Glenn-UK
Everything posted by Glenn-UK
  1. Thanks David The carpet will stay as it soft under foot and warm plus it stops the stuff I drop bouncing away and difficult to find.
  2. Thanks for that Jerry, I will follow suit. Enjoy your new build.
  3. I wasn't planning on posting until I completed some more work on the bowsprit then I thought I would show a picture of my new lathe in action, which I used to taper the jibboom. Starting with a 6mm dowel reducing down to 5mm for a distance of 73mm and then tapered from 5mm down to 3.7mm. Didn't take too long to do. I'm just loving this new toy of mine, but now need to clean up all the saw dust as can be seen in the picture below. I also made the necessary cut outs in the bowsprit cap and also tapered the top and bottom edge. Pictures below show the bowsprit, cap and jibboom dry fitted. The jibboom will run parallel with the bowsprit w hen it properly installed. According to the manual both ends of the jibboom requires octagonal shaping. I'm wondering if this is really necessary and would welcome any thoughts on this matter.
  4. Thanks Jerry I love my new toy. Good luck with your new build when the kit arrives
  5. You are correct sized for 10mm, but I was able to feed the 12.7mm dowel through which I had already reduced to about 12.5mm in order to fit in the hull bow spirit slot. Limited to about 220mm length if using the collets or face plates I cant see a need to buy the 3 jaw chuck for working mast and yards.
  6. New toy arrived on Friday, needed to rearrange the shipyard which I did tonight. Prottox DB250 Mini Lathe Used the lathe to taper the bow spirit, it was a easy task only took about 10 minutes to reduced for 12.7mm to 9.5mm at the cap end just using sand paper. Also made the 4.3mm square end for the cap. Not totally happy with how that turned out. I may keep it but I may make another one. I will decide after I have completed the work on the bow cap, as it may be OK with a bit of wood filler to fill any unsightly gaps. Still working on the hammock crane and netting which I can continue in slow time
  7. I used the model supplied eyelets for the bulwark eyelets, the cannon decorative eyelets and fixing rigging blocks to the deck. I used a larger eyelet CMB 83506 for the breaching ring cae'd to each rigged cannon. I then used a some left over eyelets similar to the CMB 83500 for the larger eyelets on each side of the cannon where the breaching thread feeds through. I only did this on the quarter deck cannons. For the upper gun deck I simply used the kit supplied eyelets for the cannon assembly and 83506 for the breach ring
  8. Work continues with Hammock Cranes. Pictures of first completed hammock crane assembly Fitted the poop deck hammock cranes both port and starboard Added the rigging thread to starboard side Starting to attach the netting attachment=232102:007 Hammock Netting Poop.jpg]
  9. Halo David. I have not ordered the Chuck as yet. When reviewing the product there is a face plate which other users have said we do the job, plus I've looked at some footage on YouTube. If needed I can order one separately at a later date.
  10. Started fitting the hammock cranes last night, adding the netting was not as bad as I thought it might be. I suspect it will take a week or two to complete this task. I will post some picture to show progress in the next day or two. Then I start with the bow spirit, masts and yard production which is a phase I'm really looking forward to starting. Following some discussion with some MSW members regarding lathes / drill presses and internet researching I have taken the plunge and bought the Proxxon DB250 mini lathe (sorry Jerry!!!) as I think this will best serve my needs, hopefully delivery is expected tomorrow (24th April).
  11. Thanks David, and I've still got the netting you very kindly sent me some time ago.
  12. I have now fitted the 4 waist ladders and installed the associated eyelets and rigging. I have started painting the hammock cranes in readiness for the next phase of the build. Here is a couple of pictures.
  13. May be worth considering getting the rudder plated to complete all the coppering
  14. Do you have any ideas for your next build? I can recommend a Chris Watton design such as Pegasus, plenty of good build logs on MSW as well which is a bonus.
  15. Thanks to Jerry, David and Robert for your comments. I plan to fit the chain tonight all being well then I can declare the stern work complete I think I will then have a couple of weeks tiding up and completing some small jobs on the Hull. I also have to think about the hammock crane assemblies, which will probably take another couple of weeks to complete at the very least. I'm almost certain I will buy a lathe to help some of the reduction work on the Bow Spirit, Mast, Yards, etc. but I will have to wait next month before I move forward with that.
  16. Yippee I have finally completed the Rudder assembly. I couldn't believe have much effort was required, took much longer to complete than I thought it would. I'm pleased to report the rudder does rotate on the hinges a little bit and looks OK to the untrained eye but I know the workmanship leaves a lot to be desired. It took many attempts to get some photos I could post.
  17. Nice job Jerry, another build you can be proud off.
  18. The forward edges were fine but I managed to take some depth of the aft edges. This was only on the top section of the front three bulkheads as the lower sections required additional fairing. There was no problem with the rear bulkheads.
  19. Thanks Jerry, it was an easy fix, I got over excited with Dremel, I've been using files to fair the new additions.
  20. I have completed the gun deck planking, except for the part which has to be planked after the gun port strips have been fitted and the bulkhead supports have been removed. I have also fitted the 4 off stern extension pieces. Finally I had over faired the top section of the first three bulkheads. I noted this at the time, before the bulkheads were glued in position. I did try to get some replacement parts from Victory Models / Amati without any luck which is very disappointing. Perhaps I have been spoil by the tremendous customer service from Caldercraft with regard to obtaining replacement parts. In the end I had to glue some additional strips and fair again as necessary. Once I'm happy with the fairing I will start looking at fitting the gun port strips. Build Index - hyperlinks 1. Prework - dry fitting bulkheads 2. Beading Line and Rabbet 3. Lower Gun Deck Fittings 4. Grating Assembly 5. Dry Fit Main Gun Deck and Fitting 6. Gun Deck Fitting Prework 7. Lower Gun Deck Glued and Pinned 8. Pre Gun Deck Planking Work 9. Start of Gun Deck Planking 10. Gun Deck Opening Cleared During Planking 11. Gun Deck Planking Work In Progress 12. Gun Deck Planking & Fairing
