Posts posted by pete48
Well, I procrastinated long enough, I knew that installing the Keel would be difficult, and it lived up to the billing. I started by lining up the Keel on the overturned hull, and marking the Hull as per plan. I used West System G-flex epoxy with 406 filler.( That went smoothly ) The tricky Part was Installing the Deadwood. ( this took a few attempts and burned thru a bunch of wood ) Once the Deadwood was set, I epoxied them in and filled the seams. I will let her stand for a day or 2 and fair the Keel. Here are the results
Beautiful, Nils She is looking Amazing
Best Regards,
Pete
- Mirabell61, Omega1234, Piet and 1 other
- 4
- Elijah, yvesvidal, GrandpaPhil and 5 others
- 8
Thank You, Patrick, She is one of my fav's as well
Thank You, Piet, She was an absolute pleasure to build
Thank You, Keith, I would have liked to set up molds like I did on the Haven 12 1/2, I may still do that at some point
Thank You, Michael, I hope this trend continues
Thank You, Tom. I am without words
Best Regards,
Pete
- Piet, dvm27, Mark Pearse and 5 others
- 8
- usedtosail, Mark Pearse, Elijah and 9 others
- 12
Today, I started by making the Tiller, I almost had the first one complete when the Egg on the tip broke off, I then had to make a second one, it is nearly complete and then need to be finished. I then Made the Boom Vang and installed it to the Mast and Boom. Next will still be to make the cleats and raise the Sails. Here are the results
- dgbot, mtaylor, michael mott and 3 others
- 6
- Omega1234, mtaylor, michael mott and 3 others
- 6
- Engelmann, captainbob, mtaylor and 8 others
- 11
I am hoping to get some work done on the Herreshoff today ( I will post pics later ) I have been doing Pre- work for the 1/2" scale Volvo pond Yacht with the Volvo that I started, I then ( after planking with Balsa ) Realised that I wanted to do some water testing at the smaller scale to help with rudder and keel configurations, So I started another and will be using Basswood for the planking, Here is where I am at with that project
HM Cutter Cheerful 1806 by Erik W - 1:48 scale
in - Build logs for subjects built 1801 - 1850
Very Cool, Erik, she's looking good
Best Regards,
Pete
