Everything posted by Wintergreen
Yep, its been lurking in my mind for over 20 years, and feels really good to finally get it out in 3D.
- 89 replies
- billing boats
- regina
Here are some photos of how I made the iron strapped blocks for the anchor tackle. Usual copper wire. In pic #2 I was a bit to slow with the torch. "well, lets just make another one shall we?" Here is the #2 try. Soft soldered since I don't have any hard soldering paste (yet). In the last picture the copper is painted because the soft solder did not take the blackening. And finally, the work with the dingy. The provided plywood sheets were warped and of very soft material. I will use them as templates only. Here is the keel assembly with stem and stern glued and dowelled. Behind lays the plug that I will use for planking. The red paint on the frames is an idea that I will credit Dafi (Daniel) for. It makes it so much easier to see when it is time to sanding...
- 89 replies
- billing boats
- regina
Lads - Thank You! Its good to be back in business.
- 89 replies
- billing boats
- regina
Hi Kats and "Welcome back"...I too will sit back and follow as you go (slowly) for the completion.
- 237 replies
- cutty sark
- revell
And from your on saying, its now the fun begins, eyh?! (read Rigging) Good to have you back!
The above picture was the last in the old log. From here on I am up to date. The boat is mainly finished (pics will come later) and work has started with the stern boat. The final picture for now is below. Remco was teased to do a proper splice for his mast pendant and that triggered me too. It WAS fiddly but in no means impossible to splice the thread.
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
The boom dry fitted and a bit naked. I later trimmed down the reeve boards at the end. Here a bit more crowded with tackles of various functions.
- 89 replies
- billing boats
- regina
Ironwork for the mast. Comparison between suppliend and scratch made jaws.. Soldered, blackened and waiting to be installed. Dressed with blocks also.
- 89 replies
- billing boats
- regina
Over to mast and spar making. The supplied rod for the boom was too thin so I made my own. Provided mast hoops was of plastic, replaced. Other mast rings and boom rests also plastic, needed replacement. And yes, the mast had the shape of an bow that would make Robin Hood happy...replaced.
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
ok, I guess the sw has the limit at 25 posts a page. The old one had 10 so this is better. Need to keep the posts a little shorter though. A quick "how to" I turned the dead eyes. There are various ways of setting the diameter. Since I only have a wood lathe, this is what I use. Mark the thickness of the eye.
- 89 replies
- billing boats
- regina
I would assume that the sw wanted to change page now, but not. Interesting. Next was produce the dead eye strops. To drill holes in dead eyes this is a fairly common setup (with variations)
- 89 replies
- billing boats
- regina
- 89 replies
- billing boats
- regina
Other small stuff that I did apart from cleats, were blocks and bulls eyes. For the bullseye I used a rod of suitable diameter, drilled out the centre and squeezed into an eye bolt. The main sheet horse and block All of a sudden it appeared that I had a visitor in my yard... The crowbar was a bit worrying I thought... Next up was chain-plates and deadeyes.. After blackening.
- 89 replies
- billing boats
- regina
Hi Steffen, and good to see you back with your log. I'll follow along to guide you if I can (no promise, just an offer )
- 35 replies
- norden
- billing boats
Another Rope Walk
Wintergreen replied to michael mott's topic in Rope Making/Ropewalks's Rope Materials and parts resources
Ah, ok, now its clearer to me. Thx!
