Everything posted by SJSoane
Hi druxey, I thought that for a long time, but on closer inspection of the 2nd Bellona model, it shows the roundhouse base sitting on top of the platform, not the upper deck. In this photo, we can see the ledges or grating that extends out from the level of the platform, and it is the same level as the bottom of the roundhouse that is just peeking out beyond the main rail. in the drawing below, the upper dotted line is the level of the platform and grate, the lower level is the level of the upper deck. or, what if the seat is the part cut off at the level of the platform, but the access from the upper deck is at the level of the deck? It would be a cantilevered seat of sorts... Mark
As I got closer to topping out the planking at the head, I notices some discrepancies between the drawings and the model I had built so far, relative to the height at which I had trimmed the frame right at the bows for the small deck afore the beakhead bulkhead. So I had to go back and reconstruct what had gone wrong. As it turned out, when I trimmed the hull around 15 years ago, I had trimmed it to the top of the deck, whereas the decking laps over the top of the hull at this point. So I will have to trim the edge down to accommodate the thickness of the deck planking. While studying this, I also realized that I had drawn the little deck with a sheer matching the rest of the ship, but on closer inspection, it is horizontal. The following drawing fixes this. However, in changing this, I notice that the opening to the roundhouse has gotten pretty short. Even if I put the seat only 8" above the deck as seen here, the opening is only 2'-4" high. This would take some agility to twist around into this opening, and then sit with your legs spayed out in front of you. I have double checked the heights of the various beams controlling this, and it is accurate. Maybe the seat opening is closer to the aft end of this opening, maybe even over the top of the beam? Or maybe at the level of the floor? Then your legs would hang down the ladder at least. It nonetheless would still be better than doing your business out in the weather afore the beakhead bulkhead! Mark
On with more planking. I am working on the channel wale, which blessedly does not have any ports interrupting it until the last 4 ports astern. I am finding it quite efficient to plot the upper edge of each plank at various points along its length, and then put in a fair line using the artist's tape. Much easier than trying to fit a flexible curve, which is also impossible once the piece is steamed and bent. Also, I have learned to cut the upper edge of the planks a little full, so I can fair the whole edge with a curved sanding block once installed. A plank in the second strake up makes a wicked curve from convex to concave as it proceeds aft, and it also twists quite dramatically. That would have been something to see in the actual shipyard. that one plank took about 5 hours to shape and install: And here is progress to date. Nice to see those boo-boos from 15 years ago disappear under planking at last. I see that I will have to make a sanding jig to later level the channel wale to an even projection from the lower planking. Not sure why this is wavering a bit. Mark
When I have to make a very precise joint, I have tried a variety of strategies like building jigs. But more recently, I have settled on cutting roughly to the line with whatever saw is handy, and then refining the face with a paring chisel, sanding blocks or files. Here artist's transfer paper or carbon paper is your friend. You slip a piece of this between the two pieces of the joint, and pull it out. This leaves some graphite on the spot that is too tight. Sand or file the graphite away, and then repeat. In complex pieces, like the ones where I am refining the edges of planks bent around a bow, I may have to repeat this process 10-12 times. But it will achieve a perfect fit if you are patient. When sanding a flat face as in your keel joint, hold the piece firmly on a work surface against a square block to ensure it is vertical, then slide the sanding block back and forth while it rides on the horizontal work surface. You do not want to hold each in your hand while you try to sand it, because this is guaranteed to wander off a right angle, and also likely round the face. I am getting better at doing this with a file, but it took me a long time to learn how to control flat and vertical cuts. The sanding block on a flat surface is more reliable. David Antscherl's excellent books on the Fully Framed Model also give great advice about how to cut things accurately with very sharp chisels. When I first read these, I thought that level of skill was way beyond me, and it was when I first tried. But a lot of practice--and constantly keeping the chisel razor sharp--has got my skills to a point that I can more reliably count on this approach. Three secrets to success with chisels, for me. First, scribe the line to be cut with a scalpel, using a square or straightedge. This give something for the chisel edge to register to, rather than trying to line it up by eye. Second, look at the reflection of the piece of wood in the face of the chisel, and change the alignment of the chisel until the wood and its reflection are straight, ensuring that you are holding the chisel straight up vertically. Third, only pare away thin slices multiple times, rather than trying to take off a larger chunk. The larger chunk approach will often crush the wood rather than slice it, and it tends to push the blade in at an angle as the wedge of the chisel tries to cope with the greater forces needed. Light and delicate is the key, and thin slices can be removed with little effort, with a gratifying "snick" sound. And I concur with other comments here; learning this process involved making lots of mistakes and doing parts over. But that is part of the fun, because you can see a visual trail of how much better you are getting, when you look at your earlier, less successful efforts! Best wishes, Mark
Hi Alan and druxey, I will likely use a mechanical means of laying out a paper strip when it comes to cutting wood, since I will have to be bending it in two directions, but the mathematical method is interesting to see, a simple means of proportion--thanks, Alan! So in the example below, the curve of the stern at the balcony level (minus the balcony itself) is a 50' radius. the angle between the lines at the ends of the chord is 26.8º. The formula would be: C= 2 × π × radius = 314'-2" angle = 26.8º x/C = 26.8/360 x = 24' 4 5/8" Nice! Working out a ratio between the curved and un-curved could be used to stretch the original drawing in Turbocad. But now I am back to cutting wood... Mark
Hi Kurt, yes, I always liked drawing, which I learned long before CAD was invented. I learned from an architect who was a master at drawing, although I never reached anywhere near his level. I like the way drawing can help me visualize things, before committing time and material to making even more mistakes than I do already. Although it is nice to be able to make a quick freehand sketch now and then, CAD really has made the production of drawings easier. Jason, no, I did not adjust the profile to the curvature--yet--I am thinking about it. I confess that I don't understand how to account for the round back on the stern, as well as the round up of the decks. I suspect that I have to do a true projection accounting for the curve one way, and then do a true projection on that second drawing. But I am not sure what I will end up with, because it will not help me shape the mouldings in the two directions. So the paper stern I put on this morning is indeed a tiny bit short, good enough to see what it will look like. Does anyone know how to flatten out a curve to get a true projection of its actual length unfolded? I have not figured this out yet. Looking at Steel's drawings, he seems to show how, but I don't really understand it. Maybe an evening studying it more closely... Best wishes, Mark
Thanks so much, Jason. I am using TurboCad Deluxe for the Mac, a relatively cheap CAD program, about $150, as opposed to thousands for AutoCad. It is a little buggy sometimes, but it is getting the job done. I started out drafting this project many years ago by hand, and I have become a convert to CAD as I started to refine the drawings I needed for the model. It is so easy to try things and change, duplicate and mirror, put things on layers to see how they relate to each other. Mark
I am drawing the section through the quarter gallery, learning much about how these were constructed. This shows just how tiny these spaces really were. And look at how short the doors are, to the left of each space. I wonder why these were not made taller? So a quick question came up about the upper finishing, or the roof over the quarter deck. Steel says, "the upper and lower finishings may be found at pleasure, making them as light as possible, to please the eye, and containing sufficient room in the upper finishing to hold a cistern." (p. 365). I am showing a recess in the finishing below. Does anyone know what the cistern was used for? Was this a primitive flushing device? Mark
Beautiful work, Siggi. And I see you have your master carpenter in the chair in the conservatory. Time to get back to work! Mark
Thank you, Gaetan, this is good advice. I am quite uncertain about how I am going to construct this balcony railing, with its lacy decorative pattern on a serpentine curved surface. I was originally thinking that the railing might help give shape to the lower surface. But I have no idea how I would cut that notch. If I made the lower surface solid rather than pierced, then I could shape it maybe by laminating layers of thin wood to the right curvature, and then it would not need the railing to make its form. I think this is going to take a lot of trial and even more error. I highly value your advice on construction details. You are the master at that. Best wishes, Mark
Hi druxey, I am thinking I need a little help with an obsessive/compulsive disorder....😗 Actually, there was some method to the madness. I am having to reconstruct the stern only from the evidence of the photos of the two models, and the original admiralty drawings which I now know are not very consistent with the models in regards to the stern. I discovered that the key foundation for this stern is the line of the mouldings at the edge of the balcony deck. You can see in the original model that the hull frame projects out six inches, like a notch, just below the balcony deck line. It turns out that this notch is lower than it should be, compared to the later model. In the later model, we can see that the notch is used to jut the upper stern works 6" further aft of the windows below, forming a little overhang over the windows, all the way to the sides of the quarter galleries. We can see this here, as a heavy shadow line just above the windows: In this detail, the lower orange moulding is below the notch, while the upper orange moulding is above the notch. However, once we turn the corner of the quarter gallery, the two mouldings are brought back together without the 6" offset. Now, the width of the overall upper works are determined by how far out these mouldings project on the side of the quarter galleries, as indicated with the red circle below. When I didn't understand what the mouldings were doing, this projection on the side varied by a considerable amount as I experimented with various moulding profiles, throwing off all of the proportions of the upper works. So, now I have a solid foundation for reconstructing the rest.
For geometry nerds only: I woke up at 3 in the morning, suddenly remembering that traditional classical architecture has long dealt with how to wrap complex mouldings around a variety of forms. I dug out an old drawing book from 1919: It reminded me that classical mouldings change their profile when they run into a surface not in the same plane, like a pediment moulding running down on an angle and then hitting a vertical wall. This book shows how to determine the profiles at various places. The key to working this out is realizing that in plan, the various lines of the moulding have to match up at the line of the miter. In the drawing below of a quarter gallery corner (stern to the left), the brown line represents the edge of the moulding at the top, the green line represents the moulding at the bottom, and the blue lines represent the lines of the various moulding pieces like the vertical fillets. Since the moulding at the stern rakes back and the moulding at the side of the quarter gallery rakes in, the overall width of the moulding at the side will be narrower than the moulding at the stern. Furthermore, the top line of the stern moulding is aligned with the sheer of the hull, while the top line of the moulding at the side aligns with the roundup of the deck. When these all match up, then the profile shapes change relative to each other. The top two drawings represent the moulding at the stern and then at the quarter gallery respectively. Now at 3/16" scale, the difference between these might be minuscule, probably outside my technical abilities to make different. One scraper might do the job for both. But it is finally satisfying to understand the true geometry, as the shipwrights would have had to work out on the real thing. Here is the difference in the actual profile edge: Geometry lesson over, you can go back to your regularly scheduled programming! Mark
Marc, thanks so much for sending that video of the Victory. Fascinating to see some of the detail close up, and it is always a good reminder of how large all of these things are in the real ship, as opposed to our relatively dainty models. When we think about all of the details that are discussed on this website, and then think about how big they were in real life, it gives one an even greater appreciation for those shipwrights. Mark
So, I think I see it now, thanks druxey. I think the blanks for the mouldings at each location have to be shaped with a different back, to match the surface upon which it sits. The guide is the moulding on the stern, which will have a horizontal top surface. The ones on the quarter galleries then align to this, with a different back angle. And, the mouldings at the sill of the window are different in their back angle than the ones at the window head, because they sit on different raked surfaces. In the drawing below, the green moulding at the left (top and bottom) is the profile swept along the moulding, which keeps the top horizontal to the ground. The green mouldings on the right (top and bottom) are what I believe will match along the quarter galleries. I may have to make up some samples to really see this.
Hmm, I will get back to the stern frame in a little bit, but this morning I am struggling visualizing the mouldings that wrap around the stern to the quarter galleries. The stern slopes one way, and the side gallery slopes the opposite. In this image, the same green moulding is aligned with the rake aft to the left, and the rake of the quarter gallery to the right. These won't form a clean miter at the corner. The orange moulding shown here works for the rake of the stern, but has to be changed entirely in its profile to fit the quarter gallery, because it upward sloping surface has slope down on the side gallery to match at the corner. The problem with the geometry is shown here. The upper diagram is a clean miter when both sides are the same rake, in this case vertical. The second diagram shows what happens with the left piece rakes aft, while the side piece rakes the other direction. The two can't form a clean miter. And yet, there are thousands of models that do this. Can't visualize it! Mark
Hi Gary, You are right. I can't see how to fit a transom behind the rudder that has any thickness to it at all. Below shows the plank running into the fore edge of the stern timber. A transom would really just be separate blocks of wood between the stern timbers, not a continuous structural member across the width of the stern. That triangular block of material directly behind the rudder sitting on top of the stern timbers really has to be something like a chock or something to fill this space, I would think to keep water out of this area. Many years ago, I see I made a big chock behind the rudder hole, the same thickness as the stern timbers at this area. I think it needs to be filled up more to the deck level somehow. I believe the flat spot I made on this chock below is at the level of the top of the beams, so there really isn't room for a transom. Well spotted! So maybe it is a nailer on the tops of the stern timbers that the planks sit upon, either side of the rudder hole. Do you think the curved beam I am showing in front of the rudder is not plausible, given the plans you have looked at? Best wishes, Mark
Well, now I don't know what to make of the original Bellona drawing labeled as the Quarter Deck plan. The quarter gallery shown here is actually the length of the quarter gallery one deck below, off the Upper Deck: The quarter gallery for the Captain, off the Quarter Deck, is much shorter, and narrower. Indeed, it is quite tight... This is really obvious in the sheer drawing, Captain quarter gallery off the Quarter Deck above, larger quarter gallery off the Upper deck below: So, druxey, it doesn't look like this plan is very reliable evidence of anything, including the 1 1/2" planking around all sides of the quarter gallery shown in this plan. Curious why this is drawn this way... Mark
Hi druxey, Thanks for the confirmation about the rakes changing from side to center. It took me several days of trying to get them parallel, and parallel they would not go! I now see that the stern assembly is in fact a large cylinder tilted backwards (same radius at each deck), with each higher deck cutting a little more aft into the cylinder because each is narrower. So obvious, why didn't I see it?🤪 I am frankly astounded at the sophistication of the geometry those shipwrights developed. Yes, I think I am coming around to agreeing with the full width of planking running all the way astern. Now I realize that the drawing in posting #1652 shows 1 1/2" planking all around the quarter gallery, but it shows the seat full length without acknowledging the thickness of the structure that has to be there, which would have shortened the seat. So it is more like a diagram than an accurate expression of the construction. Another curiosity of the set of drawings. Tomorrow, I am going to look at the captain's quarter gallery, where the room seems much narrower towards the top. A section might show just how tight it is. Best wishes, Mark
I haven't posted in a while, but I have been drawing all day long every day. The stern is definitely challenging to draw. I get the elevation worked out, only to discover that the section or plan no longer aligns. So I have to go back and forth among the three making constant adjustments. And since everything is connected to everything else, all is in constant motion... I finally figured out why things would not line up. I had assumed that on the sheer, a line drawn along the aft most edge of the hull at the sides would be parallel to a line drawn along the aft most edge of all the decks at the center line. But it turns out that the line at the sides is not parallel to the line at the center. They converge slightly towards the top. You can just about see this in the original shipwright's drawing below. Note the two dotted lines, one at the side and the other at the center, are closer together at the bottom than at the top. I finally figured out that this is because the radius of the aft deck ends is the same for the upper deck, quarter deck and poop deck. And since the decks are progressively narrower as they go higher, the amount of round aft decreases at each deck level. And so they are progressively shorter at the center relative to their sides. The following sketch shows the idea. The two radiuses are the same, but the upper deck gets a longer rise in the chord as at "A", than the rise of the chord for the poop deck at "B" So even though the poop rakes aft of the upper deck at the side, the rise of the chord is less. So the lines at the side and the center eventually converge. A small point, but I could not make the stern geometry work until I figured this out. Those original shipwrights were pretty clever! With that problem fixed, it is now a matter of constructing the side galleries relative to the sheer and the plans of each deck. In the sheer below, the brown lines are the locations of the various rims and stools on the face of the hull itself, while the purple lines are the beginning of the outside view of the side galleries as they project from the side. I learned more about the side galleries, working out how everything fits together. I realized that the original Bellona drawing posted previously did not include the thickness of the structure in the quarter gallery; when this is added, the space really starts to get smaller. The purple line shows the 4" thick plank within the quarter gallery; still not sure if it thins down here or not. The thicker plank definitely crashed into the stern window structure, but if there is a wooden backing to the glazing, this awkward junction would not be seen. These are snug places, 3' wide at the greatest width, and a 1'-9" door to get through into it. I am starting to wonder if there was room for a London Times newspaper rack after all...🙂 Mark
Cutting the Rabbit
SJSoane replied to acaron41120's topic in Building, Framing, Planking and plating a ships hull and deck
yes, you definitely want to cut a straight rabbet along the keel, before it begins to sweep up at the bow. The bottom of the frames need to be trimmed to--or padded to-- match the straight line of the rabbet. Mark -
Jointer question/recommendation
SJSoane replied to davec's topic in Modeling tools and Workshop Equipment
I once had an 8" industrial Delta, and more recently a 6" Rikon. I spent many happy hours adjusting them, and they were great for larger furniture projects. But I was always a little shocked watching so much very expensive boxwood coming off in order to flatten the entire 3' long board. I realized that I was trying to flatten something that was going to be cut down in length anyway, and did not need to be flattened for the full length, wasting a lot of valuable wood. Now, I slice wood to thickness plus a little spare with a bandsaw, and then run the smaller pieces through a Byrnes thickness sander. For straight and square edges, I use a good sharp plane with a shooting board. Much safer than pushing small parts over a jointer. I now never use my jointer for the ship project, only furniture projects. But whatever works! Mark
