Bob Cleek
Everything posted by Bob Cleek
  1. What mtaylor said. I find wax, even when applied thinned with turpentine and run between the fingers to work it in, is a dust magnet. I'm not just talking about models left out of cases. It's a problem while it's being built. It does serve to "knock the fuzz down," though. Using thinned white glue or shellac may require some running the line under a flame before coating.
  2. More experienced machinists than I will probably have more specific recommendations, but I'd note that it will in the first instance depend upon the scale and the materials you are working with, which is probably obvious. If you are planning on working primarily with wood, I'd expect that you wouldn't be needing to mill any large flat faces. That would be addressed by a hand plane, thickness sander, or table saw. Again, obviously, the various end mill shapes you'd want for woodworking would be determined by the shapes you wanted to cut. Considering that one can easily pay $75 for a 1/8" carbide end mill, I'd suggest that you buy them as you need them rather than by buying a fully incrementally-sized set of them unless you are sure you will find a use for all the pieces in the set. A pass and a half with a 1/8" bit will yield a 3/16" cut, two passes 1/4",and so on, so the number of end mills one needs to buy can be reduced in that fashion by the occasional user who can afford the time to make multiple cuts, a luxury not enjoyed by the master machinist working in a production shop where "time is money." Some hobby catalogs offer lower quality "sets" of miniature mills and router bits at somewhat reasonable prices, but you'll be lucky if you ever have a use for more than three-quarters of the bits in these sets, so they aren't particularly economical in my opinion. If you are working in wood, you may find some low-quality mills and bits that are adequate for modeling use, but you get what you pay for. A mill or bit that dulls and must be replaced in short order is a poor investment. If you buy mills and bits as you need them, as the professionals do, the insult to the pocketbook is less and your collection will eventually build to the point where you are well-equipped for the specific sort of work you generally do without having spent money on tooling you didn't need. Some of the bits and mills marketed by Dremel and their equivalents are adequate for limited hobby wood milling. Don't expect them to last for long, but if the job is small and you are not likely to ever need that bit again, there's no need to pay the big bucks for the professional grade products. There are lots of on-line mill and bit retailers. Below are a couple with particularly large selections. Shopping around is often worth one's time. Quality bits are made by a few companies and the retailers' prices often vary for the same item. If other forumites have personal experience with retailers they can recommend, their posting those links would be most helpful. https://www.toolstoday.com/router-bits/miniature-router-bits.html http://www.harveytool.com/cat/Miniature-End-Mills/Browse-Our-Products_254.aspx
  3. Try hobby shops or online retailers that cater to model airplane builders. Silkspan is used to cover stick-built model airplanes. It's what they paint the dope onto.
  4. Yes, it's pretty difficult to build a model of a boat if you don't know how it works! There are many excellent books like the one you've mentioned that go into great detail addressing full-sized rigging and hull construction details. They won't have the word "model" in the title, but they are often more accurate in many details than the books written for the modeling market. Rigging errors in full-sized applications are a lot more apparent the minute you try to sail the thing! Other similar "full-size boat" books that modelers would find helpful are Gaff Rig, by John Leather, Building Small Boats, by Greg Rossel; Lofting, by Alan Vaitses, How to Build a Wooden Boat, by Bud McInosh, Boatbuilding and Yacht Designing and Planning by Howard Chapelle, The Whaleboat, by Willits Ansel, The Ashlely Book of Knots, by Clifford Ashley, The Sailmaker's Apprentice, by Emilliano Marino, and The Complete Rigger's Apprentice, by Brion Toss. While these books primarily address traditional wooden small boat construction, the construction and engineering principles for small boats are essentially the same as for ships, just smaller. An understanding of traditional wooden ship and boat building practices is essential for building really good wooden models.
  5. I recently picked up used hardcover copies of Petersson's books after reading some discussion of them. I had other original sources, such as Steel, as well as many of the "usual suspects," books of varying degrees of reliability and utility that have been published over the years. I found Petersson's books to be as Frankie described. I share Frankie's annoyance that the industry of ship model publications is one where the accuracy bar seems too often set unacceptably low and particularly so in the area of material marketed for "beginners." A "bad ship model kit" only causes pain for a little while, but bad information in a ship modeling book can bedevil a reader forever. In the Age of Sail, it was the captain's prerogative to rig his ship as he saw fit (or delegate the same to his chief bosun.) There was a wide variety of rigging arrangements with the choice of one over the other simply a matter of style or opinion. As the saying went, "Different ships, different long splices." Those variations, however, do not entitle those who hold their work out as being accurate miniature representations of the real thing to simply "make it up as they go along" regardless of the principles of physics and engineering. I sometimes see errors in rigging or construction details published in otherwise artistically beautiful and often expensive books. I often also see the authors of such beautiful and expensive books representing to the book-buying public that their books contain detailed instructions for building historically accurate models of this or that particular vessel down to the last drift and trunnel when, in fact, there is no contemporary data upon which to base such certainties. Indeed, most of such details were left to the discretion of the master shipwrights, shipsmiths, and riggers and no historical record ever existed of them in the first place. At best, these "super accurate" models, technical modeling tours d' force as they may be, can really only represent the expert modeler's interpretation of the original construction and rigging details based on contemporary manuals, specifications, and "rules of thumb." The same is true of most, if not all, "contemporary models" found in museums and respected private collections. In recent decades, much credence has been given to the accuracy of "contemporary models" and we see errors obvious to the mariner's eyes in these doggedly replicated despite constructive criticism because "that's the way it is on the contemporary model." (A critical consideration is always what restoration or modification may have been done in the hundreds of years since it was built!) One may find that to be acceptable if one is building "a model of a model" rather than a model of a vessel, but that risks polluting the historical record going forward. Anyone who has done academic historical research using primary sources knows the frustration of encountering inaccurate threads in the historical narrative which have been perpetuated far into the future by author after author because somebody somewhere way back when was too lazy to check their sources. Somewhat uniquely, ship models often become part of the "historical record" as we see with the Navy Board and builder's yard models. We should, to the extent we are able, respect the fact that it is possible, however remote, that three or five hundred years from now, that Constitution or Cutty Sark we build today may be the only record posterity has of those ships. Striving for excellence should be appreciated as a characteristic of our hobby. Ship modeling, if it is to have much meaning or offer much satisfaction at all, must be subject to standards. Absolute perfection may well be only a theoretical objective, but it is really the object of the game. Every effort, however much it falls short, should be applauded and encouraged, but let's face it, in any endeavor in which skill increases with practice and experience, nobody is done any favors by withholding constructive criticism and outright damage is done by publishers who print technical books for the profit of it without regard to the quality of their content.
  6. Ditto on the Starrett pin vise, although the ones I've seen on FleaBay lately sometimes cost almost as much as the new ones! As for bits, I'd recommend starting with a Rogers bit set (about $25,) which comes in an indexed stand with a plastic protective cover. (Without the cover, if you drop the stand, I guarantee you'll be unable to find at least three of the bits that spill out all over the floor!) Thereafter, I'd suggest you subscribe to the MicroMark and Model Expo email catalogs. They will pester you to death with "sales," but if you keep an eye open, they sometimes have really good clearance deals on drill bits that come in tubes of ten or twelve of the same size. When they come along, stock up on the sizes you use the most. You can then refill your drill index as you break bits... any you will. You will.
  7. I have to agree with Kurt. I've broke my own tool-buying rule more often that I'd like to admit: "Never buy a tool until you actually need it and then buy the best quality tool you can possibly afford." Like Kurt and probably most serious modelers, I have a "collection" of small power tools that I bought before I knew better, or when I was trying to save money, and which turned out to be a waste of money rather than a savings. A lot of them are still made and sold by companies that offer them for modeling use. Some, such as the Chinese-built knock-off sanders mentioned above, are "adequate" for those who haven't had the opportunity to know the difference. Quality tools do cost more, but when one considers how long they will last, the value of the work they can do, the pleasure to be had in using them, and even the resale value if one loses interest and wants to unload them, they are a wise investment and a bargain, considering their intrinsic value. I've highlighted the differences Kurt notes in his post above. I'd opt for any of the three power tools Byrnes makes, the table saw, disk sander, and thickness sander, over any other for the fact alone that they are virtually "dust free" when hooked up to a shop vac. You could use them in your living room and never have to think about dust. There's more to it than that, though. For the purpose of scale modeling, accuracy is everything. Fine tools cost more because they are manufactured to operate at close tolerances.... in the case of Jim Byrnes' machines, tolerances of a thousandth of an inch and even half that, consistently and dependably. They have considerable mass because weight equals accuracy. For that reason, their working surfaces and adjusting mechanisms are made of CNC-machined solid aluminum plate, not stamped sheet metal and plastic or pot metal castings. Their fit and finish is impeccable, like a fine scientific instrument. They have expensive bearings because those also ensure accuracy. They have expensive motors because horsepower again means accuracy. If you examine the lower-priced products, you will note that their miter gauges and fences are often plastic, which wears and soon becomes useless for producing highly accurate work, The indexing on the low-priced tools is stamped or cast into the plastic parts, rather than machined or photo-etched into metal parts. There is no way a plastic setting knob is ever going to be capable of dependably holding a position to a fine tolerance. Plenty of ship models have been built with a razor blade and a tack hammer, but if you are going to spend money on tools, cheap ones are the most expensive ones in the end.
  8. $225 is a fair bit of change for a hand-cranked sander (apparently) without an accurate tilting table for compound angles and only a rubber disk pad. For another $100, you get a 1/3 hp motor and a highly accurate miter gauge and tilting table with preset angles and variable angle setting and with a thick (1/2" IIRC) disk plate that stores a lot of momentum, so no lagging when the piece connects with the disk. The Byrnes sander has a larger table of CNC machined aluminum. The Byrnes sander also has a very effective dust collection system that hooks up to any shop-vac. Then, too, the Byrnes sander has solid resale value and a manufacturer that stands behind it with a long track record of superior customer satisfaction. Just sayin'. http://www.byrnesmodelmachines.com/discsander5.html
  9. If they are three inch "logs," and you have a planer, why not just plane down one face until it's wide enough to lay flat against your planer fence and then plane another face, and so on, until it's square. You should be able to then cut what you need off the billets with your band saw or table saw. Let them dry with sealed ends, one year for each inch of thickness.
  10. Definitely masts! You could also take the tail half of it and creatively mount it on a base so you could have not only an extended bed, but also a tailstock that could be offset for tapering!
  11. Yes, you're absolutely correct. Mine was originally sold in the UK by Elliott. They were marketed in the US by American Edelstaal. There is also now reportedly a company in Argentina, ROWIC Unimat, that reportedly manufactures an exact DB/SL copy. http://www.lathes.co.uk/unimat/page15.html I've attempted to contact them via email to no avail. It's hard to believe that Unimat DB/SLs went out of production, given how excellent they are. I expect that the decrease in hobby machining and the necessary expense of manufacturing high-tolerance machine tools caused them to be unprofitable for Maier to build anymore. Or it may be that the Unimat DB/SL is just another Austrian that is rumored to be "alive and well and living in Argentina," but cannot be found.
  12. Ditto again on Byrnes Model Machines. You'll get far more use out of a Byrnes saw and thickness or disk sander than any lathe and save a bunch over buying pre-milled wood. Little Machine Shop. http://www.byrnesmodelmachines.com/ If you want to go the multi-tool route using a Dremel moto-tool, Vanda-Lay Industries has a good line of fixtures using the Dremel at very reasonable prices. Their machined aluminum products are much better than the accessories Dremel markets under the Dremel label. https://vanda-layindustries.com/ Little Machine Shop is a one-stop shopping center for small machining. All good quality and fairly priced, but be careful. The lure of their seductive website can be hazardous to your pocketbook! There will be something in there you just have to buy. https://littlemachineshop.com/?Source=Bing&device=c&keyword=little machine shop&utm_medium=referral
  13. Ditto to what the others said. It's a plastic toy, not a serious tool for grownups. Somebody bought the Unimat trade name and is capitalizing on the reputation earned by EMCO, the manufacturer of the original Unimat modeling lathes. The current Unimat trademark owners have a higher quality, and higher price point "multi-tool" on the market now. MicroMark sells it for $750. https://www.micromark.com/search?keywords=unimat It appears to still have a lot of plastic parts. You'd be better off buying a used Unimat DB or SL on eBay (the same tool... the model designations depended upon where it was sold.) They were excellent mini-lathes and passable milling machines. I love mine. The other Unimat attachments were only so-so, as is the case with all multi-function machines. Unfortunately, as is often the case with machine tools, the original Unimat tooling is difficult to find and often pricey. For $750 for a basic lathe, you could get a much larger and more capable machine with readily available, and hence less expensive tooling. China is grinding out millions of them these days in the "7"X" range. Precision machining equipment is not cheap. You get what you pay for. See: https://www.micromark.com/MicroLux-Micro-Lathe and https://www.micromark.com/MicroLux-7x16-Mini-Lathe MicroLux is the higher-priced option. Their lathes probably have a bit closer manufacturing specs. You can find the same lathe made in the same Patriotic People's Hobby Lathe Collective factory for much less sold by other retailers. Harbor Freight sells the same unit in a different color, but you may have to bring it back to them three or four times before you get one that is working right out of the box. Grizzly sells their 4" X 6" micro-lathe for $440, their 7" X 12" mini-lathe for $675, and their 7" X 14" variable speed lathe for $780, plus a number of variants in the same price range. They usually have pretty good Chinese-made stuff. Those prices are comparable to what you'd pay for a used Unimat DB/SL. The Grizzly Chinese "7" X" lathes all have power-feed and screw-cutting capability for most any threading you'd want. So does the Unimat DB/SL, but it requires a proprietary "threading attachment" with special thread formers and cutters and a power-feed attachment which, if you can find them on the used market, will set you back several hundred dollars and the formers for the various threads will run around $150 each and are only rarely available on eBay. Tooling for the Chinese "7" X" clones is widely available at several levels of quality and price points. The small Asian lathes are the butt of a lot of jokes and with some justification. The quality of Asian machine tools generally aren't anything close to American or European machine tools, but at half to a quarter the price, they are more than adequate for modeling work. Look for the label, "Made in an ISO 9001 Factory." That is a manufacturing quality certification that supposedly insures you are getting a machine made under International Organization for Standardization monitoring and certified to specified accuracy tolerances. This is a "bare minimum" certification level, but it's better than no certification at all. Your best insurance of quality among these lathes, all of which look the same, is the retailer you buy from. The top-end retailers have their reputation on the line and keep a closer eye on quality control over the stock they sell with their label on it. https://www.grizzly.com/metal-lathes https://www.grizzly.com/products/Grizzly-4-x-6-Micro-Metal-Lathe/G0745 https://www.grizzly.com/products/Grizzly-7-x-12-Mini-Metal-Lathe/G8688
  14. She's certainly coming alone fine, Rob. It would have been so easy to omit the sails and take a bow, but you pushed it to new heights.
  15. Try it! You'll like it! Fifteen bucks a quart at Lowe's or most any paint store. Grab a gallon of plain alcohol while you're at it. It will last you a lifetime. If the shellac starts to thicken in the can, just add more alcohol, shake or stir well, and you're good to go. (If you add additional coats to dried shellac, they will get shiny. One coat is the best way to apply it if you don't want it to show at all. Two coats will yield a very good scale approximation of varnished wood.) A touch on small rigging knots will keep them in place and a bit of alcohol on a brush will soften dried shellac if you need to untie them. It's also a wonderful all-purpose wood sealer, especially before final fine grit finish sanding. Blow on it a bit to evaporate the alcohol and it will dry very quickly. Far faster than glue. It can even be used as a glue if you let the alcohol evaporate from a cap full of it until it thickens, although I think PVA is probably a better option. It's been used in the boatyards for ages to glue plugs on top of countersunk screws. It's a lot better than epoxy because you can break the plug out if you have to without tearing up the hole. Epoxy takes the edges of the holes with it. It's also non-toxic, if you worry about such things. They say it's so safe you can eat it, but since it's essentially beetle crap, I'll pass on tasting it! https://www.lowes.com/pd/zinsser-bulls-eye-clear-shellac-actual-net-contents-32-fl-oz/3449840?cm_mmc=shp-_-c-_-prd-_-pnt-_-bing-_-pla-_-219-_-interiorstains-_-3449840-_-0&kpid&k_clickID=bi_272560535_1295224885195040_80951593127685_pla-4584551173775128_c_&msclkid=5bfdc711c9361d95e19c9a34bf6f6c2b
  16. I always have, too, and never have had any sagging problems. Instead of water-thinned glue, I use thinned clear shellac. It probably isn't much difference between shellac and thinned glue, but I find the shellac soaks into the fibers very well and is waterproof, which not only stiffens the line, but perhaps keeps it from absorbing moisture. It's also easy to "work" and undo, since it is soluble in alcohol, unlike glue which, when it sets up, is permanent, short of soaking it in isopropyl alcohol. I also find that I can work with the shellac as it sets up to "fix" rigging in place the way I want it. I can in that way get the catenary I want in my running rigging and make sure my coils hang from belaying pins as they do in real life, rather than having them coiled in gravity-defying circles like a cowboy's lariat! (A detail which is essential to a high-quality model.)
  17. One could spend a month going through the Smithsonians on the Mall and not feel like they'd seen it all. Actually, though, while it's been a long time since I've been there, I recall being disappointed that, relatively speaking, the Smithsonians didn't really have a lot of ship models on display. While the Museum of American History is the repository of the National Watercraft Collection (of models) curated by the late Howard I. Chapelle, there was at the time I went, only a small exhibit with a handful of models to represent that collection. I do think if you want to see models, the place to go would be the Navy Yard Museum in Washington and, if at all possible, you might take a 35 mile drive on the freeway to Annapolis and see the Naval Academy Museum, which has the Rogers Collection, which includes a fair number of Admiralty models, some of the finest in the world, actually, and a few "prisoner of war" models. There's 108 models in the famed Rogers Collection and who knows how many more on display at the Academy Museum. Maybe you can leave your traveling companion to spend a day alone in the fine art galleries while you do Annapolis. If you've seen one Van Gogh, you've see 'em all! (Just kidding about the Van Goghs and Rembrandts, of course. If you are interested in those, Amsterdam is the place to go.)
  18. Beautiful "star" figuring at the junction of the stem and bowl!
  19. What an incredible resource a database of 3D scans of important contemporary ship models would be! The HAER ship plans collection, which isn't indexed as well as it might be, struggles for funding to record existing ships around the country. Digitally recording contemporary models rarely seen by the public would be a far more worthy expenditure of tax dollars than what we see being squandered by the government these days.
  20. Somebody local will certainly know more than I do, but I believe that in recent years the Royal Museums (National Maritime, Greenwich, Imperial War Museum, Science Museum, and so on) have been undergoing expansions and modernization, if not something of an administrative merger. I have heard that many of the NMM admiralty models have been relocated to the Royal Navy Museum at Chatham. For a while, I do know that many models were removed from display at the NMM and the Science Museum, but I've read that both museums have since opened new displays of ship models. There's a recent post on MSW of a forum member who recently visited one of the museums and was given by appointment a viewing of a requested number of models not on public display. His photos of these posted here are great. Museum exhibition practices are changing. The days of endless rows of display cases full of artifacts are ending. The modern approach is "interactive" displays with fewer artifacts and more "story telling" exhibits. Conversely, their collections aren't being deaccesioned, necessarily, but rather stored for research purposes. If you go to the Royal Museums' websites, you will find that a lot of their models and documentation are now available and inventoried on line, which is a huge boon to modelers. They still have the stuff, but they are allocating their exhibit space to exhibits that are of greatest, albeit "dumbed down," interest to the greatest number of visitors. We modelers are a "cut above" in terms of sophistication and, in many instances, approach or reach the level of academic researchers who are apparently welcomed to "the back rooms" by appointment only. The days of their exhibiting "everything we've got" are apparently over, but they've still got it all somewhere.
  21. Pipes are very popular out here in California. They have whole stores full of hundreds of pipes for sale. Nobody uses them for tobacco anymore, though.
  22. Brass is always polished in the marine environment. Bronze is not. Brass would generally be limited to light sheet metal work trim aboard ship. This would be things like compass binacles and lamps on period ships. Brass, an alloy of copper and zinc, requires constant polishing or it will quickly tarnish, forming verdigris green oxidation in salt air. Bronze, an alloy of copper and tin and other metals in varying proportions, is a far stronger metal than brass and was used for guns and some cast fittings. It oxidizes slowly, forming a patina with a brown color. "Gunmetal" is an alloy of copper, tin, and zinc, used for casting long guns and oxidizes to form a dark grey patina. Some bronze alloys with higher copper content employed in marine applications will form the familiar copper green patina, such as that sometimes seen on cast bronze statues. The color of the patina on any "yellow metal" piece will vary depending upon the proportion of alloyed metals, exposure to salt air, and weathering and friction on the part (i.e. handling, as seen on coins, etc.) The spectrum of color is quite varied. Iron simply rusts. Cast iron rusts more than does wrought iron. Wrought iron was used for metal fittings fashioned by ship smiths. Early iron-bound guns were made of wrought iron pieces, later supplanted by cast iron guns. Aboard period ships, iron was always painted, generally black, to prevent corrosion. Yellow metal patina palate: Gunmetal, showing the effect of "new" surface green oxidation from exposure to salt weather and "mature" grey patina where the green has worn off in places.
  23. I'd suggest you find somebody who has a number of them and try them out. It's really a personal preference thing, like buying a fountain pen. I wouldn't buy anything but the best in any event. It's not an item to try to save money on unless you are really short on cash. There are two types, single action and double action. I prefer the double action myself. It permits regulating both the air and the paint by the use of a single button. This permits more control over the flow, That said, many modelers are quite happy with a single action airbrush. I use a Paasch I've had for decades. Keep them meticulously clean and mix your paint properly and you should have no problems. Don't clean them and you'll soon have an airbrush you can't do anything with. I'd shop around. The MicroMark catalog has a selection, but you may find the same model for less in one of the big art supply online catalogs. Noise isn't a function of the airbrush, but of the compressor. If you have a shop compressor and want to avoid the noise, get a separate five gallon air tank (Harbor Freight has them for about $25 and always has 20% off coupons on line and in their catalogs.) Put a pressure regulator and shut-off valve on the tank. You can then fill the tank in the shop in a few minutes, and then turn off the compressor and work off the air stored in the tank in complete silence. Alternately, you can buy one of the small compressors made specifically for airbrushing. Most are pretty quiet. (Harbor Freight has those, too. HF will take anything back and exchange for another if you have the receipt, which is prudent if you buy anything from them that has any moving parts. Seriously.) Their quality is usually not the best, but if you know what you are buying and have a store nearby than makes returns less of a hassle, you can often get something decent from them, although it make take a couple of tries. Forget about the aerosol cans sold for use with airbrushes. You'll go broke buying them. A small airbrush compressor will pay for itself quickly, compared to the "canned air."
  24. It's not all that difficult to make it on a frame and then attach it to the model. Draw the net, ruling all the cordage with a fine pencil on a sheet of paper. glue the sheet of paper to a scrap of wood block. Drive nails of tacks ("push pins" are handy for this) into the edges of the block everywhere that a line drawn would extend over the edge of the block. Then take your thread and wrap it over the pins in one direction, and then in the other, so that the line, stretched taut over the nails or tacks, forms squares of the mesh size desired. For fine work, you can simply touch the thread with a bit of shellac, thinned PVA cement, or a dab of clear nail polish (perhaps thinned a bit with acetone) and let it all dry. The net can then be cut from the nails or tacks and attached to the model. Depending on the scale, you can alternately tie each intersection of the thread squares with a separate piece of fine thread (a surgeon's knot works well for this) to fasten the intersections.
