catopower
Everything posted by catopower
  1. Thanks for the sage advice David. I don't believe that's the issue in this particular case, but it's certainly a point well taken. I'm curious if anyone has ever tried to use the pre-printed planks to aid in the building of wooden models? As far as I can tell, most of these kits don't include individual planks, but the Shipyard Alert kit does, and so does their Le Coureur kit. For the wood ship modeler, these kits seem to be excellent at illustrating the proper shape of hull planking as well as the joggling of deck planks into the margin strakes. Anyway, I'm discovering that card models are not easy, but they are fun. Here are some pics of the model just before I added the keel and glued the bulwarks into place. I'm learning that paint really does cover a multitude of sins and works very well on this model! Clare
  2. Hey Bob, Congratulations! You've passed the half-way mark, at least as far as the step numbers in the instructions go. Time to celebrate with some Sake? I really like the way the wipe on poly looks on your model, particularly on the thin, colored wood. It's all looking really nice. But, you're making want to build another Woody Joe kit now... Clare
  3. Hi Ken, I'm going through basically the same thing as you. I have a model of a colonial schooner and I'm working on my rigging/belaying plan. Hahn's drawings aren't much help except for the overall rigging plan and his book The Colonial Schooner basically is just a place to find those drawings. I found little else of use in it regarding rigging. I wouldn't trust Petersson's book either – very specific craft and periods. But, as Russ and Greg have said, the Sultana should be a good guide. I have the Model Shipways' plans and they look pretty reasonable since both my schooner and the Sultana belay lines to shroud cleats, mast cleats, timberheads and a few to cross bitts. The Hannah should pretty much be the same and it's of the right period, right type, similar size. Clare
  4. This is a great discussion and I am enjoying following everyone's posts immensely. While I'm kind of an advocate of the old solid hull kits, I had to "like" Brian C's post because it's honest and I think it adds a lot to this discussion. Plus, I agree, it is a shortcut. But, like neptune (John) points out, so are all kits, really. Still, I think there need to be some kits that are more shortcut than others. Anyway, the degree of shortcut depends a lot on the quality of the solid hull and availability of good plans/templates. Some kit manufacturer's hulls are less shortcut than others and can require a lot of carving and sanding to finish/correct, while others may require very little. So, I wouldn't say that all solid hull modeling is harder or easier than plank-on-bulkhead. It can be harder or it can be easier depending on what level of perfection you want and that's what I like about them. I like to see solid hull kits remain on the market through BlueJacket, Model Shipways, A.J. Fisher (still around), and even Amati (1/80-scale J-Boats kits with pre-carved hulls). Clare
  5. Beautiful work Bob! For me, planking the deck seemed to take forever. I guess it had to do with cutting all those short pieces and also making the supporting beams and making sure the planking panels all fit nicely. Like I said, you've done a beautiful job. Clare
  6. Pete, your models are truly awe inspiring, and I particularly love your solid hull work. This topic wouldn't have been complete without your input! Clare
  7. Andy, beautiful work you've done and congratulations! Hey, on those portraits, now which one is you and which is the original? Clare
  8. I've built several solid hull models, some from kits and some scratch. Personally, solid hull is still my preferred form of scratch building. Solid hull kits have the beauty of construction flexibility. A beginner can take a solid hull kit and do almost nothing to fix up the shape of the hull (depends a bit on the manufacturer) and build a nice looking model. A more advanced modeler can take a solid hull and fine-tune the shape to build an accurate model. As pointed out, one can plank over the solid hull, which provides a solid foundation for the planking. Going a step farther, a solid hull can be carved down to accommodate the planking more accurately (the thickness of the planks do change the dimensions of the hull slightly). Solid hull kits avoid some of the pitfalls of plank-on-bulkhead modeling since you don't have to worry about shaping planks unless you choose to plank over it, and you're less likely to end up with bumps and flat spots, which can often appear on plank-on-bulkhead kits if you're not careful. It's true that I've seen some people be a bit disrespectful regarding solid hulls, but not really here. But it did take me a lot of work on another forum to convince them to go beyond listing model categories as: Plank-on-Frame, Plank-on-Bulkhead and Other Models. But, there's a lot of "solid" support here (pun intended). Well, all of this is to say, build your model and enjoy it. I hope you start a build log and post photos of your progress. Clare
  9. Well said Don! I haven't started a build log because I was just experimenting with one of the smaller Shipyard kits. I wanted to find out what it was like to work in paper and I had no ties to finishing it, so I didn't want people to be following something I wasn't necessarily going to complete. However, it's actually turning out to be so much fun and such a nice build that I'm now thinking I may continue with it and turn it into a build. I will decide soon and I would say the 1:96-scale kit can be just about as nice as the 1:72-scale kit. You just have to do a lot more gluing and cutting. And, of course, everything is smaller. Stay tuned if you're interested. In the meantime, I started a write-up/discussion about the kit here: Shipyard H.M.S. Alert, 1777, 1:96-scale Paper Model kit Thanks, Clare
  10. Hi Gary, Sorry, looks like I did misread your post. Very good point about the Model Shipways' kit being a model of a model. I believe there are other oddities from the Rogers model like the undersized gun ports? Clare
  11. Geoff, Long ago, I had purchased something from this outfit. They're in Israel, I believe. I think it is either run by, or they work with, a guy who is a ship modeler. I did receive the plans I ordered, but you could tell they were copied from some kit, but not one that I'd ever seen or heard of. I think it was some Eastern European manufacturer. As far as I know, they might actually have the rights to sell the stuff, but there was something just not quite right in my dealings with them. The plans had no scale on them, belaying plans were numbered, but there was no guide as to what the numbers corresponded to. Lots of issues like that. So, the plans ended up being worthless. I've since warned ship modeling sites about them. One old site used to be a "dealer" for them, but after I and a few others complained about the company, they decided to break their ties. I suspect you'll get your plans and they may or may not be useful, but I think we're all better off not dealing with them. Not much you can do beyond that except learn from it. Clare
  12. Hi Gary, Personally, I wouldn't be too quick to disregard Erik Ronnberg, Jr's instructions. He's an outstanding model builder and researcher who's work is very well known. Petersson's books are great, but I think people put too much emphasis on them. His drawings are extremely useful, but generally taken from a single contemporary model – A British warship model donated to the Briston Industrial Museum in 1844. So, what period does the rig represent exactly? Anyway, I had to look up what you were referring to because something didn't seem right. That lift arrangement you show is only for the lower yard lifts. These yards are fixed, so they aren't raised or lowered by the lifts. My take is that if necessary, temporary jeers could be rigged up to lower or raise the yard down as needed. Otherwise, the lifts only serve to keep the yard steady. But, I was surprised at your mention of no slings, so I looked through the instructions again and there is in fact an illustration, fig 38, that shows the lower yard sling in place. Though I never built her, the Fair American was one of those life-long loves in ship modeling for me. Hope you are enjoying the build – I'm quite envious! Clare
  13. Running the risk of filling up this forum with topics about the Shipyard HMS Alert kits, I had to share this. This guys build is just incredible. Shows what you can do with the Shipyard "Laser Cardboard Kit". I just ran across this yesterday and I initially posted it my own own topic about the smaller scale Shipyard kit. I was afraid it would just get buried in there, so moved it to this new post. These are links to the 1:72-scale kit that Janet B is building and I know others are building or interested in building – Ages of Sail just sold another one of these kits just a few days ago, so it got my attention. I see a reference in the build logs to the builder living, or had lived, very close to my location. I'm temped to seek him out, though this stuff was done about 6 or 7 years ago: On a German Site: 1/72 Alert Awesome build log On Flickr: 1/72 Alert Awesome build pics I'm tempted to toss out what I've done so far and to just buy this kit. Nice 5-hole deadeye on that mainstay. Anyone know if that's in the kit or if the builder made it? Nice touch with the served lines and mouse's (mice?) too. I only wish he hadn't put it under full sail on the launch ways... Still, a beautiful job on the model. Clare
  14. Thanks for the supportive comments, Chris. I've run into some of my first limitations, either skill-wise or model scale-wise. On these kits, the hull planking is pre-shaped, which is really nice. But, all of us here know the complexities of wooden ship hull planking. The hull of this kit, and probably of most Shipyard kits I expect, are laid in 3 layers. The first layer was shown in the last images of the model I posted, and is made up of filler sheets that span the space between individual bulkheads. These are thin paper, no build-up, and pretty easy to add. The next layer consists of printed strakes, 2 to 3 planks wide. The printing serves as a guide for laying the final layer, which is made up of the individual planks. So, anyway, the second layer, made up of several strakes, is a bit tough to add so that it's nice and smooth. I've found that in order to fit them correctly, I get a little bit of buckling along one edge and a wavy edge is formed, consisting of bumps and valleys. I've compensated for this by taking the bumps and tacking them down firmly with instant CA. There are still the valleys, which of course get tacked down as well since the CA wicks into them. But, I take the point of the Xacto and cut them loose from the hull, causing them to rise up ever so slightly, somewhat evening out the strake. Is this the best way to approach this issue. Is it a common issue with Shipyard kits? Or is it a sign that perhaps I started off wrong when I attached the bulwarks section. It wasn't very clear how to add that piece, whether to glue it so it sits on top of the deck or so that it's fixed along the hull, right at deck level. First Layer of the hull Second Layer of the hull Looking back, I guess there are ways to figure this out, say, by test fitting other parts to see what allows them to fit most easily. But, I did as best I could and ended up gluing the bulwarks piece to the hull right at deck level and I THINK this is correct. But, like I said, the hull planking isn't laying PERFECTLY. Maybe this is just how it's supposed to go? I know this is starting to look more like a build log, but I'm really reluctant to treat it like one. I really like posting here in the card model section. I find it much easier to find things here and it also makes it easier to find other card modelers. Some card models in the build log section are not marked as such. That said, I thought I'd post a couple more pics of what I've been doing on this 1/96 scale Alert... Second Layer completed The Pre-Printed Decks are pretty cool All is well and this kit is very nice, especially for the price. But, I'm starting to appreciate more and more the value of NOT having parts pre-colored for you. I've ended up with a few glue blemishes, shades of the days of building my first plastic models as a kid (so many gluey finder prints on those early models). I've used the paints I bought from Shipyard to even out the coloring of the pre-printed bulwarks. It's better, but not great. And now having seem some EXREMELY AWESOME pics of a build of Shipyard's 1/72 scale HMS Alert kit posted on another forum and also posted on Picasa, I'm drooling over the bigger kit. Also, I haven't checked it out closely, but I believe the parts are not pre-colored, so I think that makes it easier for those of us who are comfortable with painting anyway. Okay, now to TRY to get back to my regular projects... Clare
  15. Hi Janet, That's the nice thing I see about these paper models, they don't take much in the way of tools or space – No $500 tables saws or thickness sanders or drill presses, just scissors and razor blades... Clare
  16. Hi Anthony, The sails do seem to be very nice and the lines appear pretty well to scale. I finally open up the package today to check them out. They're pre-printed, but only on one side. I don't know if you're expected to sew them or not, though I seem to recall having seen instructions somewhere that call for the bolt rope to be glued on. But, that's what I normally do with sails anyway. By the way, this isn't formally a build log yet, more a review of the kit, which is why it's still in this forum. While I am playing around with the build, I'm mostly doing it to check out what these kits are like. It's been kind of fun though and I am getting into it. The build log you pointed out should be very interesting. It's actually a different kit, the 1/72 scale "Laser Cardboard Kit", while mine is the 1/96 scale "Paper Model Kit". We'll see how much I get sucked into this card stock world – I also have the Santa Leocadia Super Modellar Plans, which includes all the hull parts. AND, I just ordered a detail kit for it from GPM as well as some of their CA glue based on a recommendation here on MSW. It's so much cheaper to work on card models, even though I'm ordering stuff from Poland. Clare
  17. Hi Rick, On the contact cement, are you by chance talking about Pliobond 25? I started off using that contact cement, and I swear smells like cat pee. I had to put the model in another room because of the strong odor – it completely filled the room wherever the model sat. It worked great, but I had to switch to something less noxious because we do have a cat here and neighbor cats that come around and it was causing us a lot of confusion – did a neighbor cat get into the house? I'll have to try out the GPM CA. I've been using regular BSI stuff, which works great, but I'm thinking about ordering something from GPM anyway, so I'll get some of the CA at the same time. I've only been working on a paper model kit for a couple months, 1:96-scale HMS Alertn, but find them really fascinating. I hope you'll post a few photos of your hull planking process. Clare
  18. Thanks for the kind words, Nils. In fact, my latest order from Shipyard arrived today. I was a little worried because according to their tracking system, my order had been sitting for more than a week, not shipping. After about 10 days like that I emailed them, but got no response. I figure it may be the English/Polish language barrier. But, some days later I did receive an automated notice that my order had shipped. Didn't take long for it to arrive. I'd gotten the 1:96 scale HMS Alert sails and Masting sets. You shouldn't need these at all since the items are drawn out well in the kit, but I wanted to check them out and they aren't expensive. While I was at it, I thought I'd try out their paints. There was a minimum shipping charge anyway, so I just added enough to fill out my order without raising the shipping charge. The paints are often referred to as watercolors, but I think that's a translation error. They look like basic artist's acrylics to me, but I don't know that much about the difference between the two. Anyway, I ordered them to try out, and they were very inexpensive. These are the same paints that are included in the boxed "Laser Cardboard Kits." They are simply Renesans brand artists acrylics, made in Poland. I'm assuming that the color printing in Shipyard kits basically matches the colors of the Renesans acrylics, but I don't know for sure. That's just a guess. Then again, as I think Chris (ccoyle) points out in his fine intro, all that may be necessary from the paints is to give the edges of the paper a little color, so it may be that color matching shouldn't really be an issue. I'm not intended this to be a build log, but I will post some pics later on to show how the kit looks mid-way through the build. It may be a while because this is supposed to be one of those side projects. Clare P.S. I should note that I believe all this stuff, not just the paints, are included in the larger scale (1:72 – mine is 1:96) Laser Cardboard Kit boxed sets.
  19. My bad! I wanted to make sure the ad announced the kit in time for the NRG Conference, but didn't realize how quickly the ad would show up in the Journal. The kit is coming soon. We were hoping to have a more definitive date by now, but will have to wait for more info. I'll try to get a mention of the kit on the Ages of Sail website, but will have to do a little reorganizing first. Maybe later this weekend. Clare
  20. Thank you Nils. This is an interesting kit. I agree it's on the small side, but I don't know that this is really a bad thing. I'm actually tinkering with building something in a scale that's often referred to a sub-miniature 1:192. Small scales take less room and you can often get away with simplifications that you can't at larger scales. But, yes, paper details at 1/96 look pretty challenging. It would be interesting to try out the larger 1/72-scale version of this ship. Same company, but it's only available in a boxed edition that's 3 times more money. Anyway, I wanted to try out this basic kit. Yes, I've been wanting to build a cutter in wood at a larger scale. I have the Ancre book on the cutter Le Cerf too. Cutters are really nice looking ships and that's why I went with the Alert. And actually, this kit does have you plank the hull in clinker fashion. Interesting that wood kits don't do that. By the way, I put in another order with Shipyard for the mast and yard accessory set and the sail kit. The order was sitting on hold for about 2 weeks and I was thinking that there was some kind of problem. I email Shipyard about it. I didn't get a response back, but a few days later I got an automated message that my order shipped, so I should have it in another 10 days or so. Clare
  21. Hi Dave, great to see you here! I have the Victory posted over on shipsofscale.com, but it's out of date. At some point, I might create a build log here, but I have higher priorities right now. This paper model is kind of a break. Plus it's about seeing what it's like. I blog about a variety of ship modeling news, so I needed to know more about these paper models, which are quite fascinating. Anyway, PM me or I'll PM you and we can catch up. Druxey, Edwin, thanks for the kind words. Do I know what I'm doing? I just talk like I do. But, hey, it's a ship model right? We can do this if we can build in wood! I think... I went to one of the local ship clubs' meetings on Friday and someone brought in a mostly finished card model U-Boat. He brought some of the kits he has. They aren't Shipyard kits, and I have to say that the Shipyard kits seem like the Cadillac of paper models. Of course, I say that, but I haven't seen a lot of the other kit publishers. There seem to be a lot. Still, these are very fine kits and much slicker in comparison with others I've seen. Edwin, I think you should go for it. Anyway, their inexpensive and you don't have to have many tools to build one. Clare
  22. Gregor, your model is looking really terrific. Pardon such a mundane question on such a lovely build, but can you tell me what paints you used on this model? I particularly like the red you used. Is this Caldercraft paint? Thanks, Clare
  23. Thanks Andy. Paper modeling seems like a great hobby in itself. Doris' work blows me away. But, the basic kits are inexpensive and you just seem to need glue, X-Acto or razor blades and a cutting mat. Occasionally, I've made use of a sharp pair of scissors, but you don't need any power tools and you don't need a whole lot of space. So, that's really nice. Working at 1:96-scale may prove to be a little overly challenging for me when I get to the details. I know what it's like with wood models and, thankfully, they're pretty sturdy. For a bit more expense, the 1:72-scale boxed kits of Le Coureur, Berbice and HMS Alert might be better to work with. I just went the cheap route to try it out. But in the long run, the boxed sets might be a better deal, plus the bigger scale, included fittings, paints, etc. Ages of Sail has a big order in with them for more items which are apparently stuck in customs somewhere, but I know they (we) at least have the Berbice and Coureur "Laser Cardboard Kits" in stock. If I crash-and-burn on this build, I may give one of those a try. But, here's to hoping all turns out well! Clare
  24. Well, I broke down and ordered this paper model kit from Shipyard last month. I've been helping Ages of Sail with various things for the past several months and ran across their stock of Shipyard paper model kits and was intrigued by them. I have a very vague memory of paper models as a kid. I think my older sister or an older person I knew must have had a paper model kit or something, because there seems to be something oddly familiar about them. In any case, I ordered the kit from Poland, and it only took about 10 days to arrive. I immediately had to open it up to check it out. HMS Alert is a 12-gun cutter and there's a great volume of the Anatomy of the Ship series on it. The model itself is the smaller of the two versions made by Shipyard. The larger one is part of what they call their Laser Cardboard Kit series. That's simply their term for a complete boxed kit that includes laser cut frames, but also all the paints, dowels, paint brush, wood blocks and deadeyes, and turned brass cannons, etc. Some of the kits in the series are also available as part of their Paper Model kit series, but the Laser Cardboard Kit versions are often a larger scale. My kit is just one of their standard Paper Model kits. It's 1:96-scale, whereas the Laser Cardboard Kit version is 1:72 scale, which would have been nice, but a lot more expensive both for the kit and for shipping. Mine cost me about $37 including shipping. You'll pay more for it from U.S. stores since distributors can't sell enough of them to get better pricing, but at least you don't have to convert currency or deal with overseas customer service. Not that any of this has been an issue with my first order. My only experience with Shipyard kits was the HMB Endeavour kit, which is packaged like my Alert kit, but the Endeavour had no laser cut frames. So, I was pleasantly surprised to find that the Alert had a full set of frames, all pre-cut. Of course, I had to try out the kit right away and next thing I knew, I had the hull framing done and I was off to add the hull sheets! This is something of a side project for me, and I'll probably work on it the way I worked on the 18th Century English Longboat kit, which was just something I pull out when I need a break from wood ship modeling. So, I didn't plan on doing a build log on it. At least not for now. But, at the moment, I seem to need a lot of breaks, so I'd spend an hour on the Alert pretty regularly. I've been experimenting with glues a little and settled on the contact cement I have for most of the work. It's Pliobond and the stuff reeks, but I've gotten used to it, and it seems to work very well. I'm surprised at how well everything has gone together so far. Of course, I haven't dealt with any of the fine details. Not sure how I'm going to do with all those things. And, I'm a little cautious about rolling my own cannons. But, I'd like to keep from turning it into another wood ship model kit where I just use all the same fittings, buy after market cannons and all. So, we'll see. I'm also a little nervous about how well I can rig a paper model, since I can't use the same "touch" as with a wooden model where my rigging can be fairly tight. So, far, I've managed not to accidentally crush parts, which are amazingly delicate until supporting pieces are glued in place. If I get ambitious, I'll start an actual build log, but I've got enough build logs in progress to keep track of for now. Just wanted to share about the new kit. Clare
  25. Hi Bob, Welcome back! I somehow missed some of your last updates. You've been doing a great job on this build – your model looks fantastic! I know what you mean about not knowing what to call the parts. It's a funny thing about this model because it's so non-Western that items don't really have a corresponding Western counterpart. And even if they do, somehow it doesn't seem right to refer to them using the same terms. Like the vertical timbers up near the bow are used to support a windlass, but do you call them bitts? Doesn't seem to fit. And, the aft half of the ship supports what might be called a main deck house, but I just feel like I need a Japanese-ee term for it, you know? So, how dare you come back from Japan without any more Woody Joe kits! I certainly hope you'll be going back soon to get some more... Clare
