pete48
Everything posted by pete48
  1. Hi, Matti, Beautiful work the letters look fantastic. Well done Best Regards, Pete
  2. Thank's Piet, Very interesting, if you want to stop your Sailboat you put the Bow into the wind ( in Irons ) Did you fly as a commercial Pilot? All the flying I have done was as a passenger. I would rather be Sailing Best Regards, Pete
  3. Thank you, Patrick, sometimes you need to get into the Bilge Hi Michael, I agree with you, More simple, when I started making the Door it seemed like a good idea. ( it was still fun to make ) Best Regards, Pete
  4. Today, I started by making the stem, I then ran the rub rails on the Hull, followed by the Toe rails. I then turned my attention to making the Cockpit floor hatch covers. Next I made the door, it took 10 pieces of wood to make. ( I am not sure if I like it, I will have to ponder it ) I then stained the Hatches cherry red to match the rest of the Cockpit (* I will have to add another coat ) I then started sanding the rails to round them off. Next will be to finish sanding the rub and toe rails. ( The Cockpit Coamings have not been installed )Here are the results
  5. Absolutely Patrick, I would like to build the Herreshoff 12 1/2 the same way this one is being built, ( Herreshoff Mfg. ) I have a few boats that need to be completed first. then I can think about the Herreshoff12 1/2. it has been a learning experience. Best Regards, Pete
  6. It had to be done Michael, there was no way around it, At least I don't have to look at it anymore and I can get back to more important things ( it was a bad distraction ) Best Regards, Pete
  7. Michael, That looks Fantastic, I was originally thinking of doing something similar on the bulkheads of the Haven, Then I was tempted to use the Teak I received from you. Best Regards, Pete
  8. Here is an update on the 12 1/2 one-off, I figured out what needed to happen to make the frames work out. Starting with the 12 1/2 plans ( Herreshoff ) measuring from the waterline to the base line , I would have to lower the transom 7/16". so the slope is 7/16" to zero over 16, so this means I would have to remove all the frames, I pondered this since discovering the problem, Today, I decided to remove the frames, this proved to be difficult and I went thru a lot of blades. I will say this Titebond 3 is some really strong stuff, and does not come apart without taking the majority of the wood with it. I then decided that I would cut the remaining frames off at the blocks, fortunately, I was able to save the frames ( I taped them together and put them away ) I then used a framing hammer and a 1" chisel to remove the blocks, I will re-purpose the Baseboard for the Garden Eel. I can't believe that took all day. Here are the results
  9. Hi, Cap'n'Bob, I did use The Titebond 3 on another build as the only sealant, and it worked out really well, However, I will be using West System to attach the Keel and coat the outside of the Hull. Best Regards, Pete
  10. Thank you, Deon, On the second one, I am doing some things that I wished I had done on the first one Best Regards, Pete
  11. Looks Great, Patrick, she fitted out rather nicely Best Regards, Pete
  12. Here is an update on No. 2 the ribs are bent the Stem, Transom and Knee are made. The Keel is bent and ready to be laid. I think this keel will finish better than on No. 1 Here is where she is at
  13. Thank You, Patrick, No name yet ( right now she is No. 1 with No. 2 started see the next posting) I look forward to seeing her sail. Should be fun Best Regards, Pete
  14. Thank you, John, I think the Teak will definitely make a diference Best Regards, Pete
  15. Today, I started by cutting the ribs in the bow section down to the sheer line. ( station 7 forward ) I then Brushed on Titebond 3 to the bow section and aft section behind station 19. This will seal up these 2 areas, Next I worked on the Centerboard box, first by laying it out from the plans and then getting it to the proper width, in this case it took 1/8" plus 3/32" bass wood, I then decided to finish it off with Teak ( thank you Michael ) I then dry fit it into position, I decided to make a new station 7 bulkhead and applied Teak and dry fit it as well.( I will add Teak to the station 19 bulkhead as well) Next will be to Install the floor framing and add the rear deck beams. Here are the results
  16. Hi Jon, Those are some nice sails, I borrowed the Mold making ideas from the Gougeon Brothers, and combined it with the Herreshoff Mfg. method, it worked out pretty well, I actually started building another one Best Regards, Pete
  17. That is some incredible work Dave, Beautifully done Beat Regards, Pete
  18. Nice work Erik, She's starting to take shape Best Regards, Pete
  19. Today, I decided that I would make her a Sailing version, I started by laying out the Keel. First I took the lines drawing and transferred the Keel to 1/ 16" basswood, cut out the parts needed and glued up the Keel. I then faired outside of the Keel. I now had an empty shell, I then raided my Tackle box grabbed a few bags of sinkers and cut the lead to fit in the shell, To seal it all up, I used Titebond 3 wood glue. ( Water proof ) and Like I said to John, I will make a centerboard in the down position out of 1/8" steel, and that should give me the weight needed. Here are the results
  20. Hello, John, Originally, that is what I thought, My problem is the Ballast, ( not having enough ) I encountered the same problem on the 1st Buzzards Bay 14, and ended up filling the bilge with the weight needed, On this one, I am going to make the center board out of 1/8" steel in the down position, I think that this plus the Keel will give me the ballast needed, without cluttering up the Bilge Best Regards, Pete
  21. Thank You, Patrick, I am building her in the same manner as the Full size boat, I am still not sure how the Keel is going to work out, I think once I've got it figured out, I will determine whether to Sail her or not. I am leaning toward Sailing her. ( Pond style no radio ) Best Regards, Pete
  22. Very Nice, Michael, Looks amazing, rubbing alcohol works pretty good, I noticed that you had made progress on your side project Best Regards, Pete
  23. Thank You, Piet, I was not aware of that, In Sailboat racing the down wind leg usually means that you had just rounded the top mark set your spinnaker/ gennaker ( depending on class ) and are on your way to the finish line ( a line between the pin and the committee boat ) I like talking about sailing ( only a few more months ) Best Regards, Pete
