Posts posted by Adrieke
thanks Lawrence the deck planking was a lot of work an di did make a mistake which I was able to cover up . the wire I used was the smallest they had in the store and as I am not an expert I thought its better to have it thicker then necessary. if I do lights in the future I will be looking more at some of the other options like optic fibre . anything to not have to solder too much lol
thanks Popeye
thanks Robbyn recently I did some searching for Tblacks scratch build of the vinal haven. he needed a eagle statue. I found some railroad websites and find out HO scale is pretty close to the scale of this ship. so maybe, once I got some budget again, I ll see if there are some figures and horses I can find for her
thanks Rick
from what I have seen so far of your build Rick it will be even better and the working paddle wheel is awesome
ok the daily update pictures :
railings are done on one side
I have also added the capstan
this pictures shows more clearly the 2 breaking points above the deck and less visible the break I fixed before the mast was put in place
but I have good news. OcCre has put a whole extra dowel in of the correct size in the GF kit. a try with some of the oak stain I have cam out ok. not completely the same color but close enough
so tomorrow I will make the new one : tapered and stained before I ll rip the other one out (just in case I change my mind)
what is left once that is done:
- railings on one side
- rig the mast with the gangplank (which is already constructed)
- inspect all the railings and triangles and touch up any spots unpainted
- varnish the railings, masts and gangplank
- and finally hoist the flag
- themadchemist, Piet, Anja and 7 others
- 10
Popeye if you d go back to some of the earlier pages you ll see that the bar was already set up for Sjors and Robbyn so come on in
thanks Robbyn yes its holding but the breaks are too visible top let it like that. this weekend i ll have a count of the dowels for the GF and see if i can pinch one . i l have to stain it but might be better then what it is now
thanks Anja it wil be soon , i am just checking everything to make sure i am not forgetting anything
thanks Mick this weekend she will be atleast mostly done (unless reall life interferes too much as it usualy does on weekends for me) but wiht luck i can finish her
thanks robert
- Shazmira, mtaylor, popeye the sailor and 1 other
- 4
- robert1965, themadchemist, mtaylor and 4 others
- 7
thanks Joe i l be posting daily updates til she is finished
thanks Popeye very close now
thanks Mobsie i am always good :mellow:
no worries dragzz glad i could help
- mobbsie, popeye the sailor, Piet and 4 others
- 7
hello Dragzz
look at this picture the back off deck 2 and 3 need to be right above each other
when you fit the 3rd deck on top of the 2nd deck stateroom with the pre cut slots you will notice that the 3rd deck doesn't line up at the back and is a bit forward. if you adjust the pre cut slots till the decks are equal at the back you will see that the 2 holes for the smoke stacks will line up too as will the holes for the slanted poles
dragzz , i remember at first ,like you thinking the holes wherent lined up but its actualy the hole top deck that needs to move
if you get the full scale plan you ll see that at the back end the 2 decks shoulc be directly above eachother so that the poles are verticaly
in my kit they didnt and i had to cut the slots of that deck so it will slide backward a bit. when you do that the 2 holes for the steam stack will line up
when i am home i ll see if i can dig up some pictures thta show what i mean
Tom
i found some eagles HO scale at this site http://www.musketminiatures.com/
it says they make the detaqils themselves , so might be an idea to contact them and see what they got in your scale
also found this topic on a railroad forum on how to make your own eagle in HO and O scale with a parts template
thanks Popeye . the reason i can go quicker now is because i have already prepared most of the parts almost a year ago
thanks Mick, yes i l be happy when i finish her. then i can finish my other project (stagecoach) while workign on the GF
- Piet, robert1965, mtaylor and 1 other
- 4
thanks Popeye , yup almost there
thanks Sjors
thanks Joe , the pleauser was all mine , i have learned a lot workign on here , most of all i think having patience and nto be satisfied with something i know i can do better
thanks Anja . and yes i will replace it , the breaks are too obvious even if the fix holds.
thanks dragzz.as a second build i think i havent done too bad
hello dragzz looks good
I assume you haven't glued to the deck yet since its not planked but in the pictures you have put it on backwards
sudomekh no offense but as I have mentioned before I am still new to making wooden ship models and as such do not have the skillset to even try to go that detailed at this point in time
thanks Robert and Mick
planking has slowed down a bit since all the planks now need lots of tapering and pre bending
I estimate 2 more weeks to go. then the next sanding and filling fest will be on getting the hull as smooth as I can
the steam stacks have been installed and I am now working on the reinforcement cables
you can see the mast has got some masking tape around it. this is because I have now broken that mast 5 times in 3 different places I have no dowels left
what I might do is check if I have plenty of dowels from the GF. I would need to remake the 3 parts as these dowels are a different color
thanks Popeye and yes both sides
thanks dragzz
thanks wackowolf I have some oak stain. tried it out on the support brackets of the shelf
thanks Mobsie I am thinking of buying a glass cabinet with glass shelves, because although expensive will be less in price then if I buy/make cases for each model individual. but if I would put her in a case It would have its own bottom board
sudomekh , the pedestals I got are the largest ones available.
today I went to the store to get the board and screws
when I came home I realised I had gotten not the 290mm wide board but the 190mm one
but it turned out ok since the width of the hull itself is only 150mm (260mm must be with the yards sticking out)
what I will need to do is round off one edge (since this is a shelf it is not bevelled on the wall side) and then figure out if I am going to stain it or just varnish
what do you guys think :
i noticed before that the 4 bulwark sections didn't fit all the way to the deck level. so i cut off about 2 mm at the top to fit in a replacement plank
only need to paint the inside of it white again
Corsair by DCIronfist - FINISHED - OcCre - 1:80 scale (First wooden ship build)
looking good David
