Pete Jaquith
Everything posted by Pete Jaquith
  1. Gary, The scale is 3/16" to the foot (1/64). The hatch coamings are 3/16" above the deck planking. Timberheads are 3/32" sq., bulwark planking is 1/32" and upper hull planking above the copper sheathing is 3/64". The attached picture shows the ledge in hull planking at the top of the covering board.
  2. Gary, I tried a different approach on my Topsail Schooner Eagle. I slotted every third timberhead into the hull, other timberheads were notched into the covering board, and i planked the bulwarks and upper hull.
  3. I used 1/8", 1/4" 1/2" and 3/4" basswood sheet laminated for the bulkhead spacing for filler blocks. If basswood is not available, I would use pine or popular. Shaping was done with #80 grit paper wrapped around 1" and 1.5" dowels. They turned out to be very effective fairing tools rapidly removing unneeded material. This was followed by #120 and #150 grit paper using the same large dowels. After initial shaping with gouges and chisels, I use the same large dowels for fairing laminated solid hulls.
  4. Mikiek, I have used pine or basswood for filler blocks. Easy to work with but firm enough to provide excellent planking support. Attached are pictures from my Fair American build.
  5. Tapering the quarterdeck planks on my Fair American was worthwhile and not that difficult. Shipbuilder. Images 127 & 131 show the quarterdeck and Image 132 shows the process.
  6. Here is how I solved the problem in my 14 Gun Brig Fair American kit. The fillers were either bass wood or sugar pine.
  7. After graduating from Webb Institute of Naval Architecture and Marine Engineering, I joined Bath Iron Works in Bath, ME. My 1st year included an apprenticeship in the "full scale" and "1/10th scale" mold lofts. Very enjoyable time and I learned a lot re structural design, material routing, and design for production. Later in my career, I ran the mold loft at BIW and oversaw the transition to 3D CAD. Today, most of the traditional loft functions are preformed near automatically using artificial intelligence (AI) and the 3D CAD design product model. Recently I have assisted the US Navy and warship builders with recommendations re modern 3D CAD Product Model design systems. For model building, I prefer to draw my own lines using ship's curves, a tapered pine batten, and lead batten weights from my four years at Webb.
  8. As shown in the 1st picture they are great weights for ship modeling. I cast mine at Webb Institute in 1961. Shipbuilder, Pete
  9. Hi Bruce, I used fillers on my 14 Gun Brig Fair American build. The fillers were bass wood, and they were a great help in fairing the hull. The model was single planked with 1/16" bass wood planking. Regards, Pete
  10. Tim, the paint colors are period marine acrylics by Model shipways (Model Expo). Not perfect but I like the color selection. Good to hear from you. Regards, Pete
  11. Shipbuilders, My ship modeling has been limited in recent months due to: Preparation of a major Technical Paper on "Warship Design and Acquisition" to be published in the Naval Engineers Journal Sept. `21 issue, an American Society of Naval Engineers (ASNE) publication. Incredibly hot weather which prevents work in my garage shop. With the paper complete and weather improving, I look forward to getting back to the shop. Regards, Pete
  12. Very interesting and informative build. We are all watching. Pete
  13. I recently purchased the CAF Model 130mm ships boat kit. With some additions as recommended by Allan, this builds into an interesting 18' lap strake cutter. I plan to display it stowed on the gallows in traditional fashion. Next step is on to the quarterdeck rails. Regards, Pete
  14. Allan, Thanks for your input. I will try to address these points in my build. Kind regards, Pete
  15. I recently purchased CAF Model's B-01-130 130mm lap strake ship's boat. The parts are very delicate. What glue would be appropriate for assembly? Regards, Pete - Shipbuilder
  16. With the Brig Fair American hull painting complete, construction continued with installation of hull outfit: Transom trim and carvings were highlighted/painted with Deco Color Prime-Premio gold metallic paint pens Transom windows were previously formed to follow the curve of the transom trim and planking Transom windows were painted, glazed, and installed (Micro Kristal Klear was used for window glazing) Ship’s name was installed (prepared and printed with MS Word) Rudder chains were blackened and installed Next steps will continue with installation of the quarter deck rails. Regards from the shipyard, Pete Jaquith
  17. An old article from the files using copper tape. Regards from the shipyard, Pete Copper Sheathing the Ship Model Hull_Rev 2.doc
  18. Shop conditions have improved allowing further progress. With the Brig Fair American hull painting complete, construction continued with installation of hull outfit: Chain plates were fabricated from 22 ga. silver soldered brass wire rings (1/2” and 7/16” dia. respectively), formed around the deadeyes, and closed with soft solder. A simple jig was used to check the forming of deadeyes. Deadeye/chain plate assemblies were painted/installed Channel caps were painted/installed With the bow and P/S side zones complete, next steps will address completion of transom details. Regards from the shipyard, Pete Jaquith
  19. Shop conditions have improved significantly. Now working to relearn past skills (i.e. silver brazing, window glazing, etc.); however, overhanging potential of a large full scale shipbuilding project. I will have to work to balance priorities. Pictures will follow completion of chain plates, lower deadeyes, channel caps, etc. Regards from the shipyard Pete
  20. With the Brig Fair American hull painting complete, construction continued with installation of exterior hull outfit: Gangway steps were painted/installed Gun port hinges were fabricated, painted, and installed based on a mini-kit from Syren Ship Models Quarter badges were painted, glazed, and installed (Micro Kristal Klear was used for window glazing) Next steps will continue with installation of chain plates, lower deadeyes, and channel caps and then it’s on to complete the transom outfit. Regards from the shipyard, Pete Jaquith
  21. Bob, Tim, A little cooler/less humid this morning. Looking forward to some progress in the coming days. Regards from the shipyard, Pete
  22. Limited progress due to CA heat wave (~116 outside and high 80's in my shop). Working P/S exterior hull outfit: Gangway steps - complete Aft gunport hinges - in process Quarter badges - in process Chain plates, lower deadeyes, and channel caps - next up Pictures will follow completion. Regards from the shipyard, Pete
  23. Etubino, Building up the Brig "Fair American" stern structure was an interesting challenge. Once complete with windows, ship's name, and quarter badges it should be impressive and representative of these beautiful ships from the past. Regards from the shipyard, Pete
  24. Working exterior hull outfit. Progress put on temporary hold due to CA heat wave and resulting high temperatures/humidity in my garage work shop. Regards from the shipyard, Pete
  25. With the Brig Fair American hull painting complete, construction continued with installation of the head rails and bow fittings: Head rails were previously fabricated/dry fitted from 3/32” laminated stock (3 layers of 1/32” sheet stock with opposing grain) Middle rails were previously fabricated/dry fitted from 1/16” sheet stock Cheek knees were previously fabricated/installed from 1/16” sheet stock Boomkins were previously fabricated/dry fitted from 1/8” sheet stock Catheads were previously fabricated/dry fitted from 3/16” sheet stock Head and middle rails were pre-painted and installed After checking the head rails from all angles; they were primed and finished painted. Gold trim was applied with Deco Color Prime-Premio gold metallic paint pens After completion of the head rails, catheads were painted/installed Figurehead was painted/installed Boomkins were painted/dry fitted To avoid potential damage, the boomkins will be left loose for later installation during the rigging phase. To allow construction access, the bowsprit, bowsprit bitts, and fore bitts will be left loose until completion of bulwark interior fittings and cannon installation. With completion of the head structure and gold trim she is starting to look like a fine little armed brig from the 1780’s. Next steps will continue with installation of exterior hull outfit. Regards from the shipyard, Pete Jaquith
