used years ago for the gun deck beams. It now has a base which runs along the router table surface. Hinged to this is a piece of plywood cut and sanded with the upper and lower deck roundup on each side. The piloting bit on the router table runs against this. an upper piece of plywood clamps down on the beam blank to hold it firmly in place. The hinge allows me to use a digital angle gauge to dial in the correct angle up for the sheer at the beam location. The white screws allow precise adjustment. So I first clamp in for the upper roundup, then switch to the opposite side to do the lower roundup. A spacer behind keeps the beam at its exact moulded depth. 3 done, 24 to go.....
  11. Hi Dave, Thanks so much! His design must have changed over the years, but the concept remained the same. I realize I had one too many pieces I was looking at, and here is how it goes together. Best wishes, Mark
  12. In my enthusiasm for needing some straight metal pieces for another jig, I took apart my old Preac saw taper fixture. Now I am ready to put it back together, I cannot remember for the life of me how this works. Could someone who has one of these post a picture so I can reassemble? Always take a picture before disassembling, I will remind myself in the future....🥴 Best wishes, Mark
  13. Thanks so much druxey and Siggi. I think, I hope, I have finally got it. Using primary sources closest in date to the Bellona, the Dorsetshire section and the Falconer dictionary, here is what I now see: The sweep is one beam astern of the end of the tiller, and the lines run to a sheave in the side, not to a free-hanging block, as in the Dorsetshire: And I will use five wraps on the hub, according to Falconer, which works perfectly with the maximum 2 full turns to each side or 4 turns lock to lock, with a fifth wrap for the nail at the center. This leaves a little bit shorter slot for the rope to traverse back and forth at the quarter deck level: And centering the sheaves in the upper deck framing on the center of each slot, we get: Back to shaping my upper deck beams! Mark
  14. Thanks druxey and Gary. Gary, I see what you mean. Couldn't see it in three dimensions until looking at your stern. So I left the hanging knees out for now, will see how long my horizontal knees come into this space. druxey, fascinating little sketch of the wheel. First, I had the sheaves backwards relative to yours. I switched, and now I have the starboard sheave forward of the one on the port, as above. So I did my own calculations, based on your reasoning. With a barrel diameter of 21", one turn of the wheel pulls in 66" of rope. My tiller can only swing 10'-11" to one side from dead center, because of the gooseneck hitting the beam behind the sweep as discussed before. So I need 1.98 (rounded to 2) turns of the wheel to pull the tiller its maximum distance to one side, or 4 turns lock to lock. So, if I understand how this works, with seven turns around the wheel hub, the rope will move four rope diameters along the hub when turning from dead center to full port, and the same from dead center to full starboard. And turning the wheel itself to port moves the tiller to starboard and the ship to port. In the drawing below, forward is to the right. Assuming I have this right, I located the holes down to the sheaves in the deck so they are about equidistant from the two extremes that the rope on that side will travel. The purple circles are the locations of the holes down to the sheaves. Or would these be slots in the deck down to the sheave, allowing the rope to traverse its full four diameters? I understand HMS Victory had sliding plates allowing the ropes to move without a big slot in the deck; but I am not sure if this had been invented yet in 1760. So many unknowns! Mark
  15. Thanks so much Gary, Mark and Siggi. You caught a mistake, and I was beginning to cut wood for the upper deck! Here is the refined version, thanks to your eagle eyes and research. My athwartship arms of the lodging knees were a trifle too long further forward, and the carlings at the stern were too wide apart. Adjusting for both of these, and the geometry comes out just right. I also fiddled with the geometry of the steering, moving the sweep back one beam, locating the sheaves at the sides according to the Dorsetshire print, and then running the lines to the steering wheel hub location afore the mizen mast. I worked out 7 turns on the hub, which located where the line comes up and then comes down, which are offset fore and aft by the width of the 7 turns. This makes the cross for the sheaves in the deck asymmetrical, as you can see below. Looks funky, but covered in decking eventually, so I guess I don't care! Am I understanding correctly that the port line up is the forward one on the steering wheel hub, i.e., the hub is wound clockwise? So a clockwise turn of the wheel would pull on the port line, which would move the tiller to the port, which would turn the ship to starboard? Hate to get it wrong, and have the helmsman accidentally steer into an obstacle! Mark
  16. Sweet looking gundeck, Alan! I'll be interested to see how far your tiller can swing, assuming the sweep and gooseneck are up in-between the beams as I see in the Dorsetshire plan. It is the gooseneck hitting the side of the aft beam that ultimately limits the rudder swing in the Bellona, not the size of the rudder hole in my case. Mark
  17. A little more digging last night, and I remembered that I was looking at HMS Valiant (1759). I saw this in Brian Lavery's "Building the Wooden Walls: The Design and Construction of the 74-gun Ship Valiant". The Valiant, according to Lavery, was begun the same time as the Bellona, as a substitute at the last minute for a Dublin class 74 that was about to start construction. So this deck plan would have been at least one way of constructing the upper deck of a 74 at the time of the Bellona. Assuming the athwartship arm of a lodging knee reaches from the side to the carling in the middle section of the deck, then these carlings set closer to the side for the remaining 5 beams would either require their knees to be shorter, or for the heads to be cut off, as I have shown above. I will try drawing some shorter knees in this aft section, and see if that looks more shipshape. Mark Detail of Valiant upper deck, from https://collections.rmg.co.uk/collections/objects/384159.html
  18. Hi everyone, Well, this is embarrassing, I can't find the plan I was looking at when I drew my upper deck. I assumed it was the Dorsetshire, but here is the Dorsetshire: I need to keep looking through my various sources. Should have written this down years ago. But if I don't find the source, the drawing Gary showed of the Hector, with the carlings moved in to the heads of the knees does make sense. Thanks for flagging this Siggi! A little more digging to do.... Mark
  19. thanks so much, Gary and Siggi. That makes perfect sense. It is confirmed by the section of HMS Dorsetshire from NMM, below. Here the sweep and gooseneck are clearly in between the beams, and also one beam back as you suggest. This shows what looks like a sheave in a fixture in the side, not a free-hanging block as Lavery shows in the Bellona book.... It doesn't allow any wider swing of the tiller, but it fits constructionally.
  20. Hi everyone, While waiting for the upper deck beam glue joints to dry before shaping their roundup, I worked some more on the tiller and its tackle. In a post to Alan (AON)'s site, Gary (garyshipwright) pointed out the need for directing the wheel ropes up through the deck forward of the mizen mast. I started working on this and discovered a few things. First, according to Brian Lavery's Arming and Fitting of English Ships, pp. 18-20, at the 1760 date of the Bellona, the Royal Navy was holding up the fore end of the tiller with a gooseneck running along a curved sweep track, just under the upper deck beams. A rope ran from the end of the tiller to a block on either side of the ship, back to a central block and up to the steering wheel. A problem with this method was that the tiller rope did not equally tighten and slack on each side of the tiller, causing sloppiness and some accidents. The solution was found in 1771, when Pollard, a Master Boatbuilder at Portsmouth devised a way to run the tiller rope along rollers within the track itself, keeping equal tension. But this was 20 years after the Bellona, so I will have to model the earlier, cruder method. And here it gets interesting. the original Bellona draft shows the tiller very tight up against the upper deck beams. We are seeing below the tiller at midships, but the beams at the sides. When the beams are shown at the center location, their bottom surface is only an inch or so from the top of the tiller surface. How does the gooseneck and the sweep fit? Here we see close up that the gooseneck and sweep cannot fit under the main beam. Both have to fit up into the space between the beams. There is more clearance at the small intermediate beam shown in orange. but eventually as the tiller sweeps to the side the gooseneck (shown in dotted orange) it hits the next big beam aft. (this drawing is not accurate for the position up and down, since the tiller sweeps downward as it sweeps to the side, following the roundup of the deck beam. But the space between tiller and beam will remain the same through the sweep, so this is just showing that eventually the gooseneck hits the beam.) In plan, this means that the tiller can only swing as far as the location shown in purple. The green location is a 33 degree angle David Antscherl discovered as the ideal angle in a study of helm angles in the eighteenth century, and described in The Fully Framed Model, vol. II, pp. 47-8. The Bellona geometry only allows a 26.7 degree sweep. However, the contemporary study David quotes also notes that some ships in the period only swept 28 degrees. So maybe this is close enough. There really isn't any lee-way, given the restricted space between beams 23 and 24, into which the gooseneck and sweep have to fit if the tiller really is as tight to the beams as the original Bellona section shows. Even with this, the sweep will have to be pared down at its outer ends to fay onto the underside of beam 24. Mark
  21. Gary, thanks for the note regarding how to handle the tiller ropes. I would have been in some difficulty getting around a central carling a few months down the road. Isn't it great to share ideas on this website! Mark
  22. I realized that other day that summer is coming to an end, and cold weather will be upon us before we know it. That means I need to plan ahead for anything needing the use of the router table in the garage before it is too late. So, I temporarily put aside spirketting, to concentrate on making the beams for the remaining decks. I used a router jig for the gundeck beams, and plan on the same idea for the rest of them. First, the upper deck beams. Much as I admire the tabled joints done by our great craftsmen including Gary (garyshipwright) and Ed Tosti, I remind myself that my design goal is to emulate the Admiralty style models I can see close up including the two Bellona models and also the Princess Royal model in Rob Napier's book. My hull framing is thus stylized, and so should the deck beams as seen here in my photo of the first Bellona model. The two beam halves are a simple scarphed joint. I did this on the gun deck, and so will continue onto the upper deck. The higher decks are one piece beams. So, I measured the angle needed to form the correct length of the scarph, and used angle gauges of 3.5 degrees to set up the table saw for an angled cut: I then slid this angled plywood piece under the angle table on the Sherline mill, to set the correct angle of taper. On top of this I bolted a simple holding jig, into which I can slide beam blanks, clamp them down, and then run the cutter across to form the angle. The brass bolt was used for fine tuning of the angle after I ran some tests for the correct length. I have 27 beams in the upper deck, times two halves, times 3 passes for controlling the depth of cut, equalling 162 passes of the cutter. A happy five hours! Here are the blanks awaiting their turn at the mill... Next, gluing up and shaping the roundup on the router table. Mark
  23. Hi Alan, Just for fun comparison, here is my reconstruction of the Bellona upper deck. Now I am going to have to remember where I got the carling pattern, which steps towards the bow and stern, also the curved beam just forward of the rudder opening... Mark
  24. Thanks so much, druxey and Gary. I am very slow but steady! Waiting for glue to dry on the starboard spirketting at the bow, I finished up the drawings for the pre-Brodie stove. Given the material I found, this is my best guess. It may be a few years before I actually get to construct it, so I may find out more before I begin. It is intriguing, in the Dorsetshire drawings, the nozzles out of the kettles seem to have a ball connection between the fitting and the side of the stove. They are clearly a ball in the drawing, with shading to indicate it as such. I wonder if this was a rotating fitting, allowing the nozzles to change their direction left and right and up and down. Don't know why this would be of value. And my "squiggly thingies" are drawn to the scale of the Dorsetshire drawing, but they do look flimsy for carrying a large joint roasting out at the outer edge. Maybe these need to be thickened up a bit. Mark
