MrBlueJacket
Everything posted by MrBlueJacket
  1. So the jib sail got attached without issue. Now let's see if it can be furled without disintegrating. And yes, success! Adding the drop of glue to the thread/silkspan attachment worked!
  2. So here's jib sail V.3 Lines attached, sheet blocks on, thread tied and reinforced with glue. Should work out fine.
  3. So the sad saga of the jib sails...... First attempt to use 2mm split rings was a disaster, they ripped out of the sails trying to put them on the stays. Second attempt to tie them to the stays also ripped out. Now I just made a third set of sails, I'm going to tie them BEFORE putting them on the stays, and to make the attachment stronger, I will put just a tiny drop of CA on the knot. Wish me luck!
  4. All the braces are done, here are the 2 jib sails I will have furled on the bowsprit.
  5. Here we have the three lower braces attached. Two more to go, then the running rigging on the bowsprit, attach 2 jib sails, and she's done.
  6. The decision to make them limited edition was made by the previous owners. When I took over, they were already well into development. The idea was to honor the 150th anniversary of their battle off Cherburg, France.
  7. Absolutely. An America kit would have either a frame set labeled A-B-C... or 1-2-3... as we still do today. The keel is labeled A 1 B 2 C 3 etc.
  8. One of the most relevant reasons for the loss of solid hulls is that they are labor intensive and expensive to produce, compared with POB laser cutting. The cost of the basswood boards is also more than the cost of the sheets required to produce bulkheads. Our POF models of the America and Jefferson Davis start out as solid hulls which we then slice like a loaf of bread. that technique was invented and patented by Art Montgomery. who owned BlueJacket in the 1980's. It is very expensive, since you have the cost of a solid hull and the cost of slicing it.
  9. That would be nice, but it would take hours of work that doesn't generate any revenue. With the state of the economy, it's just not practical.
  10. And a long one at that. BlueJacket alone has over 80 current kits, and 100's more from the past.
  11. Painted the inside of the cabins flat red, per the instructions. Next step is to paint the outside dark brown.
