hollowneck reacted to a post in a topic:
HMS Sphinx 1775 by brunnels - Vanguard Models - 1:64 scale
TimF reacted to a post in a topic:
HMS Indefatigable 1794 by Blue Ensign - FINISHED - Vanguard Models - 1:64 scale
Paryzek reacted to a post in a topic:
Kentoshi-sen by Glen McGuire - FINISHED - 1/400 - Bottle
HMS ANSON 1781 by albert - 1/48 - 64 guns
USS Pennsylvania 1837 by threebs - 1/72 scale - second build in this scale
HMS Victory by Pfälzer - Corel - 1:98
Paryzek started following HMS Victory by Pfälzer - Corel - 1:98 , San Felipe by Roy812 - OcCre - 1/86 , Kentoshi-sen by Glen McGuire - FINISHED - 1/400 - Bottle and 7 others
La Créole 1827 by archjofo - Scale 1/48 - French corvette
HMS PEGASUS by giampieroricci - Scale 1:36 - Swan-Class Sloop from plans by David Antscherl & Greg Herbert
Le Fleuron 1729 by Chris. - scale 1/72 - French warship from Delacroix monograph
HMS Victory Anatomy Version by JeffT - Artesania Latina - 1/84
brunnels reacted to a post in a topic:
mtaylor reacted to a post in a topic:
HMS Agassiz 1941 by Johngr - FINISHED - HMV - 1:250 - CARD
These "modern" ships are not in my area of interest, but I'm happy to rate something that is really good. Beautiful model.
HMS Sphinx 1775 by Paryzek - Vanguard Models
rcweir reacted to a post in a topic:
Another small step. I finished the horseshoe plates and stern fifshplates on both sides and the rudder complete hinges. The wood under the walles got its first coat of wax. I also folded the rest of the bow under the grating and installed it on. The second layer of siding doesn't look bad, so I decided not to use white paint. I like wood. Today I also installed gun port parts on the closed gun ports on the bow and stern and am working on the hull side stairs. I will take pictures later.
I think if I were to remove everything from under the side gallery windows. I can first glue the wooden moldings properly, and then install the new brass ornaments between them. The problem is that they cannot be removed without serious damage. I can make the ornamental moldings myself, I have pear wood, but I can't deal with those etchings. And if I pull them down, I will destroy them.
I'm reporting the next step. Unfortunately, I did something wrong. Very wrong. I installed the decorative moldings on the side galleries incorrectly and the whole thing didn't fit properly. It can't be removed without serious damage. I'll try to order new brass etchings from Mr. Watton (if possible) and redo the whole thing. I can make wooden moldings myself, but unfortunately not brass etchings. Where were the main mistakes? 1, I didn't read the instructions, my fault 2. I don't know how to work with CA glue very well, I'm more of a carpenter. 3. I was in a hurry and didn't think, another fault of mine If it's not possible to buy a plate with etchings, I'll have to leave it like that
Hello, I'm back after a while. Health problems caused a delay. (sore back, herniated disc) I added the second layer of planks. It's not quite 100%, but I like it quite a bit. I decided not to use white paint on the bottom part and leave only wood. After adding the brass parts, there will be wax. Now I'm figuring out how to install the rudder Small hole.
