flyer
Everything posted by flyer
  1. Hallo Nils Yes, I think we all like those … swans. A noble cloud of sails sure must be a glorious sight, but Danny certainly is right as well. A possible solution could be to set not all of the sails, the swan not blustering all of its feathers, so to speak. Depending on the situation you decide to show your Pegasus in, there are almost unlimited combinations of sails set, hauled up or furled possible. You just have to choose one, where you have a good view of the decks and still a pleasantly balanced arrangement of sails. An example could be that picture (from Peeter Goodwins The Ships of Trafalgar) showing Thunderer hove to. I’m looking forward to your solution of that tricky problem. Cheers Peter
  2. Next step is the making of the fore course and its attachment to the yard. It will then be fixed on its mast. I will show the making of the sail step by step and hope to convince one or two fellow builders that sail making is manageable with a moderate effort. First step is to find out the dimensions of the sail. I took a suitable plan sheet where all the masts and yards were shown. Usually the yards are shown in full frontal view and therefore the sails can be drawn directly into the plan. For the head of the sail a parallel to the yard is drawn at the position where it would be with sails set. The depth of the sail can now be found. The width could also be taken out of the plan but it must be checked with the actual yard. At the head it must be a little less than the distance between the yard arm cleats. The width at the foot is the width between the cleats of the yard below. The foot of the main course is 2 clothes wider than the head. The fore course has parallel sides. The width of one cloth is between 24 and 30 inches. I took 10 mm which corresponds to about 25 inches. All those and a lot more details can be found in James Lees’ The Masting And Rigging of English Ships of War. My sails are simplified because in furled conditions hardly any details are visible. The seams are pencilled on (on both sides) and no linings or bands are shown. The boltrope is not sewn onto the edge of the sail but glued into the hem – in this scale the difference is hardly visible and the result beats any of my clumsy attempts to sew a rope onto the edge. Also the foot of the sail is straight – no curve is necessary. Finally the size of the sail is reduced by 30...40% to produce less bulk on the yard. For the hem I ad about 2,5 mm around the sail. This is rather wide but some extra width is needed to fix the boltrope inside the hem. Sails pencilled into a plan sheet Sail drawn Check with the finished yard(s) Sail pencilled onto the fabric (both sides!) The sailmaker has the sail ready for hem and boltrope
  3. Hi Martin Yes, I just stumbled over that solution by chance and think it is quite tidy and easily done (and hopefully even historically correct). Cheers Peter
  4. Hallo Nils Once again I just had an (imaginary) stroll through your amazing Pegasus. Wonderful! By the way – what are your plans for the rigging? None, plain or with sails? Keep up the good work. Cheers Peter
  5. The sail, with the necessary lines attached, was now furled, the yard fixed to the mast as in the other examples and the different lines belayed. While verifying the various belaying points with Lees help I found that contrary to the plans the cluelines should be belayed in the lower top. I decided to use shroud cleats for this. Those offered by Caldercraft seemed a bit large and therefore I made them from some leftover ply wood. To further harden them for their task I soaked them in CA glue before painting them black. They were then fixed with glue and some fine line on the inner side of the foremost shrouds. As before lower sheets and the braces are left off. They will be installed only when all other work along the centreline of the deck has been finished. Shroud cleat Cleat fixed to the shroud Cleat with clueline belayed Topgallant yard in place Bitts and rail are almost full
  6. Hallo Nils Great improvement of that stern! That stove is coming along nicely. You have a talent to make the essence of things visible with simple means. Your stove started the same way as my own clumsy attempt. Then you add just a few things – a band with rivets here, a few lids there – and suddenly your stove looks real. Great! Cheers Peter
  7. Hi Frank Thank you! Hi Timmo Thanks again. It is rather easy to make the sails the way I do. I will show the different steps during the making of one of the next sails. And in my opinion they really add to the beauty of the ship – they are the icing on the cake. Ok that’s another crooked comparison. Some (American) cakes just clobber you over the head with the icing while on the other hand the world’s best chocolate cake (yes, made by my wife) needs no icing at all. Cheers Peter
  8. While the sail maker was busily stitching that topgallant sail the carpenter’s crew made some gun port lids 2.0. In the version 1.0 the inner layer was missing. This part fits into the frame in the gun port and brings the strength of the lid up to that of the ships side. The size of the topgallant sail was reduced by 30%, the sail bent to its yard and the unfurled sail provisionally placed on the mast. First 3 gunport lids 2.0 The eyebolts for the lid’s tackle are some leftovers from Granado Main topgallant sail not furled yet
  9. Hi Timmo Just rechecked my Granado and you are right: Those elbow/knee pieces are a bit flimsy. However they shouldn’t have to hold much pull from the shrouds. The resulting force on the channels should be directed broadside on through the channels into the ships side; provided the chain plates have a little play and are allowed to find their own balanced position. The said pieces then should only take a little strain when setting up or resetting the shrouds. At least that’s what I still understand from my design lectures– but be warned: My structure work was occasionally a source of wonder for the professor. I was also thinking about that sweep port problem and believe Jason is right. Nobody will notice it – except you. About that beer: In my opinion it’s already hard enough to have to drink it upside down. You shouldn’t aggravate the situation with syrupy consistencies. Try to get hold of a Swiss beer. No chocolate in there – we successfully sell that separately. Cheers (!) Peter
  10. Well, Martin, this is a rather philosophical question. If everybody’s imagination is running in the same direction, doesn’t that make it real? Be it as it may, I once saw a T-shirt. On the front was printed: I’M OVER 40 And on the back you could read: Over the top Going downhill Picking up speed It looks like that: the older you are, the faster you are. See it positively! When passing eighty you will be able to finish one ratline in 1/10 second or could start your formula one career and show all the Alonsos, Hamiltons and Rosbergs your taillights. Be good Peter
  11. @Mike :blush: I always liked that Unicorn. (Corels Dolphyn was my first build). I’m happy to watch the development of a fine model. @Martin Years are going by ever faster lately, I find. You’ll be there very soon. @Frank It’s nice to hear from you. But I must protest: my crew is very crisp and proper – oh, you mean this ironical. Take care Peter
  12. Hi Alistair Thank you for the compliments. It is my opinion that a sailing ship should have some sails. Without them a crucial part is missing. Furled sails still let you see the whole delicate web of all the rigging while the ship seems more complete and the rigging has a meaning. Contemporary models seldom have sails but I think perhaps the sails and how to work them was either too self-evident (and similar on all kind of sailing vessels)or absolutely irrelevant to take the pain to show them to those who mainly used those models: Professionals or investors(kings). Aren’t you perhaps a tiny little bit overmodest with your remark about skills and sails? I visited your log! Painting the seams and gluing the hem is easily done and to dye the cloth you can even use some tea without passing it through you first. Cheers Peter
  13. Hi Mike Thank you. You still haven’t changed your tag yet!? Cheers Peter
  14. Thanks very much for all those likes. @Nils I’m looking forward to the rigging of your Pegasus. You see, setting it up and working on the details, can be as much fun as you have with the making of the interior details of your outstanding build. @Martin Thank you. Perhaps you should stop the grog for your crew if setting up of some rigging is planed? @B.E. Thank you very much. Yes, I had a long talk with my bosun about those lift/sheets. Well, he is actually quite old. When he started his naval career some 40 years ago, in the 1730ies, topsail lifts were set up separately (as they will again in about 14 years from now – but we don’t know this yet). To honor his long service I decided to allow us that little anachronism. Of course, this means 2 more lines to pull during maneuvers but fortunately I have a full crew of right seamen – and besides that I like the look of it. Cheers Peter
  15. The finished sail was provided with the necessary lines and furled to the yard. The buntline blocks were installed as descript in Lees. After putting up the yard with parrel ropes, ties and lifts the cluelines and sheets were installed. For the lifts I choose (together with my bosun) a rather unconventional instalment. During the period of Pegasus’ build and live usually the topgallant sheets were used also as topsail lifts. In earlier or later times the lifts ran from the masthead; the same arrangement that is shown in the kits plans. The yard by yard build up seems easier for me, if I use separate lifts and sheets. Therefore, upon a suggestion of my bosun, I decided on a clove hitched span around the cap and seized the topsail lifts to it. Another problem is the belaying of all those lines. The space is rather cramped and I try to find reasonable belaying points using the plans and Lees while not overcrowding the bitts and rails. In the meantime the sail maker has started to work on the main topgallant sail. Parrel ropes attached Yard held with ties... ...and lifts. You see the span around the cap with the lifts sized to it. Lifts In the beginning there is still some space to belay the lines on the quarterdeck rail Buntlines are in place Captain Jack asks for more order around the bitts... ...and the bosun tries to live up to this rather untimely request.
  16. Hallo Nils That Idea for your stern (I mean Pegasus’ stern) looks like great improvement: simple, reasonable and effective. I had the same problem with the garlands on the side badge (the badges look great, by the way) and timidly asked Amati if I could buy a replacement. They sent it quickly and free, no fuss at all. I like that company. The used contact is below. info@amatimodel.com Cheers Peter
  17. Hallo Nils All those details are absolutely wonderful! I like going on a virtual walk through your Pegasus in those pictures. (By the way: Are you sure there were pin rails on the bulkheads? I understand they were rather flimsy constructions and above all were removed when the ship was cleared for action.) If you allow another critical question: Do you think it would be possible to rework the lower counter a bit? Your Pegasus’ stern looks in that place different from the other builds. I hope you don’t mind my nagging and do go on with that outstanding build. Cheerio and kind regards Peter
  18. Hi Martin You see, you need just a little splicing and knotting to fall into a kind of trance. So, who needs laudanum? However, in order to compromise, I take occasionally the brandy part of it just leaving away the opium. (OK, those two are drinking beer, but I didn’t find a nobler smiley.) By the way, I was intrigued by your use of ‘channelling’. Trying to improve my English I looked it up in the net. As I mostly found technical translations originating from channel I assume you use it as a technical slang.?? Cheers Peter
  19. Hi Nils and Mike Thank you. It’s actually fun to try to find out about the function of all those lines in the rigging (quite often I feel like Steven Maturin ) and to install them correctly. There are some differences between the kits plans and Lees book. Sometimes I go with the book and other times (especially if it’s simpler but still looks reasonable) with the plan. My Pegasus seems to have a unique bosun: sometimes he is very conservative and using old fashioned solutions and suddenly his work borders on science fiction. But over all I enjoy the setting up of the running rigging more than is right. Cheers Peter
  20. Next was the main topsail. Its length was reduced by 40%. While making it, I noticed that the largest sail on a mast is in fact the topsail. The size of the yards was rechecked but the topsail yard is lighter than the main yard. But such a large sail should at least have two buntlines if the mainsail has four. They will be installed according Lees. Additional blocks were put in place on the yard and the masthead. The sail maker is putting the last stitches to the main topsail. The sail (reduced by the lower 40%) provisionally on the mast.
  21. Finally the buntlines were attached according Lees and belayed on the quarterdeck rail. This is all the rigging which will be installed on the main yard for now. Buntlines installed Belaying the buntlines. Note the 2 blocks stropped together end on end for the buntlines.
  22. Hi Paul It’s great that you’re back and working again on your beautiful monster. (@ Popeye: do yourself a favor and go to W7. Vista is far worse than W8.) Cheers Peter
  23. Hello Frank Congratulations! What a lovely, dirty, outstanding, smelly, great old boat you made there. With your artistic weathering you achieved one unique masterpiece. Cheers Peter
  24. Hi Ulises Congratulations on a beautifully completed Vasa. May she always swim proudly on your living room table and never sink (contrary to the prototype). But still, looking back now, it was a sad thing but also a piece of luck, that the king intervened and ordered the Vasa built in a way that she couldn’t swim, but nevertheless survive until today. Great work! Cheers Peter
