cfn1803
1 Follower
About cfn1803
  • Birthday 05/02/1954
  • Gender
  • Location
    Sackets Harbor, NY
  • Interests
    Naval History, War of 1812, Napoleonic Wars
Contact Methods
  • Yahoo
    clayton.nans@yahoo.com
1,011 profile views
  1. Greg, I really haven't figured that out yet. Before I unbolt the model from the building board to fair the hull, I intend to mark and frame the gun ports, ventilation and sweep ports, which will aid in strengthening of the hull. I will fair the inside of the hull and mark the location of the deck clamps and maybe install a few for strength. I then intend to unbolt the hull, add the keelson, then fair the outside of the hull and put in the frame bolts/fastenings. I then need to figure a way to secure it back on the board to continue the build. I should probably embed nuts in the keelson to receive bolts from under the building board? Regards, Clay
  2. Jeff, Wood supply is holding up. Your milling to such exact, scale thicknesses has been just outstanding! Thank you. Your fine work has been and is greatly appreciated. Clay
  3. Break time is over. I decided that it was time to clean off the dust, dust and get back to making saw dust.......
  4. Egen, Such remarkable work! Beautiful! Regards, Clay
  5. Rob, Outstanding progress. The stern timbers are nicely done. Regards, Clay
  6. Egen, Most excellent progress!!!!! Regards, Clay
  7. Toni, Beautiful finish. Outstanding model. Thanks for sharing with us. Regards, Clay
  8. Thank you gentlemen. Greg, I am leaving the top timbers a bit long so I can cut the ports and the sheer in a "seaman like manner". Regards, Clay
  9. Alexandru, I am so glad to see your log. Such outstanding work is an inspiration to us all. Regards, Clay
  10. Greg, Thanks for bringing back your build log. Regards, Clay
