Everything posted by keelhauled
Hi Harry! Happy New Year! I hope your summer is going well. Had a great time in Melbourne and Sydney a couple of months back. It was business, but I got a day free on two weekends. spent it on the water! best, Marc
- 521 replies
- cutty sark
- mantua
Additional comments on the position of the cro-jack Sheets on the pin. I was recently in Australia and got to spend time on another tall ship. I spoke to one of the crew about the topic. He said that it made sense to him and that the cro-jack doesn't usually have that much stress on it since it isn't usually used in heavy weather. He said that it should only take three or four hands to to comfortably to pull the the sheets when setting the sail since the bulwark fairlead is being used. To adjust the sheet in fair weather it would only take one hand. He made his point by handing me the sheet and asking me to adjust it. I couldn't believe how little effort it took. I could have done it with one hand. He said he wouldn't be concerned with belaying that line to a pin if it was large enough to accept it and the sail plan reference to belaying to a pin sounded correct to him. best, Marc
- 521 replies
- cutty sark
- mantua
Cutty Sark spanker, spencer and staysails rigging
keelhauled replied to Bruma's topic in Masting, rigging and sails
Hi, I just came across this post. Bruma, I know that it is too late for a response to help you, but it might others who are looking for the same answer. the research I've done matches how you rigged the spencer in the stowed position. I rigged mine in the same manner, brailed. nice model, Marc -
Hi Marco, You are very kind. At about 4am this morning I woke and realized that I forgot the sheets! crazy the way my mind thinks. I remember spending too much time researching that topic. In general, I found contemporary paintings (don't like as reference) and photos (often to overexposed or grainy) which showed clippers having both sheets with single and sheets with whips. For the Cutty I couldn't find a photo where I could see staysail sheets. As you say, Campbell shows the Cutty with singles. The painting by F Turdgay painted in 1872 which is with Campbell's plans used for the restoration, has the Maintopmast staysail with whips and the others appear to be singles. As a result, I don't think it matters. Time to be our own captains best, Marc
- 521 replies
- cutty sark
- mantua
Hi everyone, I was asked about the details for rigging the main staysails on the Cutty. I thought that others might have the same questions, I know that I did. So, I thought that I would share my reply here. It isn't clear from many sources where lines are belayed or some of the details. Here is my take on it. Based on my info here is what I believe this info to be correct. For these references my primary source is Campbell’s plans. It took a lot of research to find this info and some dry rigging runs to verify. I messed up on my Cutty and forgot the staysail whips on my model until it was too late to correct the oversight. I was too focused on the halyards. However, Campbell and others do not have whips for the staysails. Who knows?! I’m not saying that this is absolutely correct, but it makes sense and is based on Campbell as much as possible. The block sizes, line sizes, fairleads and whips are from Campbell. The actual pin locations and the aft foremast pin rail is based on other references. That fore aft pin rail is debated. Main Topgallant (t’gallant) staysail. The Topgallant staysail halyard is doubled. The halyard is attached to the lower eye of a two-eye single 8” block Starts attached to the strop above the cringle for the lifts. In execution I moved up above the backstays so that the block cleared the stay. I believe that it is a 2 1/4 inch hemp line. The halyard goes down to and through another single block which is attached(shackled) to the main t’gallant staysail’s peak cringle and back up and through the 8” block where it started. The line then goes down to the starboard topgallant fairlead then down to the pinrail below and forward. The 2” downhaul is attached to the shackle at the peak cringle of the sail where the halyard is attached and runs through the hanks to the tack cringle of the sail and to an 8 inch single block then is which is attached to the topgallant stay below the roller. If you do not have an aft pin rail the line goes down to the port side. Here it terminates in a whip (If you decide to use one, otherwise belay directly to the sheeve or the pin), where the downhaul ends in an 8 inch single block. the whip line is spliced to a hook fastened to the lower band – aft port side. The whip runs up through the single block and back down to the spider band and is made fast to a belaying pin- aft port side. (there are three pins and eyes on the aft side). If you have the aft pin rail which is the same as the fore pin rail, the line goes down to a whip and instead of belaying to the spider band, the line either goes directly to the port pin on the rail or goes through fore to aft the outer port sheave of the pin rail and up to the belaying pin. The topgallant staysail is a held to the foremast using a strop passed around the fore mast and shackled to the tack cringle. The block is just below the strop Royal staysail The royal staysail is doubled and the same rig as the t’gallant. The differences are that the halyard is 2 ¼ inches with 6 inch block. The downhaul is a 1 ¾ inch down haul. The halyard goes through the port royal backstay fairlead and to the pin rail to the pin just forward of the backstay. The downhaul whip uses the center eye and belaying pin on the aft side of the foremast spider or the center pin in the pinrail if you have one. Main staysail The main staysail is doubled and same rig as the t-gallant. The differences are as follows. The halyard and downhaul are both 2 ¼ lines. Campbell says that the downhaul block is 6”. The down haul block is attached to the main stay just aft of the spider band on the starboard side (see photo). The mainstaysail is a held to the main topmast stay using a strop shackled to the tack cringle and the leg of the stay just before the seizing begins. This stop needs to be long enough to allow the sail to clear the deck house. The halyard block is attached to the port side 2nd most aft eye of the trestletree (fore aft) of the top mast crosstree. There are 5 eyes on the trestletree – going from forward aft this is the 4th eye, port side. The halyard goes to the port topmast backstay fairlead, forward hole (there are three holes) and to the pin rail to the pin just forward the stay. The downhaul whip (if you use one, or directly to the belaying pin) uses the starboard eye and belaying pin or the starboard outer sheeve and pin if you have an aft pin rail. I know the photo has the downhaul belaying directly to a pin (no whip) on the portside. I have photos with it belayed on the starboard- I think that they moved the line so that it wasn't in the way of repairs (see the barrier next to the mast and the lines leading forward to block visitors from the port side of the deck). What can you say? Also, I don't see how you would use a whip in this case with the block so close to the deck. Hope this helps, it’s taken me a few hours to put together, but a pleasure if it helps you. Marc
- 521 replies
- cutty sark
- mantua
Vladimir, l meant to ask you why you weren't working on your rigging. If you are willing to share. Best Marc
- 521 replies
- cutty sark
- mantua
Hi Harry She's taking shape. It's a very cool process. I like the lookof th cladding Best Marc
Thanks Rob Campbell has them labeled bollards on the general arrangement plans for the Cutty and Underhill uses bollards in his Cutty Sark book and got used to thinking of them labeled that way. However, I am used to the term bollards being used for these items ( both single and double cylinders) on the docks and piers and bitts on the boats in the US and Carribean. Maybe it's an example of differences in the terms used in different regions to refer to the same item. Thanks Marc
- 521 replies
- cutty sark
- mantua
Crojack sheet mystery solved. This is one of those cases where you've searched over the plans numerous times and missed the information in front of your face. Maybe this doesn't happen to you, it's only me. I posted the question under rigging on this site. B.E answered with directing me to Longride's Cutty Sark book. I had seen the information he referred me to which addressed the standing location of the sheet, but not the working portion of the sheet's belayed position., However, thanks to B.E., I went back through all of Campbell's pans again. comparing the Longridge info against Cambell's plans. I found that the info I was seeking regarding the belaying point is in the Rigging Plan. I guess that I spent too much time looking at the sail plan. However, I did look at the rigging plan several times and missed the comment pointing to the sheet: "4 inch hemp rope through sheave in bulwark and belayed on pinrail." You were right Harry! I had actually, given up searching and had decided to add another set of bollards to mount aft of the pinrail for the crojack sheets. I made two sets of the bollards from steel on my lathe and soldered them in place on a brass channel. I made pins in the bollards to provide unnecessary support and alignment . I also launched a single bollard into outerspace (or at least my ceiling) when I was parting it. No use looking for that tiny part in my cluttered garage. Here's my handiwork. My first attempt at making bollards. Not great, but better than the castings. Now they aren't needed. Oh well.
- 521 replies
- cutty sark
- mantua
Hi all, Thanks to B.E., I went back through all of Campbell's pans again. The belaying point is in the Rigging Plan. I guess that I spent too much time looking at the sail plan. However, I did look at the rigging plan several times and missed the comment pointing to the sheet: "4 inch hemp rope through sheave in bulwark and belayed on pinrail." In Campbell's plan the sheet is belayed to the pinrail not the bollards like the other sheets and as she is now. Mystery solved. Thanks Marc
Hi B.E. thank you for researching this issue! I can see the standing portion of sheet being made fast to the quarter bumkin. However, the working end continues up through an 11" block attached to the sail and then it has to go back back to ship. Where is the mystery. Campbell's plan shows and the actual ship has the working end continuing through a fairlead. I really appreciate the help. best, Marc
Ian thank you for the information and video. I really appeciate the help!!! Harry, thank you for alerting me to possible issues!!! Keep on doing so and reminding me of what i need to keep an eye on. I have continued to check the fore deck house. The staysails dont have their sheets rigged yet because if I do i loose access to install the forward deck house. Im still trying to figure out how to best rig some lines that will be on the pin rails beside the forward de k house. Sometimes is lind of a chicken/egg issue. Same with the aft deckhouse. Keep reminding me!!!!!!!! Thanks Marc
- 521 replies
- cutty sark
- mantua
Thanks Harry. I'm considering just adding another set of bollards beside the pin rail. Or just making it fast to the pins. I had already placed the existing bollards aft according to Campbell's plans. To me it doesn't make since not to use the sheave in the fairlead. To rig the sheet aft without it running against the sheave would cause excessive wear to the sheet. Also the sheets for the larger courses run forward from the bulwark Fairless to much smaller bollards on the rail. I have time to figure it out. I realized that the starting points for the braces need to be addressed while I can still maneuver the sails. With the sails in place, the sails are making access the starting position of the bracing line difficult to access and attach to the shrouds. There is a similar issue with the brace pendents. I won't rigg the braces till the end. But I need the sails in their braced position when I tension the lines coming from the yards and sails. Also with yards in their braced positions, the eyes to attach the pendants on the leeward side are facing inboard and difficult to access. Thus if I don't add the pendants and braces to their origins now it will be almost impossible later. Best Marc
- 521 replies
- cutty sark
- mantua
Hi, I need some help determining where and how to belay the cro-jack sheets on the Cutty Sark. I'm looking for help and insight. In researching the belaying point I've looked at the actual Ship in London, Longridge's the Cutty Sark with Harold Underhill's plans and the Campbell's Plans, which were used as one of the primary references when they restored the ship. I've drawn this diagram to help the discussion. In figure A. I've illustrated the ship as she was in 1990 and 2019 when I last visited her. The Crojack sheet goes through the bulwark fairlead where is goes around the sheave and out onto the deck and is belayed to large bollards forward of the fairlead. This is actually the way all of the other coarse sheet are rigged currently. The fore and Main course sheets are also rigged this way with small bollards on the rails. Here is a shot from 2019 The oldest references which are Campbell and Underhill's plans have these large bollards aft of the crojack bulwark fairleads as illustrated in B. It is my understanding that the bollard was moved forward when the ship was owned by the Portuguese company. I can't imagine that the sheet would go through the fairlead and then aft to the bollards. Unless, perhaps if the crew pulled the sheet forward and then stopped the farilead and made the sheet fast to the bollards aft of the fairleads? I was thinking of the way that the has a procedure for stopping the line when raising the halyard lines and brining them up to the pins? As you can see in the photo above there is a pin rail located forward of the fairleads, but these are completely full when the ship has sails. unlike some of the other pin rails, these don't have wooden bollards, just a knob-not even a pin. If you think that the sheet would be belayed here, how would it be made fast/secure? Thanks in advance for the help! best Marc
- 521 replies
- cutty sark
- mantua
Hi Harry, The build is very cool. I was intrigued by the multimedia approach. I went through the build last night, but need to go back through in detail. I atill dont know how i missed it. Glad you're well. Cheers Marc
Wow! what a build. very impressive - and it looks very small and fiddley. Sorry to hear about your illness! I hope that your well soon! I wish you the best my friend. You're an inspiration! cheers Marc
Hi Harry, Any updates? I'm still waiting to see her in the water
- 118 replies
- sanson
- artesania latina
Looking good! Keep up the great work!
- 182 replies
- billing boats
- cutty sark
Cutty Sark by NenadM
keelhauled replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
very impressive work going on there! You're very creative. Hope all is well with you and your family! best Marc- 4,151 replies
- cutty sark
- tehnodidakta
