cdogg
Everything posted by cdogg
  1. Thanks. I need to build a base for the ship. I really didn't like the one that came with the kit. Last night I sprayed primer on about 100 small metal parts, hopefully this week I'll have her close to ready for rigging.
  2. Well, it's been a while but I got this ship going again. Decided on a darker shade of yellow, "sunflower" for the stripe. The railing was a slight pain but a lot of water and jigs helped out. I was worried about the rudder but it went fairly smooth.
  3. Hey guys Sygreen- don't worry about the appearance of the first layer, just make sure it is smooth, it's for forming the hull. I didn't do a great job at this and it really got me on the second layer. As for the taping of the planks, I did that for the second layer. Make sure you leave the strips in water for an hour or so, so they bend easy, then use the nails to get the strips On the bulkheads. Also, sand that first layer a lot and use wood filler for gaps. Looks great so far!
  4. I just looked it up. For #27 just bend it with water, let it dry in the shape you need, and then wrap it parallel with the front piece, not the middle deck. The side will go about 3mm above the sides to make a railing. Make sense?
  5. The Corsair looks awesome man. Nice job. I haven't been around the site for a while, glad to see what you've done.
  6. Welcome back, what is piece 27? Also, there are planking tutorials on the site, do a search. They are pretty good.
  7. Maybe. But I will pose a question, if you varnish the deck before placing the deck components and housing, make sure you know what kind of glue you'll need to fasten these over the varnished deck.
  8. Sygreen, it should be fine. Only problem I had is the pencil lead smudging because if my fingers.
  9. sygreen, you build looks good. For the planks, take a pencil to the top side if the desk plank you will have facing up, this will help define the division of planks and look like deck caulking.
  10. Balsa wood can be used for filling gaps between bulkheads, you can never have enough. You have any updated pics of the build? I hope you didn't become a Cowboys fan while you were in Dallas!
  11. What do you mean by frayed? I dampen the deck planks with water and rubbing alcohol and trim them with a scalpel.
  12. Sorry fish, CA is cyanoacrylate glue, super glue found at hobby stores. I prefer the slow drying one, the drying times are actually listed on the bottle.
  13. My glue did the same, it straightened them out with a little CA. Not the preferred method but it worked!
  14. I think I used 90mm. Take the plans and draw both on paper, use the one that looks best!
  15. Looks great! I used the 2 method on the deck planking, maybe the 3 would be cool? I just went by the book since it was first time deck planking.
  16. Anyone ever use the titebond polyurethane glue? That lookalike it might work well
  17. The instructions aren't clear but you will see you have to angle those along with the filler piece. I think sygreen has this in his build log. This will fix that. Better too long than too short.
  18. I think I filed them down, if you haven't glues it yet maybe compare the bulkhead to the part in the plans in the back of the book, it may help the alteration of the piece.
  19. Easy fix, you will need to use a scalpel and scrap free the deck from each bulkhead. It will work but it may take a while. See the top view in your picture, you will need to expand the opening for the deck house on the deck platform. That's the cause, it's not formed correctly from the kit.
  20. I will check it out, I was thinking about a hull finish like that for my Midwest Sloop kit, thanks
  21. Yes, I'll take a pic of mine tomorrow, actually I looked the manual, step 21. It's looks bad from above but it will look like that from front/rear.
  22. You want a little bit of "hips" at the top, check out pictures of ships from those days. The middle ones should stick out about 1-2mm. Also, I'm a lifetime Minnesota North Stars fan. The Wild are ok but it just ain't the same!
