Posts posted by pete48
Thank You, Lawrence, Welcome aboard, I will be opening up the Sail loft and she will carry a Main and working Jib, I have not decided whether it will be self-tailing or not. BTW beautiful job on your African Queen
Thank You, Gerty,
Thank You, Piet, I think she may be the Crown Jewel of my fleet
Thank You, John, I originally saw the white on the Spreaders and Masthead in a WoodenBoat Article, " the bees knees" thats great. I hope she finishes strong
Best Regards,
Pete
Today, I started by sanding the Coamings, starting with 400 grit sandpaper and working my way up to 800 grit sandpaper. I then applied the third coat of varnish. IWith 4 coats of varnish on the Mast and Boom, I turned my attention to finishing the Mast by painting the Masthead and Spreaders white. Next will be to finish the Cockpit coamings and start making the Sails. Here are the results
Hi Yves, You are very kind, it was nice to see the picture, I had to show it to Kate, she loved it and likes your house.
Best Regards,
Pete
Hi Nils, The prototype looks good, the wider strakes do stand out more than on the pre-cast lifeboat. I am sure whatever you choose will be Amazing
Best Regards,
Pete
- Piet, Mirabell61, Martin W and 3 others
- 6
Hi Keith, Coeur d' Alene is a beautiful part of the North West. The Deck is looking good. The way to add all references to your posting is done in the Signature. go to your profile page and hit the edit my profile button in the upper right corner, Then on the left side select signature, it will then display " my current signature" scroll down and in the edit signature, you can set it up however you like. I hope that helps
Best regards,
Pete
Thank You, Michael, I am sure that yours will look Amazing ( it already does )
Thank You, John, She is almost ready to be fitted out
Thank You, Elijah, I am just about ready to round the top mark and head for the final leg of this build
Thank You, Nils, I appreciate the compliment
Thank You, Cap'n'Bob, she's getting there
And thanks to everyone that hit the like button
Best Regards,
Pete
Hi Yves, I just discovered your build, Very nice, She's looking good, I will have to follow along
Best Regards,
Pete
Today, After another coat of Varnish was applied to the Spars ( Mast and Boom ) I turned my attention to installing the Cockpit coamings. I started by finalizing the fit. I then made the brace that fits between the Coamings on the forward bulkhead. Next, I made the forward Coaming block, I ( once satisfied with the fit ) I installed the coamings brace and block. I then stained the block and brace cherry red. Next will be to varnish the Cockpit Coamings. Here are the results
Mark, That is looking sharp , well done
Best Regards,
Pete
- Canute, CaptainSteve, Omega1234 and 4 others
- 7
During this week, I have been sanding and varnishing the Hull, rub rails and toe rails. for the sanding. I started with 400 grit sandpaper and worked my way up to 800 grit sandpaper. I then would apply varnish wait 24 hours and re do the process. ( sanding and varnishing ) there are 6 coats of Epifanes varnish now on the Hull. I am pleased with how the varnish turned out, Next will be to complete varnishing the Spars ( mast and boom ) they currently both have 2 coats. Here are the results
- Jond, Piet, usedtosail and 15 others
- 18
- GrandpaPhil, yvesvidal, Chasseur and 3 others
- 6
Nils, That is just Amazing, Wow she's looking good, Beautiful work
Best Regards,
Pete
- Mirabell61, Bobstrake, Piet and 3 others
- 6
SS Kaiser Wilhelm der Grosse 1897 by Mirabell61 - FINISHED - scale 1:144 - POF - first German four stacker of the Norddeutscher Lloyd line
Hi Nils, I agree with Bob
Best Regards,
Pete
