Posts posted by pete48
Thank you Michael, I actually finished this boat over a month ago
Best Regards,
Pete
- Omega1234, mtaylor, michael mott and 1 other
- 4
Finally the Roller furler was made along with the Jib, Bowsprit finalized , Standing rigging finished Solar panel made and installed along with Vhf antenna and Air cowl in the bow. In conclusion she took about 5 months to build, the Client was thrilled and said it looked even better when he saw it in person, She was a lot of fun to build
Once satisfied with the spars they were varnished as well * just a note: there were 4 to 5 coats of Epifanes varnish applied and sanded to 1500 grit sandpaper in between coats , then came the fitting out Sails blocks cleats, I should also point out that the Hull had 3 coats of paint wet sanded to 2000 grit sandpaper then buffed with 3M buffing compound then waxed
- GuntherMT, hexnut, michael mott and 6 others
- 9
- michael mott, mtaylor, Keith_W and 5 others
- 8
- michael mott, Mirabell61, mtaylor and 5 others
- 8
- Omega1234, Mirabell61, Keith_W and 5 others
- 8
- Piet, Mark Pearse, Omega1234 and 6 others
- 9
- mtaylor, Piet, michael mott and 4 others
- 7
I know that this is kind of Backwards, Gallery first then a Revised Build log. To start I have had the drawings for this boat for over 25 years ( purchased thru WoodenBoat. ) so, when I was Approached to build the boat I jumped at the chance.The Boat was built bent ribs over molds just like the original. So I started by making the molds, the first shot is the clients boat
- michael mott, Piet, hexnut and 3 others
- 6
Thank you, Elijah, She will still need to be wet sanded
Best Regards,
Pete
- Elijah, Omega1234, Mirabell61 and 1 other
- 4
Thank's Patrick, I am happy with the way she is turning out, we finally have some decent weather around here
Best Regards,
Pete
- Elijah, Mirabell61 and Omega1234
- 3
Hi jdbondy, The Molds were beveled prior to the ribs being bent over them, It was tricky, the floor timbers were glued to the Keel, and outer edge of the Ribs ( Titebond 3 ) with a paint brush very thin to hold it in place, I went very slow and made sure not to get any glue on the molds, it worked out very well, When I started planking the glue was also applied to the floor timbers
Best Regards,
Pete
- GrandpaPhil, mtaylor, hexnut and 7 others
- 10
- Omega1234, yvesvidal, michael mott and 4 others
- 7
Majellan by Omega1234 - FINISHED - 1/200 - Luxury 37 m Motor Yacht - Miniature
Hi Patrick Piet said it best " Stunning "
