Dida
Everything posted by Dida
  1. I tried this. Great idea, Stelios. But I did not solve the removal the excess of the wax as good as I wanted. On the lower side of the jar cover I put a piece of balsa wood, 5 mm thick, to remove excess of the wax. I slipped the thread through balsa wood with an needle. I did not make a hole with a drill. Some wax was also removed outside of the jar cover: Here are thread guides: Finished line:
  2. Hi, Stelios! How did you solve the problem of excess bees wax on the threads after waxing in the liquid wax? Is wiping with a rag sufficient?
  3. Does somebody know if it would be better to dilute melted bees wax with some diluent?
  4. Hi! Please, can you tel us which add-ons you use in this project? Thank you!
  5. Thank you for the advices. If you can mention some of your welding tips it would be appreciated.
  6. I know, there is needed a practice to make good joint. I have huge problem to obtain correct temperature when soldering. Each my joint is burned and useless.
  7. Michael, I am also thinking about an serving tool. Thank you for sharing your design with us. How do you move sewing machine bobbin along the guide?
  8. Nice tutorial! What do you use to warm up the ring?
  9. Hi! How do you model the hull's surface? Is there "spline" available in ScethUp?
  10. I am really impressed by this work.
  11. This is very nice project. The boats like this one are in general use here, in Sisak, on rivers Sava and Kupa. They are little bit different, but very similar.
  12. This topic is very interesting to mi, I will follow it!
  13. Thank you Jay! Do you know proportions of ingredients in Britannia alloy - Zn : Pb : Sb = x : y : z ? Maybe on the box write something about that. Does the alloy fill the mold perfectly?
  14. Please, what was the material used to cast the cleats?
  15. I tried to solder with the torch, but I burned the material. The skill is essential, as always.
  16. Thank you Russ! Augie, also explained by an private message what was CA. This is not for the first time that I hit "linguistic barrier". But I am young, I learn fast. Everything will be fine.
  17. Hi, Pett! What is CA? I live in the area where this acronym is not used. Thank you.
  18. Jeff, you will have beautiful ship. Do you have a problem when gluing painted parts?
