Everything posted by Glenn-UK
It has been an interesting morning in the shipyard today. I started by giving the unpainted part of the hull a very light sanding in a few areas to remove some unwanted pencil marks. I am really pleased with how the hull now looks, after adding the white paint below the waterline. Forging ahead I then removed the bulkhead tabs and filed the stubs flush with the deck. I also sanded the inner bulwarks smooth removing any residual glue. In the photo below the 6 x stern tabs are still to be removed With all the tabs removed I then proceeded to test fit the two laser cut deck parts. They were both almost a perfect fit. I just had to sand a couple of edges to ensure the decks would lay flat on their respective false decks. The next task will be to fit and paint the inner bulwark planks, however before doing this I thought it would be fun to add the previously built deck items. The deck pumps are sitting very proud as I did wish to force them in position as the pump shafts will require a little bit of sanding. I will also paint the rear hatch red ochre to match the rest of the deck fittings. I quite like the black and white version
- 160 replies
- Alert
- vanguard models
That is praise indeed😁. However I am still in awe of your skills and speed.
- 160 replies
- Alert
- vanguard models
As I finally decided I was happy with how the white painted hull (below the waterline) looked I took the plunge this evening (while watching tv) to remove the masking tape. As the upper tape layers were being removed I was a tad anxious to see if there would be any paint bled.😬 As the final waterline tape layer was removed I was very relieved to note there was no bled. I really like the sharp lines along the waterline and I am very pleased with the end result. 😁 I plan to give the hull a very light sanding above the waterline to remove some unwanted pencil marks as I did initially make a positional error with the initial waterline marking attempt. A nice side picture of the painted hull There is a little bit of work required on a plank half way up the stern counter pattern. I do have plenty of sawdust left over to fill the gap. Bow area
- 160 replies
- Alert
- vanguard models
Thanks for you kind comments. I liked the coppering finish on my Speedy and Victory, the do look great when done. I liked the grey paint in my Yamato and white paint on my Duchess of Kingston.
- 160 replies
- Alert
- vanguard models
I now believe I have completed the painting the hull white below the waterline. When I look closely at the hull there are still some very small "potholes" visible . I know I could continue to fill, sand and paint the hull to eliminate these few remaining "potholes" but I am not sure if it will be worth the time and effort required as I think these "potholes" actually add some character to the build therefore I am tempted to leave them. I have attached a couple of pictures which shows how the hull now looks. Once I have finally decided to move on with the build with the hull as is I will remove the tape. Hopefully there will not have been too much paint bled. Starboard Side Port Side Arial view Arial View
- 160 replies
- Alert
- vanguard models
I am currently painting the hull white (below the waterline). After each paint coat the hull is sanded and filled as necessary. Hopefully the painting of the hull phase is now nearly complete. As there is quite of bit of dead time as each paint coat dries I thought I would use the time to build the 12 x 6 pounder cannons. Stage 1 - Preparing the Axles The first task was to file the edges of the front and rear axles so that the wheels would fit. As each axle was sanded I did test fit the wheels, as shown in the photo below. I also removed the laser char from the 24 front and 24 rear wheel rims. Stage 2 - Building the basic cannon frames This was a simple task of gluing the left and right gun carriage cheeks to the front and rear axles. I applied a drop of Titebond original to the slots in the axles. I fixed both gun carriage cheeks to the front axle and I then added the rear axle. Once the assembly was completed the frames were painted red ochre. I also painted the gun carriage beds black. 6 down and 6 to go All 12 completed The gun carriage beds have been painted black Gun Carriages painted red ochre Stage 3 - Adding the PE parts Each 6 pound cannon requires 1 x carriage transverse bolt, 2 x cap square and 4 x eyebolts. These are PE parts and need to be blackened. These parts were cleaned in acetone and then warm soapy water. Once they were cleaned and dried they were blackened using a burnishing solution. Parts ready to be fitted I started with fitting the carriage transverse bolt. Once these were in place I was able secure the carriage bed's. Next the four wheels were added to each gun carriage. Picture with the cannon dry fitted All 12 cannon frame assemblies completed Stage 5 - Adding the cannons and cap squares I used a touch of Titebond to secure the each cannon to the gun carriage. I ensured each cannon was correctly positioned with the crest and firing hole upmost. Once all the cannons were glued in place I added the cap squares. Picture of 1 completed cannon, the crest and firing hole can be seen on the cannon Completed cannon from a different angle All 12 completed cannons
- 160 replies
- Alert
- vanguard models
This is so true, I am somewhere between a beginner and average ability modeller and I have found a range of accessible and outstanding looking models to build.
- 355 replies
- vanguard models
- Sphinx
I did start by filling and sanding back the obvious dips in the hull using a sawdust and diluted titebond paste mix. I then like to add a thin coat of paint as I find this highlights the less obvious areas that requires a bit of additional filler. For this I will use a diluted 50 / 50 titebond and Ronseal wood filler mix. I did cut the waterline parts from both sides when removing them. Part 5 started to delaminate as it was being cut and was due to a fault in the material sheet.
- 160 replies
- Alert
- vanguard models
When assembling the stand for the Cutter Alert I managed snap some of the support brackets 😪 as I was trying to slot the parts together. I was gutted but thankfully I had enough unbroken bits to make a usable stand. As can be seen in the following photo both name plate brackets are beyond repair as it one of the long support strips and are therefore deemed to be missing in action. I also received the waterline marker I ordered from Vanguard Models at lunchtime today.😀 I will be honest I was not overly impressed with the quality of the materials of the waterline marker as a couple of parts suffered a bit of delamination which was an easy fix with some watered down pva. I also had to file some of the slots in order for the parts to fit together. I did change my mind on the tool however as I did find the tool easy to use when adding the waterline to the hull. After I marked the waterline I applied tape to the hull in readiness for the painting. I decided to use the Plasti-kote 3100SE Super Matt White Spray paint. I have now given the hull a light spray coat of white paint which is now drying. Once dry It will be a case of more sanding and filling (where necessary). I will then spray another light coat of white paint which will be followed with more sanding (600 to 800 grit) and light spray painting until I have an overall smooth white finish.
- 160 replies
- Alert
- vanguard models
Today I have started the process of sanding the hull. After the initial sanding all over (using 320 grit) I was pleased with how the hull looked. I will need to complete the hull sanding processes with a finer grit (600 or 800 grit) at a later stage. Before I do this as the hull is to be painted white (below the water line) it is very important to fill in any dips to get a nice smooth paint finish. My first step in this regard is to fill any areas which are clearly visible to the naked eye. To do this I used my Gimour TPK-PT014 (a cheaper version of the standard Dremel) on some left over planks to collect some sawdust. I then mixed some of the sawdust with a diluted pva solution in order to create a wood filler paste. The following photo shows the remnants of a paste mix and the brush used to apply the paste. I apply plenty of the wood filler paste to the dips. It does not look to pretty (as can be seen in the photo below) but once the paste has dried it can be sanded smooth and any remaining dips can filled with more past. The whole hull coated with areas coated with sawdust wood filler paste I will post some more photos of the sanded hull to show the end result in the next day or two. Once I happy with how the hull looks to the naked eye I will spray a thin coat of white primer paint (below the water line) which will highlight possible imperfections which are not visible to the naked eye. These imperfections will be sanded smooth or filled as necessary. I will probably use a diluted Ronseal wood filler /pva mix when I get to this stage to fill any remaining dips. Hopefully the Vanguard Models waterline marker I have ordered will arrive in the next day or two 🤞😀 as I do not really like the Amati waterline I currently use.
- 160 replies
- Alert
- vanguard models
I have had a good day in the shipyard today and I finally completed the 2nd planking. The 2nd planking has been trimmed around the stern area. I then applied a thin diluted coat of pva over the hull and gave it a light sanding in order for some of the sawdust to fill any gaps between the planks. The hull will require more a bit more sanding (and filling where necessary) before I can move on to the next phase of the build. Here are some pictures.
- 160 replies
- Alert
- vanguard models
I have continued on with the 2nd planking and I expect to complete this task within the next 2 or 3 days time. I do have an Amati water line marker but I have never been happy with it as I have found that the pencil tends changes position when I attempt to add a waterline mark. I have therefore ordered the waterline marker from Vanguard Models (new tools section) which I hope will be better, fingers crossed it will arrive in time. I have been using my quad hands to add the lateral (side) bend to the planks. One advantage of using the quad hands for side plank bending is they can be stacked up so multiple planks can be bent at the same time. In the picture below I have a left and right side plank being bent after a quick 5 second dip in water. With regards to adding the second planks I have continued to use a combination of Titebond original and map pins. Initially, when working in both directions (up and down), I was adding 4 planks at a time (2 port and 2 starboard). However once I reached the waterline mark (at the bow), which is where the up and down planking met I moved on to just adding 2 planks at a time (one per side). It takes around 5 to 10 minutes to shape, bend and chamfer the planks. Once they are glued I normally leave them for around 30 mins before removing the map pins and moving on to adding the next plank pair. The following set of pictures shows the current state of play. The holes left by the map pins can be seen, but will be covered up when the next layer of planking is added. A small amount of filler is required below the water line where some planks meet the stem post. Before I was adding the lower stern planks I sanded the depth of the plank to try to get a smooth line with the keel and stern post. It may not look like that in the picture, but is pretty much the case as it stands.
- 160 replies
- Alert
- vanguard models
Thanks John It should be an interesting build, and once have completed the 2nd planking (which I am taking my time with) I should be able to crack on much quicker. I will keep up with a detailed build log of my methods. You might also enjoy my build log for the Duchess of Kingston (Vanguard Models) which I completed earlier this month.
- 160 replies
- Alert
- vanguard models
Hi Derek Last time I used ca glue for planking I ended up sticking more planks to my fingers than the hull.🤣🤣 I really like the Titebond Original. I normally put a small amount in a dish, enough pva for one plank usually. I use an old paint brush to apply the glue. It grabs very quickly which I really like.
- 160 replies
- Alert
- vanguard models
Work is still slow and steady with the 2nd planking. At the moment I am using Titebond original pva for the second planking which are held in place with map pins. The method I am using is much more time consuming than the more common method of using ca glue (or ca gel) To start the process the planks are shaped as necessary. Next I chamfer the edge so it is a nice fit to the plank it adjoins. Once I am happy with how the plank looks I mark (on the back) the area to be bent. The planks are then soaked in water for around 5 minutes and bent using a heated plank bending tool and then pinned in place. I usually leave the planks pinned for around 30 mins. Each plank is then given a coat of Titebond original and pinned in place a various points along the length of the planks. The map pins are normally removed after about 30 mins. 4 wet planks pinned in position Wet planks pinned in position The end result The next planking strip will cover up the map pin holes.
- 160 replies
- Alert
- vanguard models
I have made a slow start to the 2nd planking. I have added the first four strakes at the top. These planks fitted without any need to taper. I did chamfer the top edge of the bottom three of these strakes. I am taking my time to ensure that these planks look good and will require the minimal amount of sanding for a nice smooth finish. I am expecting that I will need to start tapering with the next strake. I will also side bend the strakes, if necessary to ensure they are a nice flat fit. I have also fitted the first two strakes at the keel. I am reasonably happy with how these strakes are looking. Once again I am taking my time to ensure the strakes look good when fitted. I will continue to add the strakes in both directions for the time being. Bow area Midships Stern area
- 160 replies
- Alert
- vanguard models
Hello Theo. I am being more selective with the planks I am using above the waterline. I am not so bothered with the quality below the waterline as these will be sanded smooth and painted white. Progess is slow with regards to the 2nd planking but I hope to add some pictures of my progress in the next day or two. I am working from the top down and from the keel upward at the moment.
- 160 replies
- Alert
- vanguard models
