Posts posted by Adrieke
thanks Popeye. i better if i want to finish her by end of year
thanks Robbyn
still lots to do but i love working on her again
thanks Mick and Mark . might see if i can get that song and play it while i work on her
thanks Mick
they are from the brand CraftRight. I bought 4 sets of 2. so far one has broken when I put too much pressure on it. they can be reversed so you can do clamping spreading. one thing annoying is that the orange non marring pads slide off too easy.
overall I good investment because I use them all the time as you know
thanks Robert
cutting a little slot all around the top deck has made it easy to fit the brass parts
with that done I can now finish the walkways that give access to the steering cabin
I did notice that the ladder is not high enough (8 steps according to AL instructions) so I ll need to extend them with one more step. the sides are painted white so I should be able to cover up any gaps
- robert1965, Piet, popeye the sailor and 3 others
6
Thanks Edwin
I might try that next time.
I am now waiting on the last 2 of the side parts to dry . so tomorrow I can begin pre-bending the master planks
- Sjors, robert1965, edmay and 4 others
7
Sherry,
my sincere condolences to yours and your families loss
I will light some candles and pry for you all
I hope so Piet. I hope so
I have taken a day of Friday to take care of some financial business but that will leave plenty of time to continue the sanding , might even be able to finish so I can start pre bending
- popeye the sailor, augie, mtaylor and 1 other
4
finally a small update
installed the small steps in front of the 3rd deck doors
also working on the top deck edge, but the parts stick to everything but the deck . I am using the cut-out of the deck to form the brass parts and keep them in place while glueing
I am now thinking of cutting a small slot around the edge so that they fit in there
excelent work Robert. you ll be working on the finishing touches next . you ll probably finish her before me lol
its so much fun watching your build Danny
not only showing use amazing craftmanship but teaching us newbs the correct terminology
Piet , yes i l be soaking the planks and bend them temporary in place till they dry. then i l be sanding them so they ll fit snugle against the planks already in place. i want to make this as good as i can
Popeye, even tought they are 3 mm they are still flexible enough (even the 4x5 masterplanks) and i am hoping to have to do as little sanding as possible
For me this will be lots of learning because its the first time i am really planking (when i did the virginia i just wne for it and hoped for the best and hought i could sand/fill any problems)
I tried just now a shorter message with 3 photos and the "page could not be displayed" message came up when I wanted to preview what I had done so far. Maybe something else is going on.
I will try to copy a new post to Word next time before I even before I preview it. A while back I tried selecting the text and by using 'Control C' it should have been put on the clipboard. But after the "pcnbd" message and getting back into MSW the clipboard was empty.
Rick
I am on win 7/IE 10 also and on rare occasions I have issues but not like you describe. have you got any toolbars like yahoo or Google installed. In the past these could cause a fair bit of issues
Hmmm .... strange that you got away with pics that big Adrieke. Maybe the limit has been upped (and no-one told me
Danny
I always read it that each file could 2MB, with 10 each that would make it 20MB per post Maybe one of the admins can let us know what the limit is
thanks Piet
I haven't considered adding a filler block. I don't think the planks need added support as they are 3x7 mm strips but now that you have brought this up I might test this out just in case
umm sorry Danny but look at this post of mine where i have 8 pics of around 450K (so over 3MB)
http://modelshipworld.com/index.php?/topic/1555-gorch-fock-by-adrieke-occre-195/?p=121162
hello Rick
looking good so far
i am really looking forward to all the enhancements you are going to put in
as for making it that you can still access the insides, its not going to be easy (ask me how i know
) might be easier to make the back wall and paddle wheel detachable so you can get to the inside from there
thanks Mobsie
certainly workign on my patience skills with this
thanks S Coleman
i certainly hope so
thanks Mick
for the encouragement, i do need it as its so easy to say its good enough while i know its not
thanks Robert
yup certainly is . normaly i would have been sneezing after that but i think doing it outside has prevented that
actually I find it more grinding on the muscles in my arm , after 2 days its really hurting and my hand feels numb
i am using a half round file and a square one and some sandpaper wrapped around a wooden block for the big areas
i guess the square file gives the same result as a long strip of wood
as the bow end needs to be sanded to a point i slowly reduce the width until only a fine line is left, this to make it easy to see where the middle is
the master plank is 1 mm thicker and fits in the slots in all the bulkheads, so to make sure it doesn't stick out i filed out a slot in the bow too
finally i sand it down to a point and use a wooden strip to make sure it runs smoothly all the way
after one and a half hours of sanding the bow is done
finished all the bulkheads in between and all that is left is the stern, but its getting too dark now.
i estimate at most an hour or two more of sanding but that will have to wait till next weekend.
i ll work on some other parts in the mean time and also spend some time on finishing the kom
- Sjors, robert1965, Mirabell61 and 4 others
7
very very nice Robert. looks all perfect to me
King of the Mississippi by Adrieke - FINISHED - Artesania Latina - Scale 1:80 - with LED lighting
in - Kit build logs for subjects built from 1851 - 1900
thanks Piet
Mark I am with you on that
. I need to get a good mp3 player and download (legally offcourse ) all those good old songs.
in the end I had to add 2 steps to the ladder . here I have put a first coat of paint on it
here my setup for tapering the dowels
had a few accidents. the middle dowel broke in half
. but with some CA and tape I was able to fix it and finish the tapering
the one the right broke also , I had just enough of the 4 mm dowel left to replace it
