flyer
Everything posted by flyer
  1. Hello Nils It is a masterpiece. While I admire others in this forum for their extremely clean and almost clinically precise builds I also like that just slightly handcrafted look your work still has. It’s beautiful, individual and charming, for me it looks almost more authentically and is a true work of art. Oh, and please have mercy with those poor sailors and allow them to sail the gig if the wind is favorable – rowing is hard work! Cheers Peter
  2. The boats just resting unsecured on the spars were not longer tolerated by the first officer and they were tied to the spars. I had no idea how to do it and opted for a simple solution. This should be OK, as there is no heavy weather expected - after all the ship is still in harbour. In the meantime the sprit topsail was made, bent to the yard, furled and the whole thing attached to the jibboom. The jibboom horse presented a small problem first as I initially found a drawing for the frigate Pandora where the horses hang below the sprit topsail yard. This would however present some problems when setting a sail on it. I thought the horses should lie over the yard to allow it to slide below them and also setting a sail without having to unbend the horses. The yard was positioned just above the cap. The arrangement is somehow mirroring the mizzen mast. Between the different steps of that undertaking many small tasks went on: Making and attaching more gun port lids, adding buntlines and braces and generally slowly cleaning up the mess with all that loose ends of running rigging on the forecastle.
  3. Hi henry The sailors are Amatis 25mm crew figures. They may be hired e.g. via: http://www.cornwallmodelboats.co.uk/acatalog/amati_crew.html Cheers Peter
  4. Thanks for all the likes. What credit is due for the anchors really goes to B.E. I only managed a poor copy of his masterpieces but still got an improvement of the anchors straight out of the kit. @Martin Oh, he absolutely has to be that strong. I only got about 5 of those tiny sailors to do all the work on Pegasus and 2 of them are officers (I think, those don’t do real work). But seriously: the sailor should show the quite astonishing size of the anchors even on a relatively small vessel as Pegasus. On the other hand - such an anchor had to have the strength to hold the whole ship against the force of current and wind. I think that the anchors provided with the kit are definitely much too small. Cheers Peter
  5. As a break from the rigging work I made the anchors. For size and number I relied on B.E.’s research (again: thanks!) and the remarks in one of my books on Granado. The first bower anchor was produced with the ring made from the material in CC’s anchor kit. This looked out of size even without puddening. Therefore I made a new ring using 1mm brass wire. For the iron bands around the stocks I used black cartridge paper which looks good even without painting it. The anchor metal was painted with Caldercrafts ‘metal black’. The left anchor still has the original ring from the kit. The right one shows the new ring before puddening The captain inspects the finished bower and sheet anchors and the smaller kedge. The kit for the stream anchor is still there as I’m undecided if to ‘stow it below’ (mentioned in Granados book) or not.
  6. Hi Mobbsie I must admit, that I really stumbled Maturin-like across that horse on the bowsprit when I first read about it. What does a horse do on a bowsprit? Whine and fall into the sea, most probably, panicky beasts they are. (I like them.) Then I wondered why horses on the yards are always done in all details but those on the bowsprit hardly ever. No answer for that question. Unfortunately most of the netting will probably be covered by the furled sail but we’ll see. Hi Nils No, it’s between the stays and quite easy to fit in. Good luck with all that laundry you plan to hang into your rigging. Usually I follow W. zu Mondfelds advice and start aft and low moving upwards and forward and inboard to outboard also when installing yards and sails. But I never put up more staysails than spanker and jib so far. I think it’s most important to find a working order where you don’t block yourself your access to further working areas and belaying points. Cheers Peter
  7. While working in the bow I noticed that I was quickly running out of usable belaying points for all that running rigging. Therefore two additional knightheads had to be installed right up in the bow. The skipper approved this and the bosun also changed the belaying point of the fore yard lifts to one knighthead aft of the one according to the kits plans. Now it should get a little less crowded on those knightheads. First try with a new knighthead Now, where did that carpenter go? The skipper seems content and the bosun already has other urgent tasks to be done.
  8. While browsing through James Lees book to check what blocks where needed for the sprit topsail and the staysails, I noticed that a bowsprit netting was needed to stow the furled fore topmast staysail. As I intend to attach that sail furled I searched further and read that this said netting was to be attached to some nag or other cattle and suddenly felt much sympathy (again) for Stephen Maturin. Then I found out that the netting was to be mounted between the bowsprit horses with two stretchers. Those horses (and those of the jibboom) were missing in this kit. In fact, the only kit so far where I came across that seemingly often overlooked detail was Mamolis ‘La Gloire’. Fortunately I found also a picture of the netting in my book and was able to make one out of the same material I use for the hammock netting. The horses for both bowsprit and jibboom were also installed. Finished netting ...fixed in place Horses installed The bowsprit cap gets a bit crowded. I installed two additional ringbolts on top for the horses.
  9. The spritsail yard is now finished (the braces left off until later. Next will be the sprit topsail yard with its furled sail.
  10. Hi Ken Thank you (and I knew there was a hidden catch somewhere but at least that admiralty doesn’t write monthly bulletins). Frankly I had no problems at all with the brails because I cheated and left them off completely. They would have been covered by the furled sail anyhow and only have added to the bulk of the cloth. Checking on your (really nice) Fair American I presume, that you did the furling according Lees page 113. There the brails in fact seem somehow to double up as gaskets which I find complicated. I thought my brails could be more according to the sketch on page 109 (bottom right) because that seems to represent an older version. With those the clew would have been pulled more upwards (as it happened on my sail) and then I used a few single gaskets on the gaff and a spiral gasket on the mast to fix the sail. Below you find some more pictures of the spanker (others are on page 17 of the log) Cheers Peter
  11. Thank you very much, Martin Yeah, the conch republic definitely has its very unique charm although the tourists sometimes are a bit disturbing (tourists: other foreigners which invade with cruise liners). Cheers Peter
  12. Hi Nils Thanks. Yes and the white wall doesn’t swallow to much light either. It was a good idea for the working place. The sprit topsail yard will follow and also carry a furled sail (first time I will try this). The shape of the sail was chosen only to reduce the amount of furled cloth. It should represent a normal spanker where its foot matches the length of the boom. The lashing is according to Lees sketches of spanker and driver (have you got that book yet?). Cheers Peter
  13. Hi Nils Great sails, great progress. If you go on like this, you will soon be up to ‘Mobbsie-speed’ (similar to speed of light: you cannot go faster without using some rather exotic physics). Cheers Peter
  14. Hi Mobbsie Beautiful! Your change will be a sad loss for us humble kit builders and a great win for the dark arts. Are you aware that you could actually tempt other, innocent souls to follow you? You take great responsibility there, my friend! Cheers Peter
  15. Hallo Nis So, I presume you are a member of that club as well? Thanks for the welcome. The profession was very nice – except maybe when you had to master all possible horrors of aviation twice a year in your simulator sessions or when you had to steer an aircraft through the thunderstorms in the bay of Bengal or while trying to stay awake and alert through countless endless nights or while trying to get some sleep in a rundown hotel somewhere in Africa or freezing your behind of in Moscow while wondering if having your aircraft heated with the exhaust gas of an old MIG engine really was the best way to get rid of all that snow and ice or while being held back somewhere by some unrest or civil war or other or – and that was the worst of all – while reading your chief pilots monthly bulletins. But the sunrise was always beautiful. Good question! It seems really a bit strange that there is never something like an in-hauler or similar. On my Pegasus the lashing of the jibboom prevents the sling of the spritsail yard to move further forward but I think the main back holding force of the whole arrangement came through the braces and a bit through the sheets. This however in turn would mean that the thrust from the sail was also brought to the ship through exactly those same lines. Or perhaps the friction between yard and bowsprit could also transfer a significant part of the force. Anybody got any other ideas? Regards Peter
  16. Hi Ken Yes, the spanker is in place. The reduction was done by cutting it rather as a mizzen sail with a vertical aft edge than as a spanker with a wide foot.. Below you find the sketch of the ‘spanker’: Regards Peter
  17. Hi Michael Just lucky shots, I think… Thanks anyway. Peter
  18. Hi Nils Glad to be able to help a bit. Actually I am really curious about how your superb build will look after you assimilated all that information … Cheers Peter
  19. Back to serious business... The spritsail yard (no sail) is being hanged onto the bowsprit. I try to finish the last of the rigging in a working order that enables me good access to the actual belaying points without blocking the way to future ones – and sometimes nearly am successful. Spritsail yard being attached
  20. Well, I took some time to respond to the last posts and the wharf was rather quiet as well. The reason is that I experienced a radical change in my life: After my last flight (to Singapore) I’m now a retired skipper with a lot more time for shipbuilding. That change was celebrated with a two-week-stay on the beaches of Florida. There weren’t many ship models to see – the Mel-Fisher-Museum in Key West shows a lot of very interesting artefacts but only one, rather simple, ship model – but the sea was lovely and most of the mojitos as well – again cheers to Sir Francis Drake! After 34 years of fortunately accident- free flying I’ll be earthbound again (but plan to remain a flyer in that forum) and will happily enjoy my freedom of any fleet chief pilots or board members (and plan to find out if there will be more time for shipbuilding or if it’s true that retired gentlemen have no time at all...). Last flight into Singapore...
  21. While I was trying to install all the rigging which is belayed somewhere on the centerline simultaneously I realized that also the spare spars and the boats must be set on their place at the same time... Lashing the spare spars Working on lashing the spare spars while tripping over all the loose ends. It’s high time the bosun has that deck tidied a bit...
  22. Hi Nils There is a lot of information about the size of the stay sails in the mentioned James Lees’ The masting and rigging of English ships of war. I noticed that it is still available on Amazon for 75$ in used condition. I bought my copy in the museum shop of the USS Constitution and don’t remember what I actually paid but the price printed in the book is 40£. If you could squeeze it into your budget I would highly recommend buying the book. The size of your sails accomplished with the help of your tummy however looks right to me although I didn’t check all the measurements. While strolling through the wharf I managed to take some pictures of the jibstay… lower end of the jibstay on the traveller 'upper' end of the jibstay hitched around the lower deadeye of the starboard topmast backstay Take care Peter
  23. Hi Mike Thank you for the compliments and I’m really looking forward to a build with the quality of yours showing sails! Take care Peter
  24. Hallo Nils Yes, according to James Lees, it seems the jib was, after its introduction around 1705, either set flying or after about 1719 on the jibstay. The stays lower end was being seized to a thimble on the traveler while its upper end rove through a block stropped to the topmast cap on the starboard side. It was then led down to the stool abaft the fore channels where on small ships it was hitched around a deadeye. Its size was about 0.5 of the fore topmast stay. What you say about shifting the traveler to change the position of the center of the force on that sail to balance the ship is excellent – I never thought about that possibility. You think like a structural engineer. On the ‘upper’ end of the jibstay (which is hitched around that deadeye) you could have some excess length to adjust to the shifting of the traveler. On larger ships, by the way, that end of the jibstay was secured by means of a fall which made adjustments even easyer. Very interesting questions! Take care Peter
  25. Hi Mobbsie Thank you (and all of you) for the appreciation of my sail work. That really helps through the tedious part of sailmaking. Take care Peter
